Question about Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX
During strating on cpu for opening window, cpu suddenly shutdown. On back and indicator at monitor show thermal even (overheating). Action: already check and replace heatsink also fan but still happen. Please help me to sulotion this matter. Thank you.
  • Mike Peluso
    Mike Peluso May 11, 2010
    Did you remove the old thermal past from the CPU? Clean the CPU using a clean rag & alcohol. (Do not get the CPU wet with alcohol). Add new thermal grease (Small ammount) on to the center of the CPU, than attach the heat-sink & fan assembly?
  • 781 Answers
Also check your power supply unit for dirty or not working fan
Posted on Sep 16, 2008
How can I fix thermal shutdown of Acer b1-730?
Could be the CPU needs new thermal paste and reseating.this is usually a fail safe designed to protect the computer when the CPU is getting too hot.also check the cooling fan ......blocked vents as this may also cause overheating issues thus not cooling the internals which will activate thermal shutdown.
Mar 18, 2015 | Acer Computers & Internet
I have a compaq s5000nx that keeps shutting down and restaring after 20 min have not done any thing to it
Open the case and blow any dust out of the heatsink (under the cpu fan). Overheating is the main cause of sudden shutdowns. You may also want to apply fresh thermal paste between the cpu and heatsink. Please let me know if this helps or not.
-Joe
Apr 17, 2012 | Compaq Presario S5000NX PC Desktop
Model dx4822-01 shuts dn.reports no signal to monitor.when i open up side panel and blow air into pc with floor fan it runs ok.
This shows that your computer is overheating.
Use a vaccum cleaner to get out as mush dust as you can. Pay special attention to the CPU cooler and heat sink. Also clean the graphics card if you have one.
Take care!
damnor01
May 23, 2011 | Gateway 7200MC PC Desktop
I have toshiba satellite A200 series, it's being two and half years since I bought it. Problems: - When I turn on the computer, the computer keep on going in normal way, but the problem is sometime,...
I repaired a A210 this week with a similar problem, it was due to overheating, I even had to reflow the GPU to repair it due to graphics errors. <div>Check that all of the air vents are left unblocked and that your fan is spinning and expelling warm/hot air. It is recommended you use your laptop on a hard flat surface to ensure some airflow under the laptop. You could try purchasing a can of compressed air and blowing it into the vents to loosen up any built up of dust and hair.<br /> If you are skilled enough you could open the laptop up to completely clean the fans and heatsink. Whilst it is open you can remove the heatsink, clean the old thermal paste off of the CPU and GPU and apply a very thin, evenly spread layer of fresh thermal paste. Then put the machine back together.<br /> <span class="apple-style-span"><span style="font-size:10.0pt; line-height:115%;font-family:&quot;Arial&quot;,&quot;sans-serif&quot;;color:black">As for the fans, download a free application called SpeedFan and read through it. It will monitor your core temperatures and it has some options for controlling fans if your hardware allows it.</span></span><br /> Hope this helps,<br /> www.PuterCare.com<br /></div>
Aug 27, 2010 | Toshiba Satellite A205-S4617 Notebook
About 10 seconds after i turn on my aspire 3690 the fan shuts down. the laptop will run for several minutes and then it shuts down also probibly from overheating. The fan starts each time i start but shuts...
First thing I'd check is for a BIOS update for your computer under the Acer support pages (acer.com). In some cases, thermal control updates are included in newer version of the BIOS, if it is a manufacturing problem.
Goto http://www.cpuid.com/hwmonitor.php and download Hardware Monitor, start the computer and immediately run the hardware monitor app to check how high the temperature on the CPU gets before it shuts down.
Continuing use under this condition may damage your Windows installation because of the sudden shutdown.
Mar 21, 2010 | Acer Aspire 3690-2196 Notebook
My laptop gets heat and shutdown
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
Feb 27, 2010 | Compaq Evo N610C Notebook
The computer will just randomly do a windows shutdown and then restart. Cleaned, changed the power supply and still does it.
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the computer back on and figures out a way to foil the protection, the unit is probably doomed. Once a unit shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated unit is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning. Check the CPU fan if it is spinning and also the CPU itself put thermal paste. So that the heat from CPU will absorbed by the heat sink.
Jan 19, 2010 | Dell Dimension 2400 PC Desktop
The system automatically shutdown
This could be anything, however I am suspicious of overheating. Does the computer actually just shut off or does it reboot?
Your heatsink/cooling fan may not be working correctly. See if you can install a utility which monitors the temperature of the CPU. If it keeps rising, this indicates a thermal problem and your fan and/or heatsink need replacing
Dec 04, 2009 | Microsoft Computers & Internet
Same prob
This problem cannot be solved by anyone but a trained technician.
It will liklely requires one of the following repairs
1) new motherboard
2) new CPU
3) New CPU fan
4) new ATX power supply
This is my honest opinion after 100+ PM repairs personally.
best of luck,
Sagacious1
Aug 07, 2009 | Enlight 17IN LCD PC SILVER/CHARCOAL W/...
Sudden shutdown
What you have not indicated is whether it shuts down or restarts. If the laptop restarts then it is possible that the processor is a celeron and there is a problem of a overheating. If you are sure about all software issues be alright, I suppose you get a new fan. At times after a fan has gone weak, regardless of the contacts it has with the processor, it will still not cool; but it also be good to check the processor temperature if its goes over 60 degrees. good luck.
Aug 27, 2007 | Computers & Internet
Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX Logo
64 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
