Question about Toshiba Satellite 2415-S205 Notebook
Install ram when i installed ram now i get a aqua colored screen with lines going down it
  • greasergurrl Sep 16, 2008
    this happens on a restart not reboot if there is a diffrence..
    Scholar:
  • 135 Answers
Is it an upgrade of RAM? If so, remove the new RAM and test the default RAM if you still have the problem. If the problem is solved, just reseat the RAM or better yet, remove the old RAM then just put in the new RAM just to identify which causes the problem.
Hope this helps.
Posted on Sep 16, 2008
  • Christian Fernandez Sep 16, 2008
    I see. Adding a RAM or changing it might affect your videocard since it shares with your memory module.
    Try to re install your videocard driver. Go to device manager under control panel. Dropdown display adapter, uninstall the ATI or Nvidia driver in there, if you're with vista, do not put a check on delete the drivers. After Uninstall, click action on device manager, then scan for hardware changes. It should re install your display adapter. Then try to restart again.
    If it fails, go to the support site, support.toshiba.com, update your display adapter.
    Hope this helps.
Computer and monitor come on fine the screen goes white with black or colored lines in it
im only having a guess but i think it could be your ram is corrupt its known for the screen to go white when theres ram problems try taking out one of the sticks of ram and see does that sort it if not put that one back in and take out the other one if you only have one stick of ram then i would suggest bringing it to a store to get fixed it might not be any of these but its worth a try...look up youtube to see how to remove ram and dont remove it with the computer turned on and dont put it back in with the pc on either make sure its off and touch something metal before opening the pc to discharge any static...hope this helps
Dec 07, 2011 | Gateway Computers & Internet
My laptop symptoms are faded lines, fonts not crisp, various shades of the same color in the lines. I have replaced the monitor but that did not ellimnate the problem. I have a Dell Inspiron...
  1. Turn off the Computer.
  2. Hold Down the FN Key on the keyboard and press the power button, then Release both buttons.
  3. This should start your PSA Diagnostics
  4. You will see two color bar screens appear in succession, on the second color bar screen there is a message asking you if you saw the color bars. Press the N key for No to start the LCD BIST.
  5. The LCD BIST will run several full colored screens in succession with a beeping sound.
  6. Check for any lines, distortions, or abnormalities you were seeing in the Operating System here.
  7. Once the Diagnostics are finished you will see an Error message appear, this is Normal. Press the N Key to end the Diagnostics or Press the Y Key to continue the PSA Diagnostics.
  8. If no sysmptoms were displayed please continue on to the next step, if they were displayed please go to the last step.
An out of date Video Driver or BIOS can cause abnormal screen issues.
Visit the Dell Drivers and Downloads website and input your Service Tag to get updates specific to your computer.
If you need assistance in Downloading and Installing Drivers or BIOS. Click here for Installation Instructions
Click Here to Launch the Dell Drivers and Downloads Website
Dec 03, 2010 | Dell Inspiron 6000 Notebook
My screen has verticle lines and the colors are incorrect
Try your monitor on another computer (laptop or desktop), to see if the problem "follows' the monitor.
Try another monitor on your computer, to see if your computer's video-card is creating the problem.
Try a different "data" cable between your computer and your monitor, to ensure that all 3 "primary" colours are being transmitted.
Jul 21, 2010 | Dell Y4694 Dell MOTHERBOARD INSPIRON 9300
Vertical aqua colored line on the screen of my laptop
the cells inside of the lcd itself are starting to go bad which is why your seeing lines on the screen. To fix the problem you'll need to replace the lcd.
In the meantime you can hook up an external monitor and use that so you don't have to deal with lines on a bad lcd screen.
Jun 26, 2009 | Compaq Presario M2000 Notebook
Screen sizing
Your problem is that the correct video driver is not installed and therefore cannot use all the video RAM.(the XP version of the video driver won't work with Win98).
When you adjust to True color at a higher resolution it drops to a lower resolution because it has insufficent video RAM, but you will get a higher screen resolution at a 16 bit color because it requires less memory (video RAM).
Install the Win98 driver for the graphics card and then it can use the full video RAM at a higher screen resolution with 32 bit color.
May 01, 2009 | Computers & Internet
Installing RAM
you might want to try and remove the ram that you just installed and check if the problem is still the same. If it is then it's not the ram that's causing the problem. But if the problem goes away when you remove the newly added ram then you probably have a busted RAM
Sep 11, 2008 | Toshiba Satellite 2415-S205 Notebook
97 caldina
you can get something called a wiring harness from Walmart (or any place that sells car audio equipment). you plug it into the factory connection that would normally go to the back of the radio, and it has the wires labeled and color coded with what goes where. most times all you would need to do is match up the colors from the harness to the new radio you're trying to install. it makes it really easy to install after market radios, which im assuming you're trying to do.
Sep 06, 2008 | 1997 Toyota Corolla
Screen Issues
sounds like your video card is starting to fail mite need to install a new one ,need to do assp or mite loose entire system. la la linda
Jun 01, 2008 | Toshiba Portege S100-S1133 Notebook
Toshiba Satellite 2415-S205 Notebook Logo
168 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
