Master
- Posted on Sep 16, 2008
Re: Can u help experts online?
Well to me either the Motor Hub or the Laser assembly needs to be replaced if no spinning then its the Motor hub if spinning and then its probably a dirty laser or a burnt out laser and needs either cleaning or replacement or it could have even come out of alignment which would also pose a issue.
We're having the exact same problem, only after a short time of owning this dvd player. It tries reading the dvd and then a question mark symbol pops up, as if we never inserted the dvd.
To make matters worse memcorp has gone out of business so my unit has no warranty.
We're off to an electronics repair shop, in hopes for a cheap fix!
I have have the same problem and I found out that if you bump the unit it will engage the DVD.
You mentioned that it might be out of alignment.
I am pretty tech savy and have taken the cover off to see if I could see the problem and that is when I found about the bumping.
Can you explain the adjustment procedure if you know.
