Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Install help with broil elementin kenmorefree standing range
How to install a broil element in kenmore range model 911.9321190
  • robertcrec Oct 03, 2008
    install broil element
Install broil element
Posted on Oct 03, 2008
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
Oven elements aren't heating, Kenmore Range C970-655821
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 22, 2015 | Kenmore Ovens
Broil does not work
the broil element
Aug 05, 2014 | Kenmore Ovens
My kenmore oven model 316255311 want come on at all but the top of the stove works fine
I suspect the heating element might have burned out - does the broiler work? If "broil" works but "bake" doesn't, then replace the lower heating element.
Jul 31, 2014 | Ovens
Will the oven work without the broiler attached
You could use the oven without the broiler. It is customary that the oven will use the broil element to even out the heat in the oven for better baking but you could use if. it just may not bake evenly. There could be two things that is causing the broil element to stay energized. the control is not shutting down or there is a short to ground in the broil element. Have the broil element tested, it could just need replacing. If it is in the control that is a bigger problem.
Mar 19, 2014 | Ovens
Broiler wont light
the broil element
Mar 17, 2014 | Kenmore Ovens
Ov en will not heat up. no broiler heat or bake heat model number 790.96614407
Your symptoms point to a failure in the electronic oven control board (that acts as the thermostat for the oven in this type of range). Unplug the range and remove the upper back panel to access this component. You will likely see to burn marks on the control board. The control board will need to be replaced in this situation.
Before installing the control board, I recommend that you check the bake and broil elements. Look for damage on both elements. Remove the lower back panel (with the range still unplugged ) and check the wiring connections on both elements. A damaged or shorted bake or broil element could have caused the problem with the control board.
Hope this helps.
Shane
Mar 01, 2011 | Kenmore Ovens
Kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Oct 25, 2009 | Kenmore 30169 Electric Single Oven
Kenmore Model #790 - smooth top range
Probably not. It sounds like your broil element burned out. This just happens sometimes. If it is this , it will have visible chunks missing. Yes, It shorted with enough force to blow the main fuse. Unplug it as sometimes it can still be live and sparking when power is restored. Element is fairly cheap usually less than $50 and you can fix it yourself.
Jun 19, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Range 911.9324890
Replace recepticles for large elements. It is the part that the heating elements go into. And while you are at the appliance store, pickup a new bake element for your oven. Just unscrew element from oven wall and install new one.
Nov 16, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
75 people viewed this question
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
