Question about Panasonic Matshita- | CW-8124-B | USB 2.0 | Combo CD-RW (GPCW8124BU) Burner
Dvd drive not working
I have a Matshita UJ 820S drive and it comes up as a removable drive and in the device manager i have the yellow exclamation mark error (39) cannot start the driver. There is nothing wrong with the drive because i have two operating system and it works fine in the other system This is a Toshiba p25-S526 laptop
    Problem Solver:
  • 8 Answers
Hi to fix this proble you just need to follow the steps below:
1. Click Startdvd drive not working - vistastartbutton.jpg, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue. 2. Locate, and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM. 3. In the right pane, right-click UpperFilters, and then click Delete. 4. Click Yes to confirm the removal of the UpperFilters registry entry. 5. In the right pane, right-click LowerFilters, and then click Delete. 6. Click Yes to confirm the removal of the LowerFilters registry entry. 7. Exit Registry Editor, and then restart the computer.
Posted on Sep 17, 2008
  • denzo1827 Sep 17, 2008
    Had to repost the steps, my Internet Explorer got an error after I pressed the submit button:
    1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
Need drivers for a MATSHITA UJDA730 DVD/CDRW
are you sure it the drivers?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
http://download.cnet.com/matshita-dvd-ram-lf/3000-2110_4-82302.html
http://download.cnet.com/matshita-dvd-ram-lf/3000-2110_4-88634.html
http://download.cnet.com/matshita-dvd-ram-lf/3000-2110_4-82303.html
http://download.cnet.com/matshita-dvd-ram-lf/3000-2110_4-88638.html
here are 4 different model drivers
hope this helps you
Aug 30, 2011 | Panasonic UJDA730 CD-RW/DVD-ROM (Combo)...
I have not a driver for matshita uj 850 d. the pc not recognised the cd/dvd. thank you.
you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Mar 19, 2011 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
I have an Asus laptop with matshita dvd ram uj892as and when I put someone dvd or cd, noise, but nothing happens.. i need help! thank you!
You need to go to device manager and pull up the properties for the DVD drive and choose the "Region" that you are in. After that the drive should work.
Aug 18, 2010 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
Looking for firmware Matshita UJ-845-c
Install it as a geniric drive hen it should work.
Jan 03, 2010 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
My Matshita UJ-840D DVD/CD-ROM Drive Stopped working
i,m assuming this is A laptop Computer ?
The only thing you can try is this:-
go to My Computer/Control Panel/ System/Device Manager.
see if there are any yellow triangles or exclamation marks by your problem device. if so click un-install. then at the top of that page, there is a refresh icon or similar. which will rescan the systems bus.
failing this try add new hardware wizard, in control panel.
finally ensure the device is connected correctly, unlock/remove and re-insert. update any device drivers for this.
Mike @ Compurepair.
Sep 04, 2009 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
Matshita DVD Ram UJ 820S in my Toshiba Satellite P35 S611
msot laptop drives are 8x newer ones are 16x. you can find most drives work with most laptops. its the harware in the back that hlds drive to pc with a screw that has to be transfered to new drive. but bestbuy isnt in my top list for laptop repair.
Jul 28, 2008 | Computers & Internet
How to delet value data from upper lower filters of the key
The easiest way to remove the filters is to use the tool that Microsoft supplies at this link. http://support.microsoft.com/kb/314060
Jul 02, 2008 | Panasonic Matshita- | CW-8124-B | USB 2.0...
Computers & Internet Logo
222 people viewed this question
Top Panasonic Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Paul Wang
Andrew Freyne
Andrew Freyne
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
