Question about GE JVM1870 Microwave Oven
GE JVM1870 Spacemaker Microwave Fan Malfunctioning when Cooking
Fan runs on all speeds when you manually start it off control panel. The fan does not run automatically during the cooking cycle. We have been manually running fan when cooking last couple of days but today, the thermal fuse tripped within the microwave even with the fan started by us and running in manual. Would appreciate understanding on what is wrong with the microwave. Thanks
  • GE Master
  • 9,098 Answers
There are two different fans in this model, as with almost all over the range microwaves.
One is the hood vent exhaust fan, which you can turn on and off at will, and which should always be on when cooking on the stove top.
This fan does not automatically come on when you cook with the microwave.
The fan which should always be on (automatically) when you are microwaving is the internal magnetron cooling fan.
If the cooling fan fails, the magnetron can overheat and the thermal cutout (TCO) / thermostat will open, killing the power to the oven. Ideally, this protects the magnetron from being destroyed.
If the thermal device is a thermostat, it will reset when it cools down, and the oven will work.
If the thermal device is a true thermal fuse, it is a one-time device and if it blows, it will have to be replaced.
If your cooling fan is bad, it needs to be replaced before using the microwave.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Sep 16, 2008
Ge spacemaker xl1800 vent fan
I'm betting your base model number is JVM1860, JVM1861, JVM1870, JVM1871, JVM3660, or JVM3670.
That's the automatic louver you're having trouble with. There are micro switches in the louver assembly which tell the controller when the louver is open or closed.
If one of those switches or the louver motor fails, the louver will not work correctly.
Did your cooktop lights recently fail?
Sometimes the surge from them shorting will cause damage to the circuit board, which can be repaired.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 03, 2013 | GE Profile Spacemaker XL 1800 36"...
GE Over range microwave model JVM1443LK01 This started a couple days ago. After removeing something from the microwave and we shut the door, the fan started up. The fan will run as long as the door is...
I would check the door switches for a faulty switch. If it were condensation on the control panel. I would think it would have dried out by now unless it has damaged the control board.
Mar 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Have a ge profile spacemaker microwave model# PNM18715M155. The vent fan cmae on while cooking and it wwill not go off. I unplugged and waited 5 min. plugged it back in a the fan still came on.
most likely you have a bad thermal fuse/limit device located behind control panel... there is a small round approx. size of a quarter that has 2 wires attached to it. this device has most likely failed as it is a heat limit and for some reason either the unit got to hot and closed the limit to allow the fan to continue to run or the limit itself has failed... you will have to remove control panel to gain access.... www.sears.com then hit the parts direct link on top and enter your model number to find the part and price ... good luck to you...
Jan 27, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE jvm1653 fan quit
It is vital that the cooling fan runs, or the magnetron will be destroyed.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver XL 1650 microwave shuts off after a few seconds
this would be the digital control board that would need to be replaced
Nov 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Auto-fan turns on too often.
Normally the exhaust / vent / hood fan will come on automatically if the stove top or the bottom plate of the microwave gets too hot.
Also, there may be some settings for the auto-fan that can work like this.
Consult your manual. If you don't have it, you can download GE owner's manuals and installation instructions here.
Otherwise, the hood fan thermostat may be failing. It should be normally open when you do a continuity check.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
We even have a video on our site that shows you how to safely & easily remove the control panel assembly in less than 5 minutes so you can check out your oven.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave running although not turned on
Thought I had answered this, but this is usually caused by either a bad door switch, a loose door switch mount, or possibly a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker keeps asking for time date reset and will not operate
The power to the unit is drooping (when the heavy microwave load kicks in) causing the reset.
Try plugging it into a different outlet (whole different circuit if possible) and if that works then you have a wiring problem to the original outlet.
Jan 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 - Automatic Fan
Hopefully steam didn't get up into it. Apparently it was the heat, but it may be miswired or have a defect in the hood thermostat or on the controller. I always recommend using the hood fan when cooking on the stove top or in the oven but that may have been irrelevant here. I would definitely recommend calling the GE Answer Center at 1-800-626-2005 on this one. If the installation was done correctly, then an exchange may be in order. Early in the warranty, you should be very demanding!
Dec 26, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1870 Microwave Oven Logo
340 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
