Question about Acer Aspire 5600 Series 5630-6951 Laptop
Black screen on acer laptop
I have a black screen with a white cursor in the upper left corner. i can get into the bios but computer won't boot up windows xp. i tried the recovery but the laptop powers off after recovery starts and is about 90% finished. what can i do to fix this
  • Anonymous Mar 19, 2014
    when i start up the computer all i see is a black screen
  • 111 Answers
This is commonly caused by HDD failure. I suggest try replacing your HDD.
Posted on Sep 26, 2008
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
White cursor in upper left corner
Remove ALL media, DVD, CD, USB, etc. Unplug, remove battery, plug in, reboot, at boot start tapping F-10 to do a System Restore, use this procedure to restore to a date before this issue: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&prodSeriesId=3832468&objectID=c01634414#A1 Post results.
Feb 02, 2013 | HP Mini 1000 Netbook
When I turn on my laptop pc every couple days a black screen will come up and the laptop stops processing. Why? How to fix it?
I would suspect a glitch in the MBR/software, a black screen with a white cursor in the top left, BUT, Try this , when you shut down always unplug, remove battery when you use at home connected to AC. At boot in BIOS, BOOT sequence, change to Boot from HDD first. Also remove DVD's, CD's from the DVD/CD rom drive, if the machine has boot from DVD/CD rom as a default, it will try to read the disk in the drive first, delaying a switch to second HDD boot. This is a general idea in the Boot sequence procedure: http://helpdeskgeek.com/how-to/change-boot-order-xp-vista/
Dec 25, 2012 | Acer Computers & Internet
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Aug 14, 2011 | Gateway LT2001u Netbook
One minute it was working fine, the next it was a black screen with the cursor blinking in the upper left corner. I tried re-booting it, but it just goes back to the black screen with blinking cursor. Any...
Are you getting the Acer logo on start up? If so you might have a software issue on the hard drive, or the hard drive itself is defective. I suggest using your recovery disc to re-install windows and drivers providing you have them.
Dec 18, 2010 | Acer Aspire One PC Notebook
I turn on the power button,it shows ' acer ' and 'F2 and F12' dialogs. The hard drive light is on at this point, butthen the light flickers and goes out and the screen only gives me a blinking cursor in...
Check you do not have a disc in the CD drive or a USB drive connected.
Check the BIOS has the boot order correct, select the hard drive as the first drive to boot from.
If that does not fix it you will need the OS CD and change the boot options to boot from CD first, and try to recover the data.
Aug 11, 2010 | Computers & Internet
I am trying to replace the hard drive in my compaq evo n1020v. The problem I am having is that when I turn on the computer, it doesn't seem to be booting from the windows CD. It just sits there and does...
you need to set the jumper setting from your Hard Drive as Master Drive and the CD/DVD player is Slave then go to Bios settings then set 1st boot CD/DVD to boot the windows installer..good luck and have a nice day..
Jun 27, 2009 | Computers & Internet
Blank/black screen
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
5
Oct 12, 2008 | Toshiba Satellite A55-S106 Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
189 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
