Question about Philips 27PT6441 27" TV
The electricity wen tout and all of my televisions came back on but the philips television,power surge, how to repair
I need to know how to make my televison come back on after the electricity went off and came back on which is a frequent occurrence, like once every two weeks and the television has always came back on but not this time. can it be repaired.
I have an orion and a rca televions which have never been effected by this. the rca televions was on at the same time.
please help
    Champion:
  • 252 Answers
Check the fuse first
Posted on Oct 01, 2008
We had a low power surge that took television off and all electrical items running on low voltage when electric came back on the tele would not switch on .they say they have had to repair inverter...
hello, if you had a power cut, the fuse in the tv might have blown there are 2 types, a glass type and a soldered in type, you will need to check these with a multimeter. also there are fuses on the inverter board. i hope this helps
regardsshaun
May 11, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sony Trinitron Model KV30Hs510
Most likely a part inside the tv has failed, and would need to be replaced. Contact Sony, your dealer, or a local professional for a analysis and asisstance or repairs.
There are hardly any magic tricks we could do to make it work.
If you need more asistance, let me know. Good luck.
If someone knows better, please post.
Mar 29, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
We had bad weather lights went out ..had tv plugged into a power surge plug ...now that i have power back tv wont come on
Some will say a surge protector will save electronics. I can tell you they may not help at all. A power surge is extremely fast and can over ride the surge protector. If you think you can repair this TV, I would certainly remove the back cover and inspect. Occasionally the only problem for repair is to replace the main fuse. Remember, this happens rarely. Most cases after a surge the TV will need to be inspected by a TV tech. Almost anything, in a power surge will damage the TV. There is no certain area that will not be damaged, expect it any where. Thanks for asking and show all hands of support!
Mar 30, 2011 | Philips 47PFL3704D 47 in. LCD TV
Electricity came back on after power outage and the red LED blinks and goes of & there is no OSD
If your TV was not connected to a surge protector, it may be damaged. If you still have your warranty, check if it covers power surges.
Mar 02, 2011 | Philips 42HF7444T 42 in. Plasma TV
I have a philips 27ps50 b321. i can turn the tv on with my channel button. i will also loose the sound in it. it is intermittent sound. i will unplug it or cut it off and the sound will leave out. at first...
Hi
Thanks for using FixYa. You’ll need to reset the Projection TV and to reset it follow these steps—
1. Turn off the television and wait for 5 minutes.
2. After 5 minutes unplug the television power cord from the electrical outlet.
3. Let the television remain without power for more then 1 minute.
4. Plug the power cord back into the electrical outlet. If the television is plugged into a power surge protector, remove it from there and plug it directly into the wall outlet. Turn on the television. If the issue is resolved, then the problem is with the power surge protector and not the television.
If the issue is not resolved then this might have happened due to over-voltage. Please check the power supply unit for swollen/bulged capacitors and burnt wires/components on the power supply board of your TV. You should try and turn off the TV for 8-10 hours to reset it. Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition. All this is only recommended if you have electrical expertise and know how to solder/re-solder components.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 19, 2010 | Televison & Video
Sony wide screen projection tv model kp-57wv600 problem. Sound with no picture. Stanby red light blinks seven times? What parts do I need to repair the problem. Thanks ,Gary
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Jul 19, 2009 | Sony KP-57WV600 57" Rear Projection...
My tv is a 55pp9401 55 in rear projection tv
There do not appear to be any product alerts out for this television from the manufacturer.
Usually the problem you are describing is the result of damage to the television from electrical surges or accidental bumping of the tv. The problem is either power, tuning, or connections.
Check all connections to make sure none or loose, replace any connectors to the tv to see if this was the problem. If not the tv will require internal repair.
Jul 01, 2008 | Philips 55PP9363 55" Rear Projection...
Power button lights up, but no video or sound
I have the same problem with the same tv 3 years after buying it i have a repair guy coming out on wen. to see what the problem is.
May 24, 2008 | Philips 60PP9202 60" Rear Projection...
Fix my tv
COULD BE FANS NOT WORKING. TAKE BACK OFF AND SEE IF TURNING, CLEAN THEM, OR TURN STAND BY MODE OFF OR GO TO SONY.COM, TROUBLESHOOTING OR The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
Dec 19, 2007 | Sony KV-32S42 32" TV
Philips 27PT6441 27" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
