2004 Lincoln Aviator Logo
Posted on Sep 17, 2011
Had an oil change a month ago, oil changed required message still shows up. 2004 Lincoln Aviator
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Sep 17, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1022
Points
Turn key to on but do not start. pump gas peddle 3 times real fast. this should reset the message
What are the steps to clear the messages in the message center?
TAKE IT TO A DEARERSHIP AND HAVE THEM SHOW YOU THE STEPS. NORMALLY THIER IS NO CHARGE BUT ASK FIRST.
How to change transmission fluid in 2004 lincoln aviator
You have to drop the oil pan on the transmission and take your old filter off and put your new one on and seal the pan and back on
Oil change is required shows how I clear it
sorry as far as i know its a dealer only plug in job but i could be wrong
Just had an oil change in my Lincoln Aviator and it still shows Oil Change Required
After an oil change you have to reset the sensor. Your mechanic should have known this. You turn the key on and push button for three seconds to reset it. This should be in the fuse box under the hood goodluck. I hope this helps
1helpful
I had an oil change, and oil change required message still show up. Is there some kind of reset button? 2004 lincoln aviator
Press the Setup Menu: Select the Oil Change function: Press the reset control to reset oil change..
5helpful
2answers
I have a 2003 lincoln Aviator I recently just change my oil and put in Synthetic oli well on on the gauge a message came up saying "oil change is required' can someone solve this problem for me
1.press the setup control to enter system check then press setup control to display "oil life =***% hold reset = new.
2.press and hold the reset control for 2 seconds and release. "oil life is set to 100%" is displayed,
3.If lower oil life is desired, press and release the reset control to reduce the value.
How do i reset the oil change required warning after the oil change has been performed?
it is in the owners manual, you can read that for yourself instead of asking someone else to do it for you princess.
Had my oil changed last month. My dash lite telling me low oil pressure. Systems checkd 96 percent ok. Why is this lite on?
Make sure the oil did not drain out. Sometimes the oil filter does not seal perfectly and oil leaks out. Also check and see if your oil pump is still functioning properly. Oil pressure can also drop if the seal in the engine is worn. If this happens, oil will enter the engine and burn off. Hope this helps in some way
3helpful
2answers
Truck is missing
THE PROBLEM SOUNDS LIKE THE COIL PACKS, THERE IS ONE FOR EVERY CYLINDER, LINCOLN WILL REPLACE THEM FREE I THINK UP TO 150,000 MILES. THEY WILL ONLY REPLACE FAULTY COIL(S).
1helpful
2answers
I have a 2003 a lincoln aviator after i change the oil, how do i get the oil change required, off
when you see the oil change required,press reset by th gear lever(that three bottons that says system info,reset etc. just press the reset one.
Top Lincoln Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
