Question about Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony Trinitron XBR, Stand By Mode?
I have a Sony Triniton, I think it is the 36in model, and it will not turn on. When you go to turn it on it makes the sound like it is going to come on , but it does not. I will wait a while sometimes and try again, and it will turn on. There is a red blinking light that indicated stand by, and will blnk for 6 or 7 times. Do you have any ideas on this problem? Thanks I have a 36 inch XBR - 6 years old. My 2 year old son kept turning it on and off and now the TV won't turn on. I tried the other day and after about 100 tries or so with the on/off switch, it turned on - my luck I guess.
  • azsweeneys Sep 27, 2008
    same thing! it's killin us because a two year old FRIEND was visiting us and kept turning it on and off...until mom finally stopped him...and it was broken! sometimes we can get it to come on, but now it has been days and we fear that our luck has run out and now must repair it or purchase another. It seems that a lot of people have this same problem with this same model; is there anything that we can do as consumers? Mine will blink 4 times sometimes, then it will blink 7 times. our tv outside is 15 years old, weathers the elements, and still works without a hitch...what the heck?!
  • 4,234 Answers
The 6 or 7 blinks usually indicate a problem in the horizontal circuit. Since the TV recovered once, the problem is most likely to be a bad solder connection in that area. If you can solder, resolder any connections on the board that appear grainy or have rings. That may resolve the problem. If not, update this and we'll look elsewhere for defective parts.
Dan
Posted on Sep 16, 2008
Stand by timer sony triniton color tv Model kv-32hs420
How many times the standby button blinks before going OFF at one time switch ON?
Apr 17, 2012 | Sony FD Trinitron WEGA KV-32HS420 32" TV
MY sony trinitron XBR TV does not stay on.
what's wrong with my Sony trinitron XBR tv's timer
Apr 27, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Why does the sony triniton 40in not turn on but the power button flickers red
Is it blinking a code? * * * * * * * * * * * * This would be a 4 flash. Count them and post the flash code.
Mar 17, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
I have the Sony XBR 40in Trinitron and it won't
sounds like you have some cold solder or bad joints,power section, inspect it ,with the back off, but be carefull.........i had one that did that...bad connection in solder joint...had to resolder,if you have to resolder,make sure it is unpluged.hope this helped....
Feb 23, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Stand By timer light continues to blink on Sony Triniton TV
That problem comes up when one or both of the convergence IC's are burnt ... it normally has an "STK" number on it screwed onto some large aluminium heatsink ..... however if you venture to change it get back to me ... I'll try to guide you through ....
May 23, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Generically, the 6 or 7 blinks usually indicate a problem with the horizontal circuit. In order to provide accurate diagnosis and suggested solutions, the exact model number is needed. Please update this with tha number and I will post more details.
Thanks,
Dan
Mar 18, 2009 | Televison & Video
Tv does not turn on
The power supply is in the protect mode. This is most likely a scan amplifier failure. Most of the time it would be in the horizontal output section. If the CRT is shorted, or there is a failure in the vertical section, this type of error will show. When there are scan amplifier failures, sometimes the power supply is also damaged and requires service.
Jerry G.
Jun 09, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Many of the later model Sony TV?s have a built in self-diagnosis function. If the timer/standby indicator is blinking, this could be an indication of a problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it. The timing of the blinking you see would be as follows: two to nine blinks, (depending on the fault), about a third of a second apart, then a pause for 3 seconds, then the two to nine blinks about a third of a second apart again. Here is a list of the problems that might have occurred indicated by the number of blinks. The words in parentheses are those, which you will see for each of these faults on a diagnosis screen described later in this article. Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open). Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective. One blink - not used for the self-diagnosis Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505 Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly. Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits. Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board. Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive). Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
May 21, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
SONY 36 XBR SOUND BUT NO PICTURE
posible solution is adjust the screen to low.also check the trimer if it is working.check the resistor in the heater line...weng
Oct 30, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Post Storm Problem
Hope is last to dye. Be calm and contact the technician with best references or Authorized Sony Service. If you need more info please advice
Apr 12, 2007 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
781 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
