Question about Pioneer Car Audio & Video
I have connected the power and other wires correctly and my pioneer radio will not turn on.
    Scholar:
  • 83 Answers
Is there a fuse in the inline fuse holder on the positive (red) wire?
Where have you connected the positive and negative wires?
What colour wire have you connected to the accessories position of the ignition switch, or within the fuse box?
Posted on Sep 16, 2008
2 Suggested Answers
Daveatwhips
  • 492 Answers
SOURCE: 2005 chevy cavalier after market
No, make sure the vehicle key is in the aux or on position. If this still doesn't work, recheck the wiring. Also, make sure you have a good ground.
Posted on Sep 03, 2011
ON A PIONEER CAR UNIT MODEL AVHP49000DVD , I BOUGHT IT USED , THEN HAD TO BUY A POWER PLUG FROM PIONEER WITH A WIRING DIAGRAM , PUT IT IN MY 2006 GMC TRUCK WITH A FACTORY WIRING ADAPTER IT WILL NOT COME...
You will need to connect the pioneer unit to a switched ignition wire from the ignition switch. The 2006 GM factory radio only has a constant B+ (orange wire) and ground (black wire). The factory radio turns on when the Body Control Module (BCM) sends the radio a turn-on signal (on a data communication line) when the key is turned on. Your pioneer unit won't talk to the truck's BCM, and will need you to wire a switched B+ feed to it that turns on in the ignition accessory and run positions.
Aug 23, 2013 | Pioneer Avh-p4900dvd, Avhp4900dvd,...
Pioneer DEH-2000MP Radio In 2001 Chrysler T & C
Make sure that the speaker wiring is correctly connected. Please see the instruction manual that would have come with the Pioneer deck for correct wiring instructions first. Check that first and let me know..
Jun 14, 2008 | Car Audio & Video
Pioneer DEH-3300 UB
Apparently, you have no power at the 12 volt battery/memory wire at the radio harness of the vehicle. This wire is white with blue in color.
Also, based upon your description, you have connected the battery/memory wire and the accessory wire of the radio to the 12 volt accessory (switched) wire of the vehicle. This wire is white with red in color.
Check the radio/ stereo fuse of the car. You may have blown the fuse during your installation.
You have no memory at the radio because when you turn off the key, you lose all power to the radio.
Also, I mentioned the wire colors just in case you used an aftermarket radio wiring harness. Make sure that the yellow from the Pioneer unit is going to the battery power source and, the red of the Pioneer is going to the switched power source.
Sep 12, 2012 | Pioneer Car Audio & Video
How do i connect Pioneer DEH-P4700MP at home
If you are looking to connect this radio at home, you will first need some kind of 12V DC power supply with an operating range anywhere between 9-16V. You can purchase these online or at most electronics retailers (Radio Shack, Fry's Electronics, etc.). Simply connect the constant memory power wire (yellow) and switched accessory power wire (red) from the Pioneer's wiring harness to the "+" terminal on the power supply and the ground (black) wire of the Pioneer to the "-" terminal on the power supply. Make sure to have at least one speaker connected to the speaker output leads of the Pioneer for sound. The speaker connections are as follows: Front Left + (white) FL - (white/black stripe), F Right + (gray) FR - (gray/black), Rear L + (green) RL - (green/black) RR + (violet) RR - (violet/black). And that's it! Sound at home with your Pioneer radio!
I hope this information was helpful.
Aug 18, 2011 | Pioneer DEH-P4700MP CD Player
Everytime i start my engine none of my radio stations are stored. and the angle doesnt go where i left it before also the screen doesnt closed when i turn the car off.. please help!
The constant power wire either wasn't connected, has come loose, or was connected incorrectly - as in connected to ignition instead of battery power. Check your red and yellow wires to insure they're connected correctly.
Jun 25, 2011 | Pioneer AVH-P5700DVD Car DVD Player
Preset memory not working on pioneer DEH 1700 radio
You must connect the constant hot wire (or there is a fuse blown somewhere).... it should either be orange or yellow at the rear of the pioneer radio ... it should be connected to a wire that recieves power even when the key is off ... that wire will depend on the car itself ... if you used a connector to plug into the factory wires (a good idea) that connecter should have a yellow wire that would supply a constant "hot" for your pioneer, if it doesn't there should be a fuse blown in the car fuse box.
Apr 06, 2009 | Pioneer DEH-1700 CD Player
No sound from speakers
did you check to make sure your vehicle didnt come with a factory amp, if it has one is it turning on? or did you remember to disconnect the negative battery cable while installing your radio, i know thats a dumb question, once i was installing a pioneer a barely crossed a couple wires and fried the radio, the radio itself worked fine and all the features etc, but it never did play sound again. i always disconnect the power now!!
Dec 26, 2008 | Pioneer DEH-P4000UB CD Player
Old pioneer GM120 amp
ok first the large red is battery connection, black large is ground find good source to ground, the 0.75 is most likely the power on for the amp you should hook it up to the power antenna wire on the radio. this will turn on the amp when the radio is turned on. the grey green and black are prob speaker hook ups input. the four wires are speaker outs, the red wire might be power for cd changer test it to see if it puts out power when amp is on.
Dec 18, 2007 | Pioneer GM-5000T Car Audio Amplifier
Pioneer GM-7300M 800 Watt amp will not power on
This may have a different type of triggered turn on wire. On some of the older Pioneer amps (and maybe some new ones) the trigger wire would SUPPLY B+ TO THE RADIO and when the radio was switched on the amp would sense a current draw on that wire and would then switch on. Unlike most common amps which sense the presence of B+ on the trigger wire supplied by the radio and then turn on. Look in your owners manual to see kind of turn on system you have. If you don't have an owners manual then perhaps you can download one from Pioneer support. good luck
Aug 23, 2007 | Pioneer GM-7200M Car Audio Amplifier
Wiring Installation - Satellite Radio
The wire that runs along with the P-bus cable connects to constant power; the other wire needs to be grounded.
Jan 08, 2007 | Pioneer GEX-P910XM Satellite Radio...
Car Audio & Video Logo
35 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
