Question about Refrigerators
Refrigerator and freezer not cooling enough. Fan stopped working
  • elviejevo Sep 16, 2008
    i have a refrigerator freezer no working fan is runing good
  • Ron Freeman Mar 02, 2009
    fan was noisy then stopped turning. It is hot and the blades are difficult to spin by hand. Also between the doors it is VERY hot, as if the defrost heater is on all the time. This frig. has been a BIG problem due to bad design and materials..
  • 126 Answers
YOU NEED TO REPLACE THE FAN IF ITS NOT WORKING AND DEFROST THE APPLIANCE BEFORE SWITCHING ON.GOODLUCK.MOHAMED
Posted on Sep 16, 2008
Fan is runing good
4 Suggested Answers
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
woodchuck789
  • 4070 Answers
SOURCE: kenmore refrigerator stop cooling but fan working
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Posted on Apr 06, 2010
SOURCE: refrigerator not cooling freezer not cold
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
Is the refrigerator completely dead? If so, see “It's stopped completely.”
Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
The compressor
The Thermostat
The overload, relay, or capacitor
The defrost timer
The condenser fan motor
Cooling is poor
For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
The defrost timer
The defrost thermostat (also called the bi-metal switch)
The defrost heater
to check these components .... please refer to my solution in the below link....
http://www.fixya.com/support/t4189238-defroster_not_working_checked_defrost
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
If I've been of Help to you... kindly take a moment to rate this solution.
Posted on Sep 10, 2010
Samsung refrigerator has 21 E code flashing
Freezer fan error. Most likely the fan in your freezer has stopped working completely
Jul 05, 2016 | Samsung RF260BEAESR 25.5 cu. ft. French...
Freezer doesn't cool to 0 even though it's set at -5
There is a fan that blows air past the coils in the freezer. Either the fan is not working or the coils are blocked with ice. Sometime ice stops the fan from turning. listen for the fan spinning by turning the thermostat down. Defrost the coils and fan and see if the frig returns to normal. Sometimes the drain tube is clogged causing ice buildup.
Feb 13, 2014 | Whirlpool GB2SHKXL Bottom Freezer...
Top freezer works but main frig does not
The way a refrigerator / freezer works is a single cooling coil in the freezer controlled with a thermostat. There is a fan that blows cold air down into the refrigerator section. There is another control that is just a vent control that changes the size of the opening for air flow. if the fan fails you don't get good cooling in the refrigerator section or if the defrost is not working correctly ice will build up and also stop the flow of air to the refrigerator. You should be able to hear the fan working inside the freezer. Replacing a fan motor is much simpler than troubleshooting an icing problem. There are several components that can cause defrost to not work. Bad temp cutoff switch, defrost timer or heater element could be causing that problem. With the unit unplugged and heater element disconnected you can use an ohm meter to measure resistance of the heater, should measure some resistance. Same with cutoff you should measure resistance when cold and none when above cutoff temp. Room temp is well above cutoff and use ice water to see if it closes.
Dec 13, 2013 | Frigidaire FRT21S6A Top Freezer...
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
Freezer not cooling, fan blowing, fridge also not
If there is no frost , on the inside rear freezer wall ,
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
If there is frost , reply back with complete model number .
Nov 08, 2009 | GE PSS25MGN Side by Side Refrigerator
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Model number ARB2217CW Amana Refrigerator Bottom Freezer. The freezer is working fine but the fridge has stopped cooling. No strange noises, no frost, no water leaking--just not cooling at all.
I would check the circulating fan. This problem is very hard to diagnose because the fan spins but not fast enough to circulate the chilled air thru the freezer and the frig.
Aug 01, 2009 | Refrigerators
Refrigerators Logo
137 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
