Question about HP LaserJet 1022 Printer
About n/w printer
How to put the printer in my lan for all the users through ip addresss
If you have the network enabled 1022 you need to find out it's current IP address. To do this press & hold the Go button on the top of the printer (the large button) for 5 - 10 seconds or until the printer starts to print. This prints out the configuration page.
The printer is set to get an IP address via DHCP from the factory, but once you have it's IP address you need to give it a static IP address. You can do this by typing the IP address into a web browser & go to the network tab. choose an IP address that has not been allocated already & apply the changes.
You will need to type the new IP address into the browser if you want access to change further settings.
You can then add the printer using the new static IP address.
Posted on Oct 03, 2008
I have a D-link DGS-1005G. I have two computers connected and a printer. The D-Link is also connected via LAN. I can obtain internet connection to each computer with wireless and the printer will not...
Hi, you have to set up your printer as a device that can be communicated in your LAN by the two PCs.
To set up your printer properly in the LAN, you need to assign a fixed IP to this printer such that whenever it is switch on again, both PC still communicate to this printer without changing the new IP assigned to this printer.
You need to set up this fixed IP properly in your DLink router. For guidance please check this in your user manual of the Dlink. Please let me know any problem you may have again in future.
Aug 10, 2011 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
Hi there, I am using Window xp on my desktop and window 7 on my laptop. Lan card on desktop is quantum lan card QHM8100R3D. Problem: I have Belkin F5D7234-4 Router and when i tried to connect...
Verify that you haven't manually set the IP address of the desktop machine to an IP address that conflicts with another device on your network.
If this is the case, change the network settings to use Automatic or DHCP IP address assignment.
If this doesn't fix the issue, I suggest trying a different network card than the QHM8100R3D to see if that addresses the issue.
Dec 20, 2010 | Belkin F5D7234-4 Router
What settings should i configure for networking?
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi .Enable DHCP in router. If you want to create network with router then connect ethernet cable from computer to router or put switch between router and computer. Then set tcp- ip property of lan to ip get automatic so it will get ip from router. Then o Let me know if you need further assistance. Thanks for using FixYa.
Oct 12, 2010 | Computers & Internet
Up wirelessly with my home network.My printer is showing as offline on my computer, how can i get it back online. I have it set
The BRAdmin Professional utility for Windows® is designed to manage your Brother network connected devices such as network-ready Multifunction devices and /or network-ready printers in a Local Area Network (LAN) environment. For more information on BRAdmin Professional, visit us at http://solutions.brother.com.
Installing the BRAdmin Professional configuration utility
1 Put the supplied CD-ROM into your CD-ROM drive. The opening screen will appear automatically. Follow the on-screen instructions.
2 Click Install Other Drivers or Utilities on the menu screen.
3 Click BRAdmin Professional and follow the on-screen instructions.
Setting your IP address, Subnet Mask and Gateway using BRAdmin Professional
2 Click Devices, then Search Active Devices. BRAdmin searches for new devices automatically.
3 Double-click the new device.
4 Enter the IP Address, Subnet Mask and Gateway, and then click OK.
5 The address information will be saved to the machine.
You can use the BRAdmin Professional utility to set a password. (See the Network User’s Guide on the CD-ROM.)
Start BRAdmin Professional, and choose TCP/IP.
Note
49
For Network Users
BRAdmin Light configuration utility (For Mac OS® X users)
The Brother BRAdmin Light software is a JavaTM application that is designed for the Apple Mac OS® X environment. It supports some of the features of the Windows BRAdmin Professional software. For example, using the BRAdmin Light software, you can change some network settings on Brother’s network ready printers and multifunction devices. The BRAdmin Light software will be installed automatically when you install the MFL-Pro Suite. Please refer to installing the driver and software in this Quick Setup Guide if you have not yet installed the MFL-Pro Suite. For more information on BRAdmin Light, visit us at http://solutions.brother.com.
Setting your IP address, Subnet Mask and Gateway using BRAdmin Light
If you have a DHCP/BOOTP/RARP server in your network, you don’t have to do the following operation. The print server will automatically obtain its own IP address. Make sure that version 1.4.1_07 or later of JavaTM client software is installed on your computer.
1 Double-click the Macintosh HD icon on your desktop.
2 Choose Library, Printers, Brother and then Utilities.
3 Double-click the BRAdmin Light.jar file. Run the BRAdmin Light software. BRAdmin Light searches for new devices automatically.
4 Double-click the new device.
5 Enter the IP Address, Subnet Mask and Gateway, and then click OK.
6 The address information will be saved to the machine.
Note
50
For Network Users
How to set the machine’s network settings to wireless
Restoring the network settings to factory default
LAN or wired LAN
To connect your Brother machine to a wireless or wired network you must configure the machine from the machine’s control panel for the network type you are using.
