Question about Epson Stylus CX4200 All-In-One InkJet Printer
Paper feeder problems
Originally paper would crinkle just a mite on top of page just in about an inch or two. Then all of a sudden it starter crinkling the entire sheet of paper. got most of paper out but a couple tiny pieces still lodged. Can it be remedied?
  • Anonymous Nov 30, 2008
    Paper feeder is not allowing the paper to go through all the way and is making the paper jam and crinckle just at the top
    Genius:
  • 1,550 Answers
It is easy to remove the tiny piece of paper either by blowing air into printer or you can remove the roller to find where the paper is stuck so that you can find it and remove it .
If you need schematic diagram for your printer to remove the paper let me know .
Thanks for using Fixya .
SAM ANDERSON
Posted on Sep 16, 2008
Fix Paper crinkling on the left of each page starting about half way down?
Crinkling paper is usually due to either an obstruction in the paper path or a bad fuser, which is the part of the printer that heats the toner so it melts to the page. It is located at the top of this printer. It can be a little challenging to see the fuser on this model, but if you look close you should be able to determine if the fuser is bad. You might also have a bad transfer belt, inspect it closely on the side the has the crinkle.
Feb 28, 2015 | HP Color LaserJet 2600n Printer
At random times, when a user prints, a document, pdf, picture ect.., it's slanted. It also happens when a user scans to themselves. What can cause this to happen?
There mite be something in the path of the paper which the paper hits and so it is slanted have you tried scanning on the big glass instead of thru the document feeder does it happen then? Now the printing is something else are you talking about copying or printing. If print I would check the paper draws ensure the guide are snug up against the paper. Do you internal prints slant such as the meter count print out or the fax info reports. or the demo page? If the problem is coping then place the original on the big glass and see if the slant There are small mylar guides though out the document feeder if some one pulled the original document out in the wrong direction they mite have flipped on of them causing a corner of the paper to hit one slanting the original ALWAYS pull the original out in the same direction as the flow of the document. Try sticking a business card down thru the way the paper flows you mite be able to reset the offending mylar.
Jul 22, 2014 | Konica Minolta bizhub C250 All-In-One...
Document feeder pulls multiple pages
Sir/Mam,
Mite want to have the rollers cleaned. use a damp rag and soap and water. The separation pad mite need replacement. that's the device below the paper.in the document feeder. where the paper goes in.
Feb 24, 2014 | Konica Minolta Bizhub C253 With Document...
When feeding the paper into the printer, it gets sucked into the right side, jamming the printer and crinkling the paper. what does this mean?
Hi
kindly this problem caused because of problem in feeder rubber ...
please check that is run correctly and there's nothing jammed in printer clips or small peace of papers
Apr 25, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Paper Jam whilst doing a multi page scan
The rollers that pull the paper through could need a cleaning. With general usage these parts do get worn down. By having your printer cleaned by certified technician it would resolve this problem.
May 28, 2010 | Brother MFC-260C All-In-One InkJet Printer
Printer starts and paper goes in but starts to
hi,
it may be due to the moisture in paper. try new paper bundle .
if problem still continue this problem is due to the feeder assembly problem. clean the roller. then check it for allignment.
Aug 21, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Paper is jamming
IS this the document feeder section where the orginals is placed, mite check for a staple, paper clip, torn paper left over or a mylar mite have flipped.take a business card and stick it in the paper path you mite be able push the mylar back out. maybe some tape got in there or a 3m sticket.
Aug 13, 2009 | Sharp Office Equipment & Supplies
HP Laserjet 4M makes accordion folds in the paper before jamming
I have found that with laser printers that have an occasional "crinkle" problem that "fanning" the paper does alleviate the problem ... but it will not if there is an actual feed/hardware problem with the rollers
Mar 13, 2009 | HP LaserJet 4M Printer
Paper is printing but top edge of paper is creased and torn
It sounds like your maintenance kit is defective.
The excess oil leads me to believe that.
Jun 04, 2008 | Xerox Phaser 8200 Laser Printer
MP390 paper jam at feeder
First thing that comes to mind is that SOMETHING you (or someone) fed in, had a paper clip, staple, crinkle or some other unnatural thickness on one side of the paper - and it's stuck inside the feed mechanism.
I had the same exact thing with the feeder on my shredder. You have to get right inside you printer to find the problem.
Watever it may have been probably got stuck in the paper path so EVERYTHING from that point on gets skewed as it gets sucked into the printer and jams.
Can you get "IN" to clear the path?
Mar 30, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Epson Stylus CX4200 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
