My gas fireplace pilot is lit, but I can't get the fire to burn consistently. It will come on after awhile (once it took 6 hours for it to come on), then it will go out and come back on at will.
  • adarose1 Sep 17, 2008
    OK, thanks. We are going to try to find the part and replace it. Hopefully that will resolve the issue. I will let you know.
Problem solved. It was a loose hot wire.
Posted on Sep 19, 2008
Faulty Gas valve to gas fire
renew it
Posted on Sep 16, 2008
I have a regency E33 gas fireplace. after 6-7mins with fire on, fire and pilot both go out. any suggestions?
thermopile should show 600mv clean thermopile . clean pilot so its strong and blue . see how that goes, may need new thermopile .
Oct 20, 2017 | Heating & Cooling
My Insta_Flame gas fire place will not turn off completely. We ahve turned off the gas supply now, but before it still had a tiny flame burning even when turned off.
boy that is one sad excuse for a heating guy. how foes this thing flame on? if it doesn't have an electronic spark start mechanism then it operates with a pilot light that will always be going as it uses this small flame (pilot light) to ignite the gas when the thermostat turns it on.
Nov 21, 2014 | Heating & Cooling
Got pilot light but wont fire up all power on
Unfortunately, your question/problem didn't include the brand/manufacturer and model number of the heater, fireplace, etc. However, most of the time, it's that the gas control has not been turned from the PILOT position to the ON position, once the pilot has been lit and it .
Check that first, If that doesn't solve the problem, get back to me with information I listed above.
Hope this helped you solve the problem.
Jun 15, 2011 | Heating & Cooling
Gas fireplace pilot flame won't stay lit.
Hi , you can try and pull the panel on the bottom of fireplace out and check the adapter in fireplace. Sometimes they go bad. When you open in also check to see if there is an adapter plugged in and a option to use the battery operated function. If this goes bad the pilot will not stay lit.
Dec 27, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Propane fireplace insert won't light
Gas apliances have safety features built into them so you don't blow yourself up. The pilot heats a thermocoupler which tells the gas valve there is a flame, open the main gas to the burner. If you can see the flame area of the pilot look for a round post about 3/16 inch in diamiter. This should be directly in the flame, if not bend the bracket so it is in one side of the pilot flame. The thermocouple is attached to a mounting bracket. This will be held in place by a 1/4 inch hex screw. remove the screw and the capilary tube leading to the gas control valve. Before you do anything, close the main gas supply to the fireplace and disconnect the power to the fan. You may need to semi dismantle the fireplace to get the thermocouple. The gas valve end is a brass 1/4 pipe thread plug. Turn the outer nut and remove without twisting the tube. Reverse this order to install a new one. Besure not to twist the capilary tube, tighten brass nut 1/4 turn past hand tight. Your better heating supply house will have these in stock. Restarting the pilot will take a few tries because the gas was off. Your gas suplier would charge about $75 to fix this. if you don't have the proper tools and it dosen't look pretty stright forward don't do it. You could get dead.
Dec 01, 2008 | Heating & Cooling
FIRE GOES OUT AFTER AWHILE
Hi clean pilot light check out thermocouple might need new one
Nov 14, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Marco gas firplace
I have a Model 792864B. Before you attempt to light the pilot light - make sure that any wall control switch or remote control for the fireplace is in the off position. Locate the gas supply line. There should be a gas supply valve to turn on the gas supply. The valve is usually painted a different color than the supply line like blue, green or yellow. Open the valve by pivoting the handle to be parallel to the gas line, usually counter-clockwise. When it is closed it is at a 90 degree angle from the supply line. Locate the pilot light assembly - this is the pilot light. There should also be a red or black ignitor button and a black or green valve control knob with the words "on" "off" and "pilot" on it. It may be located inside a black box, mine is marked heatolator, that has a lift off top. Lift off the top of the box. Push in the valve control knob and turn it until the word "pilot" is in line with the arrow (my arrow is red) or indicator line. While pressing and holding in the valve control knob - it presses in about 1/4", press the red or black ignitor button repeatedly (once per second) until the pilot ignites. Once the pilot is lit, continue to hold the valve knob in for about 30 seconds and then slowly release. The pilot should remain lit. If it remains lit, press in and turn the valve control knob to the "on" position. The on/off wall or remote control switch should now light your fireplace. If the pilot doesn't ignite, turn off gas supply valve, wait about 5 minutes and try it again.
Nov 20, 2007 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
110 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
