Question about Whirlpool Dryers
No heats from the dryer. the mechine is 4 yrs old.
  • moonlee Sep 16, 2008
    no heats at all...why ia it???
    Please help me out.
  • 4 Answers
First thing is to check the fuses. Often there is a separate line for the heating elements. If that fuse or circuit breaker is tripped there is no heat but the dryer will still turn.
There are heating elements behind the drum that may need to be replaced if broken. Also check thermostat control.
Posted on Sep 16, 2008
Where is the belt located?? This maytag legacy elec dryer is 4 yrs old. over the last few mths it has made louder sqeaky noises but now all of a sudden it stopped tumbling!! It still heats up like it's...
it is inside the dryer, you will need to disassemble the dryer here is a website that may help:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
diagram of belt routing:
http://www.applianceaid.com/images/belt-config.JPG
Good Luck Tim
Feb 09, 2011 | Maytag MDE308DAYW Electric Dryer
Electric dryer tumbles but does not dry clothes on any setting. dryer is only 4 yrs old.
Heating element has gone bad. You need to unplug unit. remove back, then find heating element and remove it. Look for what looks like broken springs, if found replace element. 99% of electric dryers not drying are the heating element. Cost around $50
Sep 28, 2010 | Dryers
My dryer is not heating,we have checked all of the settings, and the barrel is spinning so can you please help, the unit is about 4 yrs.old I have a maytag neptune
check ur breaker first, dryers will run on 120volts but wont heat unless have 240.
if electric check ur heating element, thermostats, and thermal fuse for continuity with a meter.
if gas check the ignitor,thermal fuse, and secondary gas coils,
Feb 05, 2010 | Maytag Dryers
3 yrs old stopped in the middle of a cycle .
need to change thermal fuse,when dryer gets filled with lint they pop,it is a safety device that pops when dryer over heats
Nov 03, 2009 | Maytag Dryers
No heat from dryer
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Nov 03, 2009 | Amana ALE331RAW Gas Dryer
Lightning strike power surge partially disabled dryer.(Whirlpool)
If it took a lightning strike something in the heating coil is shorting to ground tripping the breaker. DO NOT Keep trying it, you could cause more damage or even burn your house down.
Sep 29, 2009 | GE Profile Harmony DPGT750EC Electric...
Neptune Gas dryer burner will not continue to fire
There's a good chance you need to replace the igniter. Careful, they are brittle !!!
Sep 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
The cooling function is always on. The dryer will not heat regardless of the mode that it is in Normal/Timed/Manual
hi your mechine will be having a option called reset button by reseting it your mechine program ill be reset and come s to normal state
Aug 24, 2009 | LG Dryers
No fire
This link --->click here<--- is the exploded view for your unit. If you look at diagram 4 (gas valve), the first guess would be a faulty igniter (diagram location 12). This is only a guess for no tests have been done to narrow down the faulty component.
If you need assistance, let me know.
Please take the time to give this solution a fix ya rating.
clarkco
Mar 01, 2009 | Dryers
My Kenmore Elite dryer spins with no heat
please check the thermal cutoff. these are the parts with 2 thick wires attached to it. they are normally located near the heating element ( if electrical ) and (near the exhaust if it is gas).
these parts control the heating element.
tnx 4 using fixya,
drcool
Nov 05, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
