Question about Mitsubishi WS-65809 65" Rear Projection Television
Mitsubishi WS-65809 Dim Lamp
My picture is very blue. I took the back off, the blue lamp is very bright, the green is less bright, the red lamp doesn't even project color onto my hand holding it over the lamp. If I look down into the lamp I see it is illuminated though.
  • cantseeathin Sep 17, 2008
    Thanks BIG IRISH, I am somewhat handy so I'll give it a try. What's a PCB though? And is there a way you can determine that coolant has leaked out and if so, what would you need to replace?
  • 927 Answers
Good Day, cantseewhat;
It sounds like your TV has a problem. It could be and most likely be CRT Coolant on the circuit boards. If you handy, then clean PCB's with acetone on areas which fluid appear. If not handy call aN Authorized Sevice Center and have them give you a written estimate B4 repairs. Cost $450.00 to 650.00 depending on your location. Good Luck, big IRISH.
Posted on Sep 16, 2008
My Mitsubishi WS-65809 turns on and then off after about a miniute, the lamp light turns red
I think some confusion here, The model indicated is a WS series set does not use a lamp but has three picture tubes and the power light should be green on this model (ie no lamp light).
Want to try this again?
Dec 12, 2012 | JVC HD-61FH96 61" Rear Projection HDTV
I have a Mitsubishi WS-65809 that I am having convergence problems with. The Red and Blue appear fine but the Green is the problem. The Green bows down on the bottom and up on the top. I have replaced the...
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 14, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Convergence is off - Blue and Red are fine Green will not line up
On most units, the Green is constant and the Red and Blue are adjustable. Here are 2 links on how to manually adjust the convergence. There is a menu option using the remote control. Once there, you will find step by step procedure on how to adjust the convergence. Hope this helps answer your question. All the best!
Greg
http://www.fixyourowntv.com/menumitsubishi.php
http://www.ehow.com/how_2034880_perform-convergence--tv.html
May 23, 2009 | Mitsubishi WS-65809 65" Rear Projection...
No Red, can't adjust Red convergence, Blue works fine
looks like the red "bulb" has blown.
you need to replace but can be expensive.
Apr 28, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi lamps
This set does have a lamp, it utilizes 3 picture tubes (red, green, blue) The tubes are not available as new any longer. It is recommended to replace all 3 after the reaches 5yrs of age because a new tube will over drive the others in brightness but it is possible to only replace the defective one. You can try Tritronics at 800-638-3328 for rebuilds.
Nov 11, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Blurred Picture Mitsubishi WS-65809 65"
the convergence IC's will most likely need to be replaced as well as a resistor or two
electech
Oct 29, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Rear projection - only blue lamp works, after set was moved
since you moved it i would look for a loose connection or loose board and loose plugs
Dec 22, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65857 RPTV: Picture turns Red and Blue
i am having the same problem with my ws-65857. Did you get yours resolved?
Glenn
Oct 06, 2007 | Mitsubishi WS-65857 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
154 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
