Question about Parasound TDQ-150
Parasound dr 25 receiver
I have a parasound dr 25 receiver with a fuse blowing problem. No smoke was released so I don't think much is wrong. There is a shorted/leaky 1500 mf@35v cap but a new one does not help. I need a schematic to help examine the power supply section. Any help would be appreciated.
Thanks very much.
2 Suggested Answers
Grubhead
  • 5259 Answers
SOURCE: how to fix 2 fuses on the left of the amp? the right side work well.
Fuses only blow if there is an overload somewhere. The most likely cause being a transitor that has shorted out. Easy to spot with a multi-meter on the ohms setting. As it will be liked you have touched the test leads together!
Posted on Oct 30, 2012
My str dr 520 is blowing the 6.3 fuse
You most likely have shorted output transistors that are causing the fuse to blow
Oct 01, 2014 | Audio Players & Recorders
Hazard light/turn signals out
You have a short circuit in your wiring, with the hazard switch
in the "off" position can you insert the 25 amp fuse ?
If so them you have a short circuit before the switch.
Dec 20, 2013 | Cars & Trucks
How to fix 2 fuses on the left of the amp? the right side work well.
Aug 21, 2012 | Parasound HCA-1000A 2-Channel Amplifier
My kenwood reciever kr-a4070 keeps blowing a fuse
have you tried a different outlet? something my be wrong internally
Jul 31, 2012 | Kenwood Audio Players & Recorders
I have a parasound 5250 5 channel amp. Channel one is not working. Is there a fuse?
hi, there is no fuse on amplifier output only power supply, the problem is some parts of electronic that drives into audio output of the amplifier maybe are shorted like transistors, diode or amplifier Ic's. bring it to a nearest service center to check it. or if you have a knowledge in technical yo can used multi tester to check it. Note: unplugged it first before you open the cover to check it. thanks
Mar 28, 2011 | Parasound 5250 5-Channel Amplifier
I have a Sony STR DB930. Something happend and it
The fuse blowing is a symptom of something seriously shorted internally. What preceded the initial problem? Smoke is bad. Fire would be soon to follow without the fuse blowing. Take it to a tech.
Feb 08, 2010 | Sony STR-DB930 Receiver
JVC RX-318 keeps blowing fuses
could be several things, speaker wires touching,shorted output transistors, a shorted rectifier diode,bad filter caps in the power supply,those are the most common
Jan 06, 2009 | JVC RX-318 Receiver
Blown fuses
If the fuses only blow after the remote voltage is applied, the output transistors are likely shorted.
According to the owner's manual, the amp should have two 20 amp fuses.
Manual
Oct 15, 2007 | AudioBahn A1801T Car Audio Amplifier
My tv power does not come on
When a fuse blows out thats an indication that theres a short in the set and the fuse is installed there to prevent a fire fom happening in the set. unless you know the HI Voltage safty issues with a tv set there are no user serviceable parts inside these sets and these tvs should only be worked on by trained service personel! The problem that occouring here could be a shorted or leaky bridge rectifier, a shorted and or a bad horizontal output transistor as well as the flyback transistor and the trsnsformer, or a bad componet in the power supply.. Good Luck
Jun 23, 2006 | Sylvania 6427TE 27" TV
Parasound TDQ-150 Logo
242 people viewed this question
Top Parasound Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Parasound Audio Player and Recorder Expert? Answer questions, earn points and help others
