Question about HP PSC 1210v All-In-One InkJet Printer
Hp 1210 wont print
Has ink. paper run thru,but it is blank.
    Scholar:
  • 73 Answers
Disconnect the USB cable > click on start > Run > In the run box type services.msc and press OK.
> It will open services window > right click on print spool er > click on start.
Now connect the USB cable and try to print.
Posted on Sep 16, 2008
Printer sounds like it is printing but paper is blank when done
gabriel, have you tried to 1. clean and 2 allignment of cartridges using the tool function.?
Mar 24, 2014 | HP F4480 All-In-One Printer
Printer functions fine, but nothing is printed on paper
are these new carts? or have they been sitting around long before you installed them?
Printer will not print anything..the paper runs thru the machine and kicks it out totally blank have inserted new cartridges new printer send by kodak never used
It's time to take the printer to a qualified technician.
Tell him/her that you have just replaced *ALL* the ink-cartridges,
and pay him/her to troubleshoot.
Jan 02, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Canon BJC 4400 won't put ink on the paper
You need a new printhead, BC-21E, they wear out and plug with ink and the only repair is to replace the printhead.
Sep 16, 2009 | Canon BJC 4400 InkJet Printer
Makes all sounds like printing from computer command, but paper comes out blank. Sufficient ink in all cartridges.
Try cleaning your inkjet ports as per your owners manuel. At times ink may dry up in the port clogging it so no ink can get thru when printing.
Aug 31, 2009 | Office Equipment & Supplies
Printer will not print anything. Ink levels are
If it has been longer than 3 or 4 weeks since anything last printed, the problem may be clogged print heads. Run thru several cleaning cycles and see if anything begins to appear on the paper. If not, changing the ink cartridges may solve the problem. If it's been quite a long time since last printing, you may need new (and expensive) printheads. If that's the case, replacing the printer would be more cost effective. Sorry for the bad news.
Aug 13, 2009 | Epson Stylus C88 InkJet Photo Printer
Black ink smears everything.
you may have to clean the print head. since the jam cause the smear, and there still have some ink left on the print head.
you wouldn't get aclean copy till all of the ink trace are gone.
May 20, 2009 | Canon Office Equipment & Supplies
Ink casette error
If you just put new cartridges in the printer, check to make sure you removed all of the protective plastic wrap that may be required to remove prior to printing.
Also, check the cartridges by removing and replacing each one. make sure there is no obstruction, or torn papers, that may cause a jam or other problems.
Also, after verifying all that. Use the printer utilities to run a test. Hopefully that should fix or clarify if there is any other problem.
Hope that helps..
~enov8
Mar 07, 2009 | Canon SELPHY CP760 PHOTO Thermal PRINTER
Leaking black ink on printed pages
Hi, please attempt to run a numerous blank paper through the printer. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains or streaks are still present, the printer may need service.
Tirzo
Jun 12, 2008 | Epson Stylus CX7800 All-In-One InkJet...
HP PSC 1210v All-In-One InkJet Printer Logo
Ben Johnson
