Question about Whirlpool ED2FHEXN Side by Side Refrigerator
My refrigerator is hot
I have a whirlpool refrigerator and I just noticed today that the plastic parts of the doors are hot why may this be? and I have also noticed moisture in there. I was cleaning it yesterday and one of the light bulbs broke. I was wondering if that had to do with it?
  • 126 Answers
IM NOT UNDERSTANDING YOU PROPERLY IS THE FOOD IN THE REFRIG STAYING COLD.PLEASE GIVE MORE DETAILS ON YOUR PROBLEM AND NO THE LIGHT BULB WILL NOT CAUSE THAT.MOHAMED
Posted on Sep 16, 2008
Flap on Ice chute came off I need to put it back on. Whirlpool Refrig. With water and Ice with a flap over the ice to keep hot air from getting in.
I'm in the middle of the same problem on my own refrigerator right now. The flapper swings on a steel pin which passes through a stationary plastic tab. That plastic tab can break off, allowing the door to fall out of position. Look up into the mechanism to see if this is your problem. Whirlpool makes a modification kit, part #8201756. It's not on the original parts list, so do a web search for Whirlpool 8201756. I hope this helps.
Jul 10, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
The post between the doors of my side by side refrigerator is hot. If you open the doors and put your hand on the outside,it is hot. I cleaned the bottom of the frig last nite and noticed the cooling fan...
The fan motor needs to be replaced . Pt # W10124096 , is the part number for the condenser fan motor ( compressor cooling fan ) . It costs about $ 100.00 for the part , but is easily replaceable ( 2 or 3 screws ) .
Nov 20, 2009 | Whirlpool Refrigerators
GC5SHEXNQ02 Whirlpool 2door ref - Panel gets hot
I am not going to say the problem is normal. Normal operation those strips are placed behind the metal and inside the walls around the door seals to prevent moisture or sweating around the doors. They are usually noticed to become hot when there is a change in the control boards operation. Some brands have the hot gas from the condenser circulating around the doors. If your model has an economy switch, switch it on. I would look for any abnormal operation of the refrigerator like compressor or condenser fan stopping or ice buildup or abnormal temperatures in the fresh food compartment. If this continues I would unplug the refrigerator and open the control panel inside the fresh food section and examine both sides of the control board for signs of heat or burn marks on both sides. May not be anything to be concerned about also because this may be the first time you noticed this. But it should not be too hot to touch. Sea Breeze
Jun 23, 2009 | Refrigerators
Whirlpool GD5SHA XLTO2 problems. Last night, awoke to a sort of burnt plastic smell coming from refrigerator. Turned off ice maker and smell stopped coming out. Today, freezer was not keeping things...
sounds as if your overload relay, controlling your compressor has burnt out heres a part number that should getyou back in working order( complete with intructions pn# 8201786
Jun 15, 2009 | Whirlpool GD5SHAX Side by Side...
Gasket seal around refrigerator and freezer doors is hot.
This is likely part of the defrosting feature and if it is always hot, the defrost timer has failed and is keeping the seals hot.
The defrost timer is normally located behind the lower grillwork and many are equipped with a slotted shaft that can be turned with a flat-bladed screwdriver. The slot will also let you see if the clock motor inside is running. You would need to mark it and give it time since these things rotate only once every 12-24 hours.
May 20, 2009 | KitchenAid Refrigerators
Clicking noise coming from whirlpool refrigerator
The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Jan 18, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Refrigerator door stays open.
Sears came out and repaired my door with this same problem. It was a pretty easy fix. There is a small black part that the door rests on. It just was worn out. The repairman simply unscrewed the door from the top of the refrigerator. He lift the door off. The door normally rest on a black round circular plastic part about 1 in in diameter. It has a small plastic piece sticking up about 1/2 inch that the door rests on. This piece was worn on bottom. I have the Sears invoice and I bought a replacement bin for the door and I don't know which item is for the black plastic piece. Here are both part numbers so call Sears and order the correct part
CAM-DOOR 46 106 4318165 1 or $14.83
SUB TRIM-DOO 46 106 2156022K 1 $12.48
It took the Sear's guy about 10 minutes to repair. So save yourself $200 and do it yourself.
There is a picture of the part in the Whirlpool Manual, under Door Removal, look at the bottom hinge.
Email me if you need another picture.
lcbeaty2004@yahoo.com
Nov 12, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a side beside whirlpool refrigerator/freezer. today I noticed the strip between the frig and freezer was very hot and coil under frig are almost too hot to touch. It has been this way since about...
no danger of fire, they(Whirlpool) run a copper heat tube through the center mullion of frig, to cut down on amount of undesirable condensation that may build up between doors, reason for extra heat can be from leaving door open too long, perhaps the coils under the frig need to be vacuumed,
Oct 12, 2008 | Whirlpool Refrigerators
Whirlpool Side by Side Refridgerator
If the mullion heater around the doors is hot to the touch the inside temperatures are not being maintained. They should be warm but not hot. This usually indicates a problem in the internal temperatures. Check the back wall of the freezer section for frost buildup. Your defrost system may not be working and it had not gotten to the point of complete failure as far as you noticing the temperature differences yet.
Jun 15, 2008 | Whirlpool ED2FHSS Side by Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
65 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
