Question about Frigidaire Refrigerators
Frigidaire FRS23LH5DS9 Side-by-side won't freeze and/or or chill
First, I noticed the ice-cubes were thawing then the refrigerator started buzzing about every 5 minutes. We used a hair dryer to thaw the icemaker line. Cleaned the compressor with a vacuum. Initiated the defrost cycle by pushing in the light switch 5 times in 6 sec. Then turned off the defrost cycle by doing the same. Lastly, we unplugged the refrigerator and let it sit for about 10 minutes before plugging it back in. We reset the Cold Controls from "0" to the "factory settings" on both the refrigerator and the freezer. Fans are running, lights are all on, water line is still buzzing but nothing seems to help the inside remains 60 degrees on both sides. My refrigerator is 3 years old. Any suggestions?
catriver
  • 878 Answers
SOURCE: Kenmore 596.75509400 bottom freezer
JH, did you notice if the freezer back panel was full of frost first time it started thawing? If so you may have a defrost problem. I've had 4 of these control boards (jazz boards) fail on this model in the last week. Behind the front grill, there should be a tech sheet that will show you how to run the componet tests at the control board. Part number for the board is 12002339. This board controls compressor, defrost, damper and fans. Catriver.
Posted on Aug 05, 2007
SOURCE: FRS22ZRF side by side Frigidaire
I'm having the same problem and I've identified that the ice auger is no longer being turned by the rear drive coupling b/c the rear drive coupling is slipping on its axis or axel. There is a nut and some sort of metal clip there but I haven't figure out how to removed it yet. The water not coming from the door dispenser may be linked to the electronic valve in the bottom rear access panel area or possibly a blocked line. ID the valve by actuating the water dispenser and listen if you can hear the valve selenoid. You can remove the water lines at the valve to trouble shoot if the valve is opening. that way you can determine if it is a blocked line or just the valve or something else. ken.wrenn@verizon.net
Posted on Oct 03, 2007
Krazytech
  • 725 Answers
SOURCE: Buzzing and low temps
sound like a compresser relay/overload ,uplug the refigerator remove back cover, remove relay that is on the compressor and check it by shaking it , it should not rattle. if it does replace it..
Posted on Aug 10, 2008
SOURCE: FRIGIDAIRE PRO SERIES # PHS69EHSS #
FIXYA IS A RIPOFF. I MADE ONE CALL TO AN APPLIANCE TECH. IF YOU CLOWNS DONT KNOW QUIT NOW .
Posted on Jan 14, 2009
  • 4 Answers
SOURCE: Icemaker not making ice
Have you tried to turn off the icemaker and turn it back on? Or maybe even unplug the refrigerator for a few minutes in order for the icemaker to reset?
Posted on Jan 15, 2009
Ice maker crushes ice but wont dispense Crushed ice
Good Afternoon Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS23H7CS, is crushing your ice, but will not dispense the crushed ice. It sounds like the dispenser is possibly jammed. Follow the following steps for a possible resolution:
    1)The ice has melted and frozen around the auger due to infrequent use, temperature fluctuations, and/or power outages. Remove the ice container, thaw, and empty the contents. Clean the container, wipe dry, and replace it in the proper position. When new ice is made, dispenser should operate.
    2)Ice cubes are jammed between the ice maker and the back of ice container. Remove the ice cubes that are jamming the dispenser.
    3)Ice cubes could be frozen together. Use the dispenser often so that cubes do not freeze together.
    4)The ice cubes are hollow or smaller than normal. The ice & water filter cartridge could be clogged. Replace the filter cartridge. Dispensing system operates best at 20 - 100 psi water pressure. Well water pressures should fall within this range.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try dispensing crushed ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire FRS23H7CS Side by Side...
Freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Jul 08, 2012 | Frigidaire Refrigerators
The ice dispenser only give crushed ice. It will not do the cubes anymore.
there is a soliniod in the back of the freezer wall that engages to disp cubed ice the coil has either frozen or melted down and won't open the chute to allow cubes out. this happens from time to time on all brands. if you have the coil out and let it thaw you might be able to save yourself from having to buy a part
Apr 23, 2010 | Frigidaire 22.6 Cu. Ft. Side-by-Side...
Ice cubes frozen together and not dropping out of dispenser in samsung side by side refrigerator da99-00494v
Make sure the door is closed tight. It sounds like a thawing and freezing problem. The magnetic strips on these doors are not that strong and if the door is slightly open you may be getting thawing followed by freezing of the cubes together.
Aug 23, 2009 | Refrigerators
Ice maker will not dispense ice
your gpoing to have to thaw out the pan that has all the ice in it the the auger will work
May 23, 2009 | Frigidaire FRS26H5AS Side by Side...
Ice cube button is lite but the only dipenses crushed ice
We have had this problem on occasion. The lever up in the ice dispencer gets jammed with frost and ice. If you remove the ice bucket/auger and let it thaw or just rinse it with water and dry it. Give it a try. -Matt
Mar 13, 2009 | Frigidaire FRS26R4A Side by Side...
Ice maker is crushing ice when cube ice button is on
We've had a similar problem, possibly the same, with our LG in-door ice maker. Whether cubed ice or crushed ice is selected, it crushes the ice.
We found that there is a little lever on the inside of the door, on the lower right behind the ice bin, which freezes in the down position. This is a literal "freeze up", as a block of ice forms in the little well under this switch and eventually freezes the switch in place. Since the switch needs to go up to provide cubed,.. we only get crushed. On 3 separate occassions we've thawed and chipped out (carefully) this little ice dam and gotten cubed ice capability back for a few weeks. At which point it freezes again. I have no idea why water collects there in the first place.
Feb 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
Ice maker not making ice
my ice maker is not making ice what could be the problem, and there is not any water in the ice machine what do i need to look for
Jan 08, 2009 | Frigidaire FRS23KF7AB Side by Side...
Frigidaire refrig stuck on crushed ice will not go back to cubed model #glhs268zds7
A common problem on these models is the solenoid that changes the mode from crushed to cubed has frosted over/frozen over. Sometimes this happens if the freezer door is left open. Slide the ice bin out of the freezer section, and notice where the lever on the end of the ice bin goes into what looks like a plastic "square" on the left side of the box. That "square" is the end of the solenoid and it should move freely by hand. It is probably frozen stiff. If this is the case, sometimes you can get away with thawing it out with a hair dryer, but I usually find I have to take theat whole assembly out of the freezer, thaw it out and then dry up the parts, as it sometimes will just re-freeze if you don't get the excessive moisture off the solenoid plunger.
I hope this helps.
Dec 14, 2008 | Refrigerators
Refrigerators Logo
350 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
