Intermec CK31 Display screen is upside down, how do l get it back the right way. (have to hold gun upside down to read)
  • detaylor Oct 03, 2008
    Screen is sideways, want to get it back to normal
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
ALT + UP Arrow
Posted on Aug 04, 2009
Click Start->Intermec Settings. Then tap on Device Settings->Display->Screen Rotation. Tap 0 Degrees. Then tap File->Save.
Posted on Sep 22, 2008
The world is upside down, the king has lost his crown, don't laugh please, my monitor screen suddenly got upside down.
Rotating the screen image is a feature of the graphics card and is normally caused by accidentally pressing a combination of keys. To correct it, hold down Ctrl and Alt and press one of the four arrow keys (up, down, left or right) until you have it the correct way up.
As your screen is completely upside down, hold down Ctrl and Alt and press the Up arrow key.
Alternatively, you probably have a Rotation setting in the display properties of the graphics card. You should be able to reach your graphic card settings, but reading and setting them properly may be difficult since everything you see on the screen is upside down until it's fixed.
If all else fails, try restoring the system to an earlier date when the display was right. This will reset the driver to its proper orientation.
Nov 27, 2014 | Samsung SyncMaster 913N 19" LCD Monitor
Can't connect CK31 to Barcode software
Hi Chris,
You need a few things to be able to connect your Intermec CK31 to a server and all the settings are within the "Intermec Settings" within the terminals control panel.
First thing to start with is the wireless profile, set this up to match your current access point wireless settings, SSID, Encryption Type, Key etc. You can also set your wireless IP. Once this is done there will be an icon in the taskbar that shows connection and signal strength. Depending on the firmware revision of the terminal you should be able to use the tools to ping a device on your network, if the server responds to a ping then you should be able to get to your server when you try and connect.
I hope this helps.
If you need any more help then please do not hesitate to contact us:- or TEL +44(0)1202 620955
Jun 19, 2012 | Intermec CK31C,COLOR TE2000,5KY LINR
How to reset factory defaults to CK31? How I can put the settings to access WPA2 in wireless network?
Restoring Default Settings
You can restore the CK31 to factory default settings from
Intermec Settings.
Note: Using the Restore Defaults option restores all parameters
including network settings. When you choose to restore defaults,
you erase the registry. As a result, you may lose network
To restore factory default settings
1 From Intermec Settings, select Device Settings > Restore
2 Select Restore Defaults and choose the Run App button. A
Run Application dialog box appears asking if you want to run
the restore defaults program.
May 12, 2010 | Intermec CK31 Portable Terminal
Intermec CK31 the most slow terminal.. is a piece of ****..
We have come across this many many times. After the terminal has fully booted (can take an hour when slow) and if you manage to access the CPU monitor you would be able to see that the CPU is running constantly at 100% - not good.
A complete blank and operating system restore is required.
or TEL 01202 620955
Nov 07, 2009 | Intermec CK31
Unit will not boot. Screen reads
"Check serial Input" is just part of the cycle on boot up. It checks for a key press on boot up so that it can access a hidden menu. A cradle, serial null modem cable and hyper-terminal is required to bring up this menu
You can try and re-install the operating system.
Download the latest image from Intermec (you will need to register) and then load the image onto an SD card.
Remove the front cover just above the scan engine; 2 slot head screws and insert the SD card. Cold boot the device. Take off battery and hit the reset button a few times. Re-install battery.
Image will begin to reload.
Detailed instructions are available with the download.
NOTE: The latest image downloads from Intermec not longer have the Telnet application pre-installed. If you require the telnet client then select a previous version, but then also not that there are usually 2 versions EX25 and non-EX25 scan engine type.
If you need any more help then please do not hesitate to contact us:- or TEL 01202 620955
Oct 29, 2009 | Intermec CK31 Portable Terminal
2 of the slots don't hold battery in place to charge
Return it to the manufacturer for a refund, or a replacement.
Jul 29, 2009 | Intermec 4-Slot Battery Charger for CK30...
My Intermec CK31 just hangs, it scan and there is a sounf beeping but the touchscreen is not working and even the keyboard.
Sounds like you could have a main logic board problem. Try restoring computer to factory defaults from the intermec settings.
Mar 06, 2009 | Intermec CK31 Portable Terminal
Here at Legacy Global we can help you. Call Diana at 1-847-750-9231.
Sep 07, 2008 | Intermec CK31 Portable Terminal
Intermec CK31 handheld - Configure to read bracket symbol
Mar 10, 2008 | Intermec CK31 Portable Terminal
Computers & Internet Logo
1,181 people viewed this question
David Payne
David Payne
