Question about Kenmore Elite 45986 Front Load Washer
Kenmore HE4T Door Latch Replacement Instructions
A while back you offered to provide instruction on how to replace the door latch on an HE4T. Could you still do so?
Also, is there some way for me to visibly see if the latch is broken?
Thanks so much!
  • 5,911 Answers
Okay, here ya go. This link should give you the step-by-step instructions you need:
I hope this helps you resolve the problem you may have. If you have questions along the way, or require further assistance please let me know.
As far as begin able to determine a visible flaw with the latch, the only part that you can check (that I know of) is the latching mechanism inside the slot in the door. The rest of the latch assembly is a sealed component, like an electronic module. There are a few connectors attached to it that you can check to see if they are making proper contact. You can access the rear of the latch by removing the to panel of the washer. Take the panel off by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then off. You should be able to see the connector by looking down behind the front panel on the right hand side. You can also use this as an alternate method of replacing the latch if you like.
Let me know if you have further questions.
Posted on Sep 16, 2008
Kenmore washing machine flashing dl he4t
"Fdl" is a Door Latch Failure error code. This is an indication that either the door latch mechanism has failed, the Central Control Unit (CCU) has failed, or you have a problem with the interconnecting wiring between the two.
I recommend you refer to the tech sheet to determine how to determine which component is causing the error code.
Each one of these washers come with a technicial data sheet inside the unit. To access, you will need to remove the lower toe panel under the door. The panel comes off by locating and removing the screws under the bottom front edge of the washer. You may have to prop the front feet of the washer up for better access to the panel screws (a 2x4 works well for this). With the screws removed, the panel will dro down, then come off. The tech sheet will be located either directly behind the panel, or affixed to one of the interior cabinet walls. Included in the tech sheet are all the error code definitions, troubleshooting data, wiring diagrams and diagnostics procedures.
If you determine the door latch is defective, the following link explains how to replace one:
NOTE: A simple test that you can try to see if the latch has failed, or if the problem is with the Central Control Unit (CCU) is to lightly tap on the control board with a screwdriver at the point where the door latch connectors. There's a relay on the board that controls the locking and unlocking of the door latch. Sometimes the relay sticks, causing the error code to appear. Sometimes this can free up a stuck relay.
To access the CCU, follow these steps:
1. UNPLUG the washer.
2. Remove the top panel of the washer by locating and removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off.
3. The CCU is located top center behind the wash tub. Locate the connector plug(s) that run to the door latch. Unplug each connector one at a time and reseat them. Sometimes this can restore a connection where continuity is lost due to corrosion or oxidation.
4. Attempt to start a wash cycle and see if it works. If not, as the washer tries to lock the door latch, tap the board where the door latch connection(s) are.
NOTE: The washer usually makes 4 attempts to lock the door, before it errors out.
If none of these preliminary measures work, you may need to replace the CCU. If you can get the CCU to work, but still have to tap on it each time, you should replace it as well. This may get you by in the interim while awaiting parts (if you can get it to work this way).
Replacement parts can be purchased at any of the following web sites:
I have found these sites to be reputable and provide great service. Prices differ between them, so shop and compare. The first three sites on the list also include exploded view diagrams to assist you in locating and properly identifying the part(s) you need. The Sears website will sometimes offer a refurbished CCU for much less.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 02, 2010 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore Elite HE4T Washer
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 13, 2009 | Kenmore Washing Machines
Kenmore Washer HE4t. F DL comes up and washer
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Mar 09, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore He4t door lock error
No...the Main Computer (or CCU) is much more expensive than replacing the door latch. "Fdl" or "Fdu" are door latch errors and usually means the latch requires replacement. The following link explains how:
This is a very simple repair if you follow the steps provided. A replacment latch can be found at or Just type in your complete model number in the search menu. If you require further assistance, please let me know. I hope this helps you.
PS This does not mean that the CCU still may not have a fault. Its just much easier and less expensive to replace the latch first. More commonly, the latch is the culprit.
Aug 05, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Replacing door latch on HE4t
Here ya go. Click on the following link:
If you have any problems along the way, please let me know. I hope this helps you.
Jul 12, 2008 | Washing Machines
Washing Machine door latch replacement
Go to and type in your model number. The door latch assembly can be found under the "Door and Latch Parts" heading as item number 7 (part #8181700). If you need instructions on how to replace, just follow this link:
If you do not wish to purchase parts online, use the part number provided and go to your nearest appliance parts retailer. I hope this helps you.
Jun 18, 2008 | Kenmore 4292x Front Load Washer
Coded"F dl"
"Fdl" is a door lock error. It's usually attributed to a defective door latch mechansim and/or wiring harness from the Central Control Unit (CCU). More commonly, however, the door latch is the culprit and needs to be replaced. Post back with your model number (located around the door opening) and I can give you advice on where to get replacement parts. If you go to my profile and look under "Tips and Tricks", I have step-by-step instructions on how to replace a door latch on a front loader. I hope this helps you.
May 03, 2008 | Kenmore 4292x Front Load Washer
Error code
Fdl is a door latch error.  What it means is that the Central Control Unit (CCU), which is the main computer, has lost communications with the door latch.  If you can't hear the latch clicking when you try to start a wash, chances are the door latch is broken.  Sometimes they will click,  but the internal latching mechanism may be damaged.  If the door latch fails to close, the washer will not begin a cycle.  If you provide me with your model number (located along the inside of the door) I can get a part number, price and where you can get a replacement.  I can also give you step-by-step instructions on how to replace the latch.  This is a fairly simple problem that the do-it-yoursefler can accomplish with a little guidance.  Let me know.
Nov 01, 2007 | Kenmore 45981 Washer
Kenmore He4t frontloading machine flashing F 02
U have something stuck in your water pump u need a torx 20 and some hose clamps unplug the machine take the three torx screws off the toe panel put the hose clamps on the white plastic waterpumps hose that goes from the back of the pump to the bottom of the drum unscrew the pump to the left and pull out you can also use the toe panel to catch some of the water pull anthing out of it that u can and replace everything back try taht first
Mar 10, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
497 people viewed this question
Sal De
 Brian Main
Brian Main
