Question about HP PSC 1210v All-In-One InkJet Printer
Hp 1210all in one
Paper run thru with out printing,have ink , it tell meon help have printer ready to go.
Hi recently we brought Hp Deskjet1460 printer we dont know how to use pls help us
Posted on Sep 16, 2008
Does not print.
print a test page from Windows...if nothing prints, you need new ink
Jul 21, 2012 | HP Office Equipment & Supplies
My black ink is not working please tell me how to clean it
To clean it, remove the ink cartridge and rub the print head into a plain paper with rubbing alcohol until ink flows. Then run the print nozzle for 2 time for further cleaning the print head. Then try to print again.
Another way is to soak the print head only into a how water for 5 minutes until ink loose up and ink flows, rub the print head into a plain paper with rubbing alcohol until ink flows. Run the print nozzle and then try to print again
Post comment for more help
Mar 18, 2011 | Office Equipment & Supplies
My printer will not print. it goes thru the motion but nothing prints
The ink-jets that spray the ink onto the paper may be clogged; run a few "print-head-cleaning" cycles. Also, check that you've not run out of ink.
Feb 26, 2011 | Dell V313w AllInOne InkJet Printer
Put new roll in printer and paper feeds through then goes back out again
The printer should accept print paper ready for feed commands when computer sends jobs with clicks. A paper feeder tray may be clogged, attempt to open compartments to ascertain for misaligned or adjusted entrapment areas. Paper feeder adjustments that are tightened least allows feeder processing while loosened paper feeder clips allows several print papers at a time. Select the appropriate adjustment for the papers. Second, printers that run out of ink display sensitive malfunctions either as inability to feed paper when available. Ascertain that printer ink is available.
Jan 28, 2011 | HP PhotoSmart 130 InkJet Printer
Printer will not print anything..the paper runs thru the machine and kicks it out totally blank have inserted new cartridges new printer send by kodak never used
It's time to take the printer to a qualified technician.
Tell him/her that you have just replaced *ALL* the ink-cartridges,
and pay him/her to troubleshoot.
Jan 02, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
False paper jam
Try cleaning the feed rollers with some alcohol on a lint free cloth. You may have some debris on the rollers.
Jan 31, 2009 | Lexmark P4350 All-In-One InkJet Printer
I have a Kodak easyshare all in one printer 5100
You need to clean the printhead of the printer to solve that
issue. Because everytime you print, excessive inks are going
to the printhead that's the reason why it's clogging the
system up. That's because Kodak printers is using
"pigments" as inks that's why Kodak printers are producing
high quality prints unlike other printers - a photo printed from
kodak could actually last for about 100 years. Now back to
your issue, you need to clean the printhead from the printer
but not manually. You could clean it by going to the
software of the printer namely the KODAK HOME
CENTER SOFTWARE. You need to click the "?" mark
icon on the upper right corner of the software window then
under the General Links select Maintenance then choose
Clean Printhead. Do it at least twice and then try making
prints. If that still doesn't work try calling Kodak Technical
Support Representative: 1-800-421-6699
I hope I have been some of help. ^_^
Nov 10, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
After I took out PrintHead and tried to clean it up again, I put it back in with Ink Cartridges and got error code 3813 - also couldn't fix it. Removed Ink Cartridges, turned printer off. Turn back on and it will forget about error code 3813 and will tell you to install Ink cartridges. Do that and error code 3813 is gone and ready to print.
A note: I did not find anything telling me I have to change printhead but my problem with black ink printing still exists so I will get new printhead and see if that problem gets fixed.
Sep 10, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Damm printer
did you use generic ink carts before?
It seems that the ink has clogged the whole print head.
Do use original brother ink carts which have special cleaning fluid within the ink.
After that run the manual ink cleaning procedure by pressing ink etc.
Make sure that all carts are placed well and are secured.
Jan 31, 2008 | Brother MFC 210C All-In-One InkJet Printer
Wants to print but won't put ink on paper
I'm experiencing the same problem. I tried to troubleshoot through software that came with printer, but no luck. Here's what happens:
The printer worked great for a month or so. Then, I didn't use it for a few months. When I tried to use it again, it acts like it's printing. My computer shows it's printing, the printer runs through all the steps, including moving the print cartridges back and forth over the paper as it should, but no ink comes out on paper.
Any suggestions?
Nov 05, 2007 | Lexmark X1270 All-In-One InkJet Printer
HP PSC 1210v All-In-One InkJet Printer Logo
29 people viewed this question
Ben Johnson
