Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Slow espresso dispensed, occasional water light, descaling option does not work
I have read all these solutions and i'm still unsure what is wrong with my italia. first off when i try to run the descale option it only goes for about 7 seconds then all 5 lights flash and then water light comes on. i pump the water through and it goes off. it slowly makes espresso but sometimes it stops and the water light comes on again. i have to keep priming it to make the light go off. i tried adjusting the strength of coffee and the grid but it does not make the espresso come out any faster. i think either the pump is not working properly or the machine has water scale but i can't get the descale to work...or the water sensor is just not working? not sure what to do please help.
  • 515 Answers
try to replace the flowmeter in the machine.
/Mirran
Posted on Sep 17, 2008
Why the coffee is not coming out of coffee spout?
  1. If you can get steam/water from your steam spout.
  2. Fill your tank and add descale solution.
  3. Descale according to the instruction for the unit.
  4. After descale and rise are complete refill your water tank.
  5. Your system should now work as normal.
Note: If you do not have a descale solution, run the above with just water. Remember to descale when you obtain a descale solution.
Jun 30, 2015 | DeLonghi EAM4000 Espresso Machine
Intuita coffe machine not working
Needs a service take it in let them replace the seals,If the seals go faulty this happens
Dec 29, 2013 | Coffee Makers & Espresso Machines
My Saeco Talea Giro plus is not even one month old and the descaling light was on. We have descaled twice thinking we did something wrong and the descaling light will not go off. During descaling the...
Did you often use the espresso machine for family or for business, when you often use the machine and you used water that is not filtered, you can assure it need to descale often.
Read carefully the manual and follow instruction. Did you descale it in the right amount of solution, how long and its duration?
If still persist ( the descaling light continue flashing ) then it has a defect in sensor. Since your machine is new, its under warranty. Call the dealer where you brought that and a service technician will send.
I hope I give you answer and solution idea for your unit problem.
Mar 29, 2011 | Saeco Talea Giro Espresso Machine
My Keurig does not dispense enough water for any of the settings. Is there something I an doing wrong or that I can fix. Thanks
Hello Gajaxson,
I understand that your coffee maker/Espresso machine is not putting out enough water when you are brewing. This is a common occurrence when the machine needs to be descaled.
There are many different ways to descale coffee/espresso machines and some have cycles built in that you have to add the solution and push a button. Would please post me a model I will check with and see if the manufacture has any suggestions on how to descale your machine. Also if you still have the owners manual it will show you how to descale your machine.
It is recommended that you descale your machine at-least once every six months for moderate use and once every three months for heavy use.
Thank you for choosing FixYa.com
Justin
Mar 13, 2011 | Keurig Coffee Makers & Espresso Machines
After descaling the red light will not go off . I used a full tank of water,and a fresh tank after that.My product said cleaner not descaler - does that make a difference.
Use a citric acid based descaling solution rather than a cleaning based solution.
You have to ensure the descaling function runs completely to the end. Occasionally the water tank will be empty BEFORE the descaling program has finished, in which case you should refill it and let it continue descaling.
The light wiill automatically go off once the descaling program has been fully completed.
Feb 04, 2010 | Braun Tassimo Espresso Machine/Coffee...
Gaggia Synchrony wont work after decaling
Check the thermostats on the boiler and the boiler element?
Jul 14, 2009 | Gaggia Syncrony Espresso Machine
Decalcifying method
There is an auto button on your machine the double ellipse button, hold down for 5 seconds display will read descale.
Safe Descaling method
1- Always use the right descaling products.
Descaling chemicals purchased from supermarkets may not be suitable for the machine. Use of Vinegar is prohibited by manufacturers. Please read the operating manual. Do not use Cafiza, Cleancaf or PuroCaff. These are coffee cleaners recommended for back flushing coffee machines.
2- Always dissolve the Descaling chemical in a container and pour into the water tank. Never add directly into the water tank. Crystals of chemical will slide into the filter & pump and block the water hose and restrict flow of water.
3- Do not pour solution when the tank it is on the machine. In fully automatic machines, the bean hopper is next to the water tank. The solution / water can accidentally get into the bean hopper and cause serious damage to the grinder.
4- Espresso machines have separate water passage for Hot water from steam pipe and espresso dispensing. Flush the solution from both sides, alternatively. Turn machine on, flush one cup from steam pipe and turn machine off. After a pause of 3 to 5 minutes turn machine on and make one large espresso (4-oz.). Repeat this process until all of the solution in the tank is used up.
This method is best both for semi-automatic & fully automatic espresso machines.
Using Electronic programmed method does only half the job as it flushes descaling solution only through the steam pipe. The machine must be flushed with solution from espresso side as well. Automatic descaling method should be completed by making 6 espresso with or without coffee (using pre-ground cycle when available).
5- Rinse the water tank and fill with fresh clean water. Repeat the rinsing process alternatively until four tanks of water is used up to flush the chemical out.
Caution: Do not leave the machine before completing the rinsing with clean water. The solution left inside will corrode & tarnish metallic surface.
Do not leave Chrome plated objects submerged in descaling solution for more than 10 seconds. The chrome will dissolve and leave the item permanently corroded and black.
Jun 07, 2009 | Gaggia Titanium Espresso Machine
Lines are clogged and the coffee is not coming
Use Scalekleen or other citric acid.
1-
machines.
when available).
metallic surface.
Jun 05, 2009 | Saeco VIA Venezia
How do I clean and descale my Schaerer siena 1 espresso maker. We have lost the manual.
Remove the coffee grounds container & leave it out.
Press & hold the cleaning button for approx 5 seconds, you will then see the words " Caution Hot"
Then push the cleaning button once (the one with the plus sign on it) This will start the descaling....I have a Siena-2 & I too could not figure out how to descale, I sent an email to schaerer who sent me an pdf with these instructions which are close to what I was doing. They said it sounds lie I had an older model version - They were very helpful.
remo.weber@Schaerer.com
see the guy who helped me - email above.
Jun 05, 2009 | Schaerer Siena Espresso Machine
How do I descale the saeco magic deluxe coffee machine?
Try this:
Standard descaling
Switch off the machine.
Pour a descaling product into the water tank.
Switch the machine on to the programming mode(see below). Place a large container under the steam/hot water dispensing tube and open the steam/hot water knob slowly, turning it counterclockwise.
Turn on the machine by pressing the main switch and let the descaling product flow out of the dispensing tube for approx. 1 min.
Close the knob again.
Turn off the machine with the main switch and let the solution take effect for approx. 5 minutes.
Repeat this procedure two or three times, to allow all of the descaling product in the water tank to flow out of the dispensing tube.
As soon as descaling has been carried out, rinse the tank thoroughly and fill it with fresh water.
Switch on the machine and let fresh water (approx. 2 l) flow out of the steam/hot water dispensing tube in order to rinse away residue.
The machine is now ready for operation.
When the machine is on, the warning light switches off automatically, by pressing the steam selection button for at least 5 seconds.
To enter the programming mode, turn the machine
off with the main switch.
Press steam , espresso coffee and the
main switch at the same time.
Release the buttons.
Hope this will help you.
/Mirran
Aug 16, 2008 | Saeco Magic De Luxe Espresso Machine
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
174 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
