Question about Toshiba Satellite R10-S802TD Tablet PC
SATELLITE M35X-S329 sartup problem and freezes
Hi, when I start up my laptop, power button turns green as normal. Screen stay black for about 1-5 minutes. All of a sudden, it'll boot normal. About 6-7 minutes after it starts up, it will just freeze on me, mouse stops moving but says on present screen. Help me PPPLLLEEEAAASSSEEE!!!
    Problem Solver:
  • 18 Answers
I worked on one of these a few months back, it about drove me the nuthouse!!!!!!! after some long hours of going over every chip and connection in that laptop, and by now a couple more gray hairs, I started my search for help. It turns out there was a class action law suit for this product (not sure now on date) but I'm sure of the M35X. There is a issue with stress fractures in the motherboard, along with a couple of bad soldering connections on the board as well. This one I was working on was so strange it even started to boot as I had the HD half way out of the machine and no battery!!! Sounds like you need a new board, sorry! Just make sure if you do, get a good warranty and extend it!
Posted on Sep 16, 2008
How do I turn on my pandigital supernova tablet?
It could be two things, Jack: I would start by plugging it in to your charger for about 24 hrs to make sure it's not just the battery after that length of time not being used...OR, you might have to reset it to factory settings.
In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults.
First you need to make sure your tablet is powered off.
Hold down on the Volume + button and hold down the Power button at the same time.
  • As soon as the tablet's screen turns on, let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen.
  • At this point you will see a screen with boot options.
  • Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option.
  • On the next screen use the Volume - button again to go down to Yes and use the Power button to select.
  • At this point it will be going through the wiping and resetting process.
  • When it's done you will see the first screen you came to when you first started the setup.
  • Just tap the Power button to select Reboot System Now.
Stuck in Android System Recovery Tips to Fix Recover Lost Data
Apr 27, 2016 | PANDIGITAL SuperNova
My Nextbook model NX785QC8G freezes when you turn it on. How do I reset it to the factory settings? I have looked, but have not found a reset button.
Check http://support.nextbookusa.com/support/index.php?/Knowledgebase/Article/View/84/0/reset-instructions-for-nx785qc8g.
1. Hold down the Volume (+) and the Power button at the same time, until you see No Command on your screen. (The tablet will act like it's going to turn on and go black, continue to hold your buttons until No Command shows up on your screen)
2. Release your buttons when you see the No Command appear on your screen.
3. Tap the Volume (+) once, and a blue menu will appear on your screen.
4. You will use the Volume (-) to navigate and the Power to select. Tap theVolume (-) until you highlight "Wipe Data Factory Reset"
4. Press your Power button to select it.
5. You will see a list of "No's" and one "Yes." Use the Volume (-) to go to the onlyYES on your screen.
6. Press your Power button to select the Yes.
7. This will prompt your tablet to go through the motions of resetting itself. When you see the words ''Wipe Data Complete", tap your Power button once to selectReboot System Now.
8. Your tablet will power off and power back up on its own; this will take a little longer than normal, so give it a couple minutes before it boots.
Dec 29, 2015 | Nextbook Tablets & eReaders
System is frozen. Wont shut down or go to start screen.
Here are two things to try:
I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Sep 04, 2015 | Dell Venue 8 Pro Tablet Computer
How to factory reset a contixo tablet ?
Look around the tablet to see if there is a pinhole along the edge or back. If there is, then you can carefully insert a straightened paper clip to reset the tablet. Normally from off condition, insert paper clip and press power button.
If no pin hole, from an off condition press and hold the volume + and the power buttons until it boots. Follow any directions presented.
I am sure you have checked your manual, but you may want to look again for any specific reset procedures.
Mar 31, 2015 | Contixo Q102 10.1" Quad Core Google...
Trio 10 1 turns on but wont go past the next screen to see my apps
Press power and volume + buttons together until reset screen comes on, then select factory reset!
Nov 09, 2014 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
ASUS T100 stuck at preparing automatic repair message will.not reboot
Hello there, i just owned a brand new Asus T100 for 2 days and today on the 3rd day after purchasing, i faced problems during boot/start up where the laptop gets frozen on the Asus logo screen.
I tried holding down the power button for 10 seconds and turned it on again. It ran a series of windows software updates before the start up, then after all software updates have been completed, the laptop resumed to freeze at the Asus logo screen again. I tried holding the power button for 10 secs followed by holding the power button and volume up button at the same time, to get into automatic repair/repair mode. THIS HELPS, get into the repair mode!
To cut it short, i tried the other advanced options as well as the restart button in the repair mode but to no avail. After carefully reading the different options in the 'advanced options' in repair mode...
Here's what worked for me:
1) If you're stuck at the Asus logo screen which doesn't seem to boot for ages or at least 10 minutes, hold down the power button for 10 seconds and let the screen turn black. (I did this with my charger plugged in, not too sure if it matters)
2) Count to 10 seconds. Switch the laptop on by HOLDING THE POWER BUTTON + VOLUME UP BUTTON at the same time. This will send the laptop into an 'automatic repair', followed by a 'diagnosing this PC' and after which you will see a blue screen which is the repair mode.
3) On the blue screen you will see 2 buttons, 'Restart' and 'Advanced Options'. Click on 'Advanced Options'. (DO NOT CLICK RESTART, it does nothing as you will get stuck again at the logo screen)
4) After clicking 'Advanced Options', click 'Advanced ....' (i forgot what exactly) and click 'STARTUP REPAIR'. This is the crucial part.Then follow whatever the system promts you.
5) Afterwards, it will attempt to repair your system then lead you back to the logo screen for startup.
6) Wait a few minutes and you should be able to get to your login screen as usual.
Hope this helps. I chanced upon it by guessing which would actually help me.
Nov 19, 2013 | ASUS Tablets & eReaders
Reset kindle fire
Step 1: Plug the Kindle into the charger
Step 2: Hold Down the Power Button for 60 Seconds
Step 3: Release Power Button - wait 60 seconds
Step 4: Press and Release Power button normally
Apr 06, 2013 | Amazon Kindle Fire HD
How do you get your screen to show again if it's black?
it shows bubbles in the middle tablet and with blue and green line
Mar 11, 2011 | Tablets & eReaders
IBM X60 laptop won't start
It really does sound like a hardware problem, perhaps a motherboard/processor/memory issue. If there is no beeping but just humming that is just the fan and drives kicking up.
I would recommend you take it into a repair shop and have them diagnose the issue.
Mar 20, 2010 | IBM ThinkPad X60 Tablet PC
Toshiba Satellite m35x-s329 notebook, wireless antena
Do you have a wireless card?
If not you need to get one for it to work!!!
Jan 05, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Toshiba Satellite R10-S802TD Tablet PC Logo
305 people viewed this question
Top Toshiba Tablets & eReaders Experts
micky dee
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
