Question about Lexmark X5470 All-In-One InkJet Printer
X5470 Power is to the printer but it won't turn on
The printer worked fine when I turned it off. The next time I started to use it the power button would not turn the printer on. I called tec support and I got a few hints and then the big blow. Must be hardware failure and since it was out of warranty (even though I bought it and hardly used it) it would cost more to fix than a new one and they gave me 20% off a new one with an ink cartridge and free shipping. Does anyone know how to take the %$&&%$$##@^&&*** thing apart so I can check for myself? It might just be something simple. I've taken screws out but it still won't come apart.
THANKS in advance
  • Lexmark Master
  • 4,338 Answers
Get service manual here:
Please remember to rate all users who assist you for free :)
Posted on Oct 04, 2008
X5470 won't turn on.
Just Keep the power Supply connected for 1 Hour and check the adapter whether its Warm or Not and let me know!
Feb 20, 2013 | Lexmark 4425-001 5470 Inkjet Printer P/N:...
Set the printer to factory defaults. Caution you will lose all stored custom settings. You will then be prompted to set the language, country, date, time and time format, your fax number, and name on your printer..
You can reset your printer to the original settings by first turning off the power. Then p
ress the Start Color (green button) + X and keeping the buttons pressed down. Press the Power On button once to power the All-In-One on. Continue to hold the Start Color (green button) + X buttons for the next ten seconds.
When the prompt appears , release the buttons and follow the prompts on the display to choose your language, country or region code, date, time, and fax number.
Use the forward and backward arrows to select your language. Use the checkmark to save the setting.
Use the keypad to enter the date, time, fax number, owner's name, and press the checkmark after each selction to save.
For future reference support information for your printer may be found here.
Jan 21, 2012 | Lexmark X5470 All-In-One InkJet Printer
X5470 constantly is powering on and off
Please try the steps below:
  1. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer.
  2. Disconnect the power cord from the power source. Re-connect after 30 seconds to a different known working power outlet. Bypass any power surge devices or power extensions/strips and directly plug in the cord into the power outlet in the wall.
  3. Re-plug the power supply into the printer.
  4. Press the power button if the printer won't automatically power on.
If the problem continues, please contact Lexmark Technical Support for further assistance. Thanks.
Nov 02, 2011 | Lexmark X5470 All-In-One InkJet Printer
Good morning, i was printing and the printer shut
Try to unplug the power adapter from the printer. Unplug the power cord from the power outlet in the wall. Replug the power cord after at least 10 seconds - bypass any power surge devices or power strips. Replug the power adapter into the printer. Your printer should automatically power on, otherwise, press the power button. If the printer still won't power on, please contact Lexmark technical support for additional assistance.
May 12, 2011 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470 used to work fine and stopped recognizing printing for the windows vista ?
Try to disconnect your printer from your Vista computer. Reboot your computer. Then, unplug and replug your printer into the power source to reset it. When the printer turns on, reconnect your printer into the computer. Doing this usually fixes minor communication issues.
Apr 20, 2011 | Lexmark X5470 All-In-One InkJet Printer
My Lexmark x5470 keeps turning on and off, but won't print anything. Message says align paper, however the paper is fine, then it turns itself off and then back on to tell me the same thing. I've...
Try to focus on the printer itself first. Remove the cartridges from the printer, close cover then unplug the power supply. The power supply is the black box behind the printer where the power cord is attached. Wait at least 30 seconds before plugging it back in the printer. When the printer's ready, reload the cartridges. Go through the alignment process. When it's done printing the alignment page, try to make a copy. If problem persists, I recommend you contact Lexmark Technical Support for further investigation. There might a hardware issue in the printer.
Jun 08, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 powers on and off constantly
I encountered the exact same problem with my Lexmark X5470. After a power failure on Aug 20, the printer would reboot itself every few seconds. I unplugged the power cord and/or adapter for a few minutes and after replugging, it worked fine. However, the problem returns after I power off the printer and then turn it back on, in which case I unplug again for a few minutes. Hope this helps.
Aug 19, 2009 | Lexmark X5470 All-In-One InkJet Printer
My lexmark x5470 will not turn on after disconnect power and reconnecting. Is there something else I can do?
Is the USB cable back in place? Try holding down the #9 button and the select button while you are powering up the unit. If that fails try pressing the select button after powering up the unit. I had a HP all in one 7170 and during a WILD lightning show I got hit through the phoneline. Zap "All Gone!" I called HP support and they gave me these two steps to try, hope one works for you, if not it's time to go shoppin.
Jul 25, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470
Clear NV RAM..... Unplug the Power Supply from the Printer.... Press and Hold the #5 button on the Printer and plug in the Power Supply....... Don Release the #5 button till the Printer turns on completely.... After releasing the #5 button........ Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM..... Now as soon as the Printer is Restarted....... U will be able to send and recieve faxes..... Thanku.............
Aug 13, 2008 | Lexmark X5470 All-In-One InkJet Printer
Printer activates on its own
To change the power save setting, go to the operating panel of the printer.
Press the Option button 11 times until Power Save appears on the LCD.
Use the arrow buttons to scroll through the options:
After 10 minutes
After 30 minutes
After 60 minutes
Never (select never......)
Press the Select button to save the required option.
Nov 25, 2007 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
519 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
