Whirlpool washing machine, tub is disconnected
The tub completely came loose from the machine. It started with banging against the side and looking slightly crooked. I figured it was just something weird going on. Now the tub is completely disconnected. Can this be fixed? If so... does it have to be an actual washing machine repair person?
  • 126 Answers
IT CAN BE FIXED AND ITS BEST YOU GET THE TECHNICIAN TO REPAIR IT AS RESETTING THE DRUM IS A DELICATE TASK IF YOU DONT DO IT CORRECTLY THE PROBLEM WONT GO AWAY.GOODLUCK.MOHAMED
Posted on Sep 16, 2008
My washing machine tub seems real loose. It starts banging on the sides when starting to spin. What causes that?
Hi Steve, This is usually caused by an uneven load. For instance, If you have a bath towel in with some shirts or tea towels, the bath towel absorbes more water than the tea towels, thus making an uneven load.
My wife tends to wash slippers in a pillow case with nothing else in the washer, and the drum will bang against the side.
Hope this helps
Kind regards
David
Nov 10, 2017 | Washing Machines
Drum is loose during Spin and Rinse cycle and banging against side of washer
If it is under warranty, call Whirlpool at 1-866-698-2538. If it is out of warranty, try running the washer with no clothes in it in spin cycle. If it runs fine empty, it may be that when you had clothes in it they were not balanced evenly in the tub. If it runs off balance when empty, then a spring may have broken or come off. Contact an appliance repairman.
Oct 31, 2013 | Whirlpool WTW4880AW 3.4 cu. ft. Top Load...
Inner drum of GE front load washer is very loose and is banging against the sides of the outer drum.
The rear spider shaft has broken it can be repaired. but I'm not 100% on lg units a lot of newer washers have a complete tub unit now it's all sealed in would need to see the machine with the lid off.
Dec 10, 2012 | Washing Machines
Thin twin tub loose
you will need to remove the front panel of the washer,there are 3 spring suspension rods below the tub and either one or more of these springs are disconnected from the tub or broken
Dec 07, 2012 | Whirlpool LTE6234D Top Load Stacked...
When washer goes into spin cycle it starts to tub starts to bang against side walls and shortly after error out, with an error on electronic display. Kenmore Elite Oasis
either unit is unlevel or one of the tub supports has come disconnected .... these washers have a slanted top lid so you must put level at side of washer on front and both sides and check front to back with level at side cabine seam as your leveling point
Jan 24, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
I have a loud clunking noise after my maytag empties the water, it seems to be getting worse. The model is a centennial top loader. IT is getting to be annoying. Any help will be appreciated. Thanks
Check the springs or straps that are connected to the wash tub. They keep the tub centered in the machine; if one is broken loose the tub will bang against the sides of the machine.
Sep 12, 2009 | Washing Machines
Whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Dec 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machine Suspension Problem?
smirkin, the question here is if the basket is listing against the tub or the whole tub and basket is listing. If the basket is listing and banging around it could be the drive block has worn or broken. I will attach a photo of one. If the whole tub is listing it could be a spring that broke. You can remove the front panel of the washer by pressing in on the two clips on each side of the washer top, The front panel should drop and pull out. You can see if any of the suspension sprins broke. The drive block is located under the basket. The agitator and basket have to be removed to change it out. Take a look at the attachments...Catriver..post back
Sep 07, 2006 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
104 people viewed this question
Top Washing Machines Experts