For wireless LAN On your machine, press Menu. Press a or b to choose LAN and press OK. Press a or b to choose Network I/F and press OK. Press a or b to choose WLAN and press OK. The wired network interface will become inactive with this setting. Press Stop/Exit.
It will take about a minute for the LAN menu on the LCD to become available again.
For wired LAN On your machine, press Menu. Press a or b to choose LAN and press OK. Press a or b to choose Network I/F and press OK. Press a or b to choose Wired LAN and press OK. The wireless network interface will become inactive with this setting. Press Stop/Exit.
To restore all network settings of the internal Print/Scan server to factory default, please follow the steps below.
1 Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
2 Press Menu. 3 Press a or b to choose LAN.
Press OK. 4 Press a or b to choose Factory Reset.
Press OK. 5 Press 1 to select Yes. 6 Press 1 to select Reboot.
7 The machine will restart, re-connect cables once this is complete.
Apr 29, 2010 | Brother MFC-665CW All-In-One InkJet...
My wireless lan button is in the on position, however, the computer will not connect with my router. Is there another function that needs to be turned on for the computer to recognize a network?
If you have trouble then you can talk to you ISP to help reestablish your modem connection and functions to the internet,thats what you already paid for by connecting with their service
no function ??? no payment ??? simple
Networking is lots of fun,
Firstly You have to be logged in as an Administrator
but before it will work the machine needs to have the same comon group ip settings for the function to work,
run your network wizard to establish this and follow the prompts and at the end of the wizard the units will see each other
the router ip address may be set to 192.168.0.1
and every other device may have addresss between
192.168.0.2 thru to 200 but not the router address which is dedicated to the router from manufacture,
Also the subnet mask settings 255.255.255.0 will allow access to each device on your network ie printers and other computers too (providing you give them permission to be on your network)
to find your ip address you have to go into the adaptor setting then properties when you set up the connection to your router.
or
you can use CMD prompt to find out all your IP settings on you network,ie,XP or Vista
Go to start
In the search bar (VISTA & XP)
type in CMD
This will open the adaptors settings mode
then type in IPCONFIG and press enter.
This will show you the IP address of your machine
To find out the address of the other devices on your network,
type in IPCONFIG/ALL
NOTE - depending on the type of modem ,
the settings addresss may differ slightly but the basic set procedures remain the same,
Hope this helps Misterdj
Mar 25, 2010 | Sony VAIO VGN-NR120E/S Notebook
IP Addresss of the printer is lost after the printer has been powered off and on
Need more information like make and model of printer & router to be able to explain step-by-step how-to.
Mar 12, 2010 | Office Equipment & Supplies
Dell 5100cn change ip address
Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel.
On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
Note: Make sure the use the correct IP address within the network's range.
Jul 16, 2009 | Dell 5100cn Laser Printer
HI I am trying to connect my printer via a router
You need to plug your comuter into one of the LAN Port and the Copier into another LAN port your Modem into toyr WAN port. Then you will need the IP of the router it should com along with the router Info and either be 192.168.000.1 or 192.168.0.1. add an ip spec range Isusualle use 192.168.000.120 this goes into your copier under network protacals in user tools. under the same area setup sub net mask 255.255.255.0 if you have already installed you Ricoh AP3800 Driver place the ip 192.168.000.120 again the 3rd set of numbers either .000 or .001 depending on your router. SO under start menu go to either printer and faxes or control panel right click on printer icon for ricoh AP3800 go to properties select the ports tab, Click add Port select Standared TCP ip Clickm the new port. Click next Add your IP adress for the Copier here. Click next Next window will have Generic network card so press NEXT and then Finished Close printer ports window and then click apply. This should get you printing
May 16, 2009 | Ricoh Aficio AP3800C Laser Printer
I.T Warning
Obey the rules directed by I.T
Jul 09, 2008 | HP Compaq ProLiant DL580 G3 (364636HP1)...
Configuration of LAN fax
The best solution I use is Smart Net Monitor, which is supplied with the Ricoh disks or can be downloaded from www.ricoh-usa.com . First you need to install the lan fax driver, after that then install Smartnet Monitor.
From there click start, and then control panel, then printers and faxes, then right click on the Ricoh LAN fax driver, from there click properties, click ports, then click add a port, under available ports you will see smartnet port (highlite) and then select new port, a new box will come up and then select search, the software will then make the connection and add the port. Besure to click ok and apply and then you are connected
Oct 09, 2007 | Office Equipment & Supplies
HP LaserJet 1022 Printer Logo
2,005 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
