Question about Thermaltake Xaser III V2000A Extended ATX Full Tower Case
Cable connections to the Mic and Headphones inputs on the top side of the casing
Please help me with the connections of the mic and headphones inputs on the top side of the casing.
I have just replaced my Motherboard and my computer shop does not know how to connect up the cable to the appropriate inputs.
All help will be greatly appreciated.
Thanking you in advance.
Peter from Melbourne Australia
  • 21 Answers
There r mainly three pins one is ur output volume thn othr two is in rose an blue color...and ur mic and head set havin two wires one is blue an other one is in rose ...so pls connect rose pin to rose jacket an blue to blue jacket it will b workin thn ...
Posted on Sep 21, 2008
Bought turtle beach z11 headset, cant get mic to work
The Z11 has a four-pole input/output plug to connect the mic and the earphone. The earphone needs to be connected to the earphone jack and the mic needs to be connected to the mic input jack on the back of the computer. In other words, you should have to 3.5 mm plugs. Plugging both into the same jack will disconnect one or the other. Check your adapter, It should have two separate 3.5mm plugs. If it does, be sure they are connected to the right jacks on the computer. The headphone jack will have a headphone symbol; the mic jack will have a microphone symbol. Go to System Preferences, Sound. Select the line in preference for input and the line out preference for headphones. Just may work.
Mar 14, 2014 | Apple iMac G5 Desktop
I want to use this for skype on my computer and it wont pick up the mic
Hi hilldest,
These headphones cannot be used for your computer ,because you computer requires seperate input for mic, unlike the mobile phone where you have only one pin and then it includes the mic function with it.
So if you want to use the mic you can use it by connecting a seperate mic in the pink slot of your computer and you can still use these headphone to listen to the incoming voice by pluggin it in the green slot of audio output.
Hope this helps ..:) Your feedback would be appreciated.
Aug 28, 2011 | Sony DREX12iP Headphones
I am using pro tools 8 LE. I have a blue bluebird condenser microphone. the cable going into the mic is a male 3 pronged end. and the end going into my avid mbox mini is a normal ending (the ones that look...
The mbox mini is usb powered, wont work without power so your mac or pc must be powered on and connected. The blue led will be on when powered. Assuming you have the the appropriate cables, you want to make sure the condenser is plugged into the Mic/Line input. (Input 1 on the back of the mbox mini). All condenser mics require phantom power, so engage the +48V switch. Also make sure the DI (direct input) switch is not engaged. The input gain control is located on the front of the mbox... There needs to be speakers connected to the 1/4 output jacks on the back of the mbox or headphones on the front for sound output. Use the large knob for monitor volume control.
In protools: Create a Stereo Master fader track
Create a mono audio track
Set the input of the mono audio track to Mic/Line 1 Arm the track for record (click & make sure the R is red)
You should getting levels and sound output from your condenser.
Apr 01, 2011 | Blue Microphones Blue Bluebird Condenser...
How to connect a microphone to Logictech z-340 ?
Hi there and happy new Year , Your Microphone has to be connect to your PC in the Red or Orange Color COded Jack Input , it cannot connect too your Speaker System ...
Hope this helped bud
Dec 26, 2009 | Logitech Z-340 Computer Speakers
Trying to use a microphone but not sure how to hook it up
No because the mic is a signel in device and the headphone jack is a signal out jack! meaning if you plug the mic into it the mic will act as a speaker and music will come out of it and ruin it!
I would buy an adapter at radio shack and plug it into the phono input on the back of unit! and if you dont have a phono input you will need to buy a small pre-amp and plug it into the aux or tape input!
That will work!
Please rate my answer!
Thank You!
Jan 16, 2009 | Samson R21S Microphone
Mic
If your headphones have a single plug you cannot plug these into a regular speaker connection or headphone connction and get mic and sound, you will need a headset that has 2 separate plugs (one for Mic and one for headphone) or a splitter you can get a radio shack. Most headsets have only one plug and there are connections for both the mic and the headphones on this plug, but the headphone connection on the computer has only connections for the headphone and therefore cannot detect the microphone.
Feb 20, 2008 | E-Machines eMachines Refurbished EMA...
Only Hearing Sounds on One Side of Headphones
your headphones are bad sounds like cheak out the new seinhezer hd280 pros ok 99 bucks best they make
Jan 23, 2008 | Edirol UA-25 External Sound System
Can't Connect
go to you sound in preferences and make sure you have clicked on the headphones to use them....that is the only thing i know to do.
Nov 22, 2007 | Motorola Mobility HT820 Wireless / Cable...
Line Recording with H5500
i think that audio jack is for headphone-microphone combined (those cable plugs have a three black lines , top for left audio, center for right audio, last line for microphone) so you can use a headphones with mic directly with this 5500. the mic is i said before is the last line. what you need is a monophone plug. (mono mic) i dont think stereo mic will work.
Sep 12, 2005 | HP iPAQ H5555 Pocket PC
Thermaltake Xaser III V2000A Extended ATX Full Tower Case Logo
183 people viewed this question
Top Thermaltake Computers & Internet Experts
Martin Clarke
Martin Clarke
Lawrence Oravetz
Are you a Thermaltake Computer and Internet Expert? Answer questions, earn points and help others
