Question about Logitech Harmony 550 Remote Control
Not functioning with my RF extender
I have the Harmony 550 and using it with the "Next Generation RF remote control extender in my bedroom. I use it with a Panasonic 50' plasma, Onkyo 605 rec., Toshiba HDDVD and Direct TV HD rec. H-200(?). for 2-3 weeks it all worked fine. then for no apparent reason the harmony would not communicate with the RF extender to operate the Direct tv receiver. it works fine with the other components. I have another HD receiver in the Fam. room so I hooked up the RF extender there and the Harmony would not communicate with that one either. I When I remove the transmitter battery out of the Harmony remote and place it in the Direct tv remote it still will not operate the Direct Tv rec. When I put the transmitter in Onkyo remote it works fine. So is it the Next generation RF extender not working with the Direct TV rec? why? thanks Don
  • Anonymous Mar 20, 2009
    I have the next generation remote extender as well and it has ruined several Onkyo remote controls that I programmed to act as universal. It works fine for a few weeks then the volume button stops working on the remote. When I take the transmitter battery out the volume button is still shot. I thought it was the Onkyo remote that was weak, but I am starting to think the transmitter must be killing the remote. I called next generation and talked to Bob who claims this is not possible and that the remote is the problem. My remotes, however, work fine until they have the transmitter in them for a few weeks. I then put the transmitter in a dish remote control, programmed it to run the Onkyo receiver, and that volume button finally quit and will not work without the transmitter now either. I was thinking of buying the harmony 550 but now with your problem will hold off. I need something to operate my equipment as it is all in an enclosed closet.
SOURCE: Need help with harmony 520 remote
1. Remove batteries
2. Hold "2" button down.
3. While holding "2" button down, reinsert batteries
4. Continue to hold "2" button down until remote exits safe mode.
Posted on Feb 05, 2008
  • 16 Answers
SOURCE: Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
Posted on May 11, 2008
SOURCE: my harmony is stuck in safe mode
I had the same issue this morning so my apologies for the delay in answering you. After numerous delays and frustrations in being unable to "update" my remote i did the following. First, remove all batteries and disconnect remote from the USB cable. Check ALL buttons to ensure that none are stuck in the down position. I found that my SELECT/OK button was stuck in the "on" position. Continue to check all buttons to make sure all test fine. After doing this hold down the "Off" button while connecting the USB cable, still no batteries in the unit at this time. Hold the "Off" button down for at least 10 seconds or until the units Testing is completed. If the Harmony remote software is up, perform the Update Remote step still sans batteries. After it completes it may perform a self test again (mine did) and after it completes then insert the batteries back into the unit. Hope this helps.
Posted on Dec 26, 2008
  • 22 Answers
SOURCE: Harmony 1000 in safe mode?
The harmony remotes have a built in safe mode, similar to a Windows XP computer. Usually you enter the safe mode on the harmony remotes by taking the battery out, then pressing the power off button and holding while putting the battery in. If you continue to press the power off button, the remote will display safe mode on the screen.
If you are not doing the above procedure and you are still getting the safe mode on the display of the remote, I would try to update the firmware on the remote. And if you have an RF Extender, update the firmware on it at the same time.
Hope this helps,
Posted on Dec 29, 2008
  • 3 Answers
SOURCE: need manual for my logitech harmony 520
Go to
Posted on Jan 07, 2009
Logitech Harmony remote having trouble changing the channel
Harmony remotes use IR commands, so you will always have to have line of sight for it to work.
However, if you are using the RF extender, ensure that the device you are using to change channels is assigned to the extender, and that the extender is properly paired.
Feb 20, 2010 | Logitech Harmony Remote Control
Harmony 550 Manual Download
Download Logitech Harmony 550 Remote Control Manual
Have you misplaced your Logitech Harmony 550 Remote Control Owners Manual?
Would you like a digital, searchable, pdf version of the Logitech Harmony 550 Remote Control Users Guide?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
Logitech Harmony Firmware Update
Harmony Mac Software Download
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
on Apr 30, 2010 | Logitech Harmony 550 Remote Advanced...
Harmony 890 Pro will not pair with Xbox360
The RF signal is on the XBOX is used for the controllers only.
When using the Harmony 890 with a 360, you will have to use it as an IR (infrared) device. That is the only way to use a remote with the 360. If you have an extra port on your RF extender, you can place the end on the remote senor on the 360 (located under the eject button).
I set these remotes up weekly, it is a product I recommend to people all the time!
But again, the only way to setup a remote with the 360, is to use the IR port as a standard IR remote. Since the controllers run off RF, the learn function will not work, unless you already have 360 remote control to use to do the learn function.
Hope that offers some insight. This information can also be verifies at Microsoft XBOX 360's FAQ page.
Oct 21, 2009 | Logitech Harmony 890 LCD Remote Control
What is a ?????
The RF extender is a add-on device that communicates with the Harmony 1000 remote. You would actually hook up IR eyeballs to your equipment and then plug them into the RF extender. This allows you to have your equipment in a cabinet or closet and have the door shut. The Harmony 1000 sends RF signals to the RF extender and the RF extender sends that signal to the components. This way you don't have to point at the components to control their operation.
Hope this helps, if it did please indicate with vote.
Feb 14, 2009 | Logitech Harmony 1000 LCD Touchscreen...
I just bought a Harmony wireless extender but cannot get it to work. Do I have to also purchase a Harmony remote control or cannot it be used with any standard remote?
I would suspect that it would need to be used along side a Harmony remote. Get one they are great, you will not be disappointed. TigerDirect has some refurbished Harmony 720s, that's the one I have, it's the best value.
Jan 24, 2009 | Logitech Harmony RF Extender IDE / EIDE,...
Logitech harmony remote 1000 not operating CBus lighting
Is there an IR receiver (or if using the RF extender, IR eyeballs connected to device and the RF extender) that you are pointing at to control the CBus lighting? If not, there is no way to control it. The Harmony 1000 will only communicate with the RF extender through Zwave, so you can't communicate with other Zwave devices, like you can with the Harmony 890 for instance.
Hope this helps,
Dec 08, 2008 | Logitech Harmony 1000 LCD Touchscreen...
Logitech harmony 890 display is blank
this sounds like it is a hardware issue, try contacting Logitech through e-mail from the website and sending an e-mail in.
try the following before contacting them:
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
If this doesnt work, provide them with the following to make sure the process goes as smooth as possible:
The PID of the remote:
The P/N of the remote:
The PID of the RF Wireless Extender:
The P/N of the RF Wireless Extender:
Full Name:
Phone number:
Zip/Postal Code:
Please Note: The PID (Product Identification) and P/N (Part Number) for the remote can be found either on the underside of the battery cover, or at the bottom of the battery compartment (the battery might be covering it). Your PID number is a character code with a combination of letters and numbers, starting with either WL, WD, or LZ
Nov 29, 2008 | Logitech Harmony 890 LCD Remote Control
Cannot interface with harmony rf wireless extender
the One doesn't have rf capabilities, so you can't use an rf extender
Jun 08, 2008 | Logitech Harmony One Advanced Universal...
Pull the battery out and re-insert it, also update the remote firmware
Aug 12, 2007 | Logitech Harmony 890 LCD Remote Control
Logitech Harmony 550 Remote Control Logo
497 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
