Problem with convergence on the upper and lower part of the screen. Red, green and blue colors are slightly separated. Unit is an RCA brand HDTV, p/n: R52WH74
    Sergeant:
  • 399 Answers
Its due to the faulty convergence. the stk convergence ic on the main board which controls the picture alignment is faulty and needs to be replaced to solve this problem.any tv technician will do it for you at a very negligible cost. nothing to worry.thanks.
Posted on Sep 16, 2008
My screen looks like its 3D.
Your tv has a problem with the convergence, adjust it using the original remote go to the setting's menu then go to the convergence section. Adjust the convergence color red and blue the green color is your guide you cannot move this green color, then you should move the red and the blue in all direction left to right, up and down. If you cannot move the red and the blue far enough the convergence IC is defective it must be replace in order to align this convergence. Feel free to send feed back good day and best regards.
Aug 14, 2011 | RCA HD56W66 56" HDTV
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
My RCA HD52W59 HDTV Television has double vision and red, green and blue colors separated like a spectrum in stead of all the colors blending together to make one uniform picture. What can I do?
Ur tv have a problems known as a convergence problems,it dead.The tv convergence board require changes 2 STK convergence ICS and some or all it resistors to solved convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 09, 2010 | RCA HD52W59 HDTV Projection Television
My set is 10 yrs old. In the upper left and lower
Try adjusting the convergence. If it won't move see below- red IC in particular
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 18, 2009 | Sony KP-43HT20 43" Rear Projection...
Converge off a little and screen has green tint
If you have the remote, go to the setup screen and move the picture. Converge has nothing to do with where the picture sits but, where the red, blue & green dots land. All you should see are pure white dots. There should be absolutely NO color ghost anywhere on the screen. If so, you need a bar / dot generator to set the convergence to center the dots.
Jan 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
This is what is known as convergence. a projection tube ussally has three picture tubes.. red green blue. they all have to align. the concave picture indicates complete loss of convergence or convegence power supply. First question on these sets Do you have the convergence option in the customer menu under setup. if you do not this is a indication of the common "FL231 fuse problem" and inexpensive simple repair. I have wrote and artilcle on this under my tips and trick section. If you do have the option then next does autoconvergence work. in you case i would not think it work. under blue and red manual convergence does the crosshairs move. if not then this is indication of convergence power supply board. if they move at all this may indicate a convergence amplifer problem.
Sep 10, 2008 | RCA HD52W56 52" Rear Projection HDTV
Red, green and blue color resolution
you have a bad diode in the convergence part of the unit rca part part# rca25963 they will tell you the part can not be found you will have to do a search on the part to find it.
Jul 28, 2008 | RCA R52WM24 52" HDTV Projection Television
Rca rear projection hdtv lost color convergence
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 07, 2008 | RCA MM52110 52" Rear Projection HDTV-Ready...
Televison & Video Logo
141 people viewed this question
Top Televison & Video Experts
