How do i connect wireless with my laptop where do i go and how do i start
    Problem Solver:
  • 18 Answers
First you will need a wireless router, and if you laptop doesn't have a wireless card built in you will need one of those as well. I would write the info about your laptop ie: name, model, OS and go to a local store (Best Buy, Office Max, ect) I would suggest a Linksys Wireless Router and card, they are about the easiest to set up and work very well with most machines and have a great range along with a secure Wep incription to keep your privicy safe.
If this is not what you had in mind, and was looking more for on the go use, contact your local cellular phone company and ask about a Wi Fi card.
Posted on Sep 16, 2008
Connect to wireless internet
There is a wireless card on it. You can use the Connect to option of your Start menu to search and connect to a wireless network connection in a public wi-fi hot spot such as starbucks. If you need to set up your home wireless network, you can use your own wireless router connected to your modem and set the network ID and password by connecting your laptop to it and open the web page with the URL of the default IP address of your wireless router and configure the settings. Use DHCP on your wireless router and your laptop TCP/IP configurations (Shown as Automatic IP address). Then you can use the connect to item in the start menu to connect to the network of your wireless router (according to the network ID you just configured). If there is a switch on your laptop to turn on wireless card, move it to turn on wireless. See the edge and the bottom of your laptop to check about that. Some helpful links:
http://technet.microsoft.com/en-us/windows/ee851695.aspx
http://windows.microsoft.com/en-US/windows7/View-and-connect-to-available-wireless-networks
http://windows.microsoft.com/en-US/windows7/set-up-a-wireless-router
Sep 23, 2010 | Dell Inspiron Mini 10 Notebook
Turn on wireless internet connectin
If you are saying you cannot turn on wireless using a button on the laptop, then its possible it is disabled.
GOTO Start, Connect to and then wireless, this will start the wireless connect.
or
Control Panel, Network Connections, Right-Click Wireless connection & Enable.
Feb 17, 2010 | HP Compaq nx9010
Acer aspire 5542 laptop won't connect wirelessly
GO TO START>NETWORK CONNECTION
CHECK WIRELESS IS THERE OR NOT
if not there
go to Start>Run type "services.msc"
start windows zero configuration
right click WIRELESS
properties
select wireless tab
put one tick mark in the use windows to configure.......................
ok
agin right click on wireless
view wireless network
search on wireless(leftside)
select connect
Nov 01, 2009 | Acer Computers & Internet
Wireless Connection
1. go to Start->control panel->network connections->wireless connection. 2. There you will find an option of repairing the wireless connection. select it and repair your connection.
Aug 30, 2009 | Acer Aspire 4315 Notebook
Unable to activate wireless lan
TRY GOING TO START, START SEARCH TYPE WIRELSS DEVICE
LOOKE IN DEVICE MANAGE FOR WIRELESS FOLDER
INPUT DEVICES
AS SO CHECK THE FOLLOWING FOLDERS ALLOWING COMMUNICATION BETWEEN THE LABTOP AND THE WIRELESS DEVICE AND THE COMPUTER.
NETWORKING AND SHARING FOLDER
PROBLEMS AND REPORTING
SECURITY FOLDER
SYNC CENTER IF YOU HAVE ONE
WINDOWS DEFENDER
WINDOWS FIREWALL
THE LAST 2 PROGRAMS IN THE LIST ABOVE CAN STOP THE DEVICE FROM WORKING.
YOU WANT MORE HELP I WILL HELP YOU IF YOU HAVE THE SITE CONTACT RODGANDYSR@GMAIL
ROD
May 12, 2009 | IBM TP R51 - P M715 1.5GHZ 256MB 40GB...
I can't connect to the router from my laptop
find the wather firewall is enable or what is enable then disable it and other this is wireless zero configuration option is start or what is start then re-start it
Jan 02, 2009 | Linksys Wireless-G Broadband Router
Cant connect 2 laptops through linsky wrt54g is this possible
are you connecting the laptop hard wired or wirelessly?
for wired connection, just plug the ethernet cable from the router to the laptop and it should work fine.
for the wireless connection, check on the wireless network connection. for xp, click on start> control panel> network connections> right click wireless network connection> then click on view available wireless network> then select your network.. for secure wireless connection, type the security key then click connect. :-)
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
Westell model 327w router
if this is the first time you're trying to connect your laptop with the gateway, if this is a windows operating system, you have to go to your wireless zero configuration so that windows can automatically configure the wireless connection of your laptop. you cann see that by clicking on start, and then run, and then type in the box services.msc, and then search for wireless zero configuration click on start if the service has not yet started. if this doesn't work check your built in wireless adapter, uninstall and reinstall it. try to access your westell by typing in 192.168.1.1 in the internet explorer address bar. the default username and password for that is admin and password. you can configure the wireless settings in the modem by going here. the WEP key for your wireless connection can be found below your westell modem/router. if i'm not mistaken this is the westell 327 versalink right? you can also find out if your laptop is connected to your modem by checking your computer's ip address. it should be 192.168.1.xx. if it's like this, your laptop is connected to your 327w. if it's a 169.xxxx ip address, you're not connected to the modem. the best way to configure your laptop and modem wirelessly is to configure it while you're connected using an ethernet cable.
Oct 21, 2008 | NetGear DG834G Router
Netgear wireless router DG834PN wireless access local only I can get internet on my desktop which is connected to the router via ethernet but I can connect to the router wirelessly on my laptop but only...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To start with plug the LAN cable, type 192.168.0.1
into your browser, a netgear window should come
up name is (admin) PW is (password) default.
goto to wireless settings.
Tick Enable Wireless Access Point
Tick Allow Broadcast of Name (SSID, give it a name
Under security options, Tick none
Hit apply and exit
Setup your laptop up with no security to start with, the laptop
Should now see the Netgear SSID name you made.
After this find out your laptops MAC address, log back onto the
Netgear unit, add the MAC address to the allowed list, hit apply
And exit, now only your laptop will be able to get a wireless connection.
Hope this helps
Have a nice day
Aug 14, 2008 | NetGear WGR614 Wireless Router
Asus A6 laptop
Try clicking on Start->Run Then type in: services.msc and click ok. When the window opens, scroll down to the bottom where you should see Wireless Zero Configuration. Make sure this service is started. If not, start it, then go and try your wireless again. If it IS on... then you may want to try reinstalling your wireless card/adapter.
When you go to Network Connections, right click on the wireless connection and on the Advanced tab, make sure the box is checked to let Windows Configure Your Wireless Connection.
Jan 28, 2008 | ASUS A6U Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
