Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool Gold Conquest IceMaker
My icemaker stopped making ice, but the water dispenser is working. I have changed the filter. There is a red blinking light on.
  • sandals2004 Sep 16, 2008
    What does the water valve look like?
  • 126 Answers
HAVE YOU CHECKED YOUR WATER VALVE LOCATED AT THE BACK BOTTOM RIGHT OF THE APPLIANCE THAT MIGHT BE THE CAUSE OF THE ICE MAKER NOT WORKING.LET ME KNOW IF YOU REQUIR FURTHER ASSISTANCE.GOODLUCK.MOHAMED
Posted on Sep 16, 2008
  • MOHAMED UZAIL ESSACK
    MOHAMED UZAIL ESSACK Sep 17, 2008
    THE BEST WAY FOR YOU TO LOCATE THE WATER VALVE IS TO LOOK AT THE BOTTOM TEGHT OF THE FREDGE IT WILL HACE TO WHITE PLASTIC PIPES ATTACHED TO IT AND YOUR MAIN WATER PIPE FROM YOUR TAP ON THE OTHER SIDE IT SHOULS HAVE A BLUE AND A RED VALVE IN TOP OF IT ALSO
Will not make ice!
water is not going to icemaker, I changed the inlet water valve, I check the tubes everything clear, water is coming to dispenser,want can I try..
Aug 30, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
My side-by-side Whirlpool Gold is not making ice.
could be bad solinoid, only letting water to dispencer, u could switch sol leades to see if water goes to ice maker, but check ti make icemaker is on first
May 29, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker will not make ice
If you have water sitting in the trays and no action is happening, then i suggest replacing the ice maker complete as these spares are pricey and take a while to get to you , (In the hope that they are correct). On some units there is a small test button. If you have one, push or switch it to activate icemaker. Often this resetting brings the ice maker back on line.
May 23, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker on side by side not working
Change out your ice maker. If your icemaker has worked for 6 years, you got lucky! They normally have to be changed out every couple of years. We have an unlimited inventory of appliance parts for Whirlpool, so please call us to send your parts out and we'll get them out right away!
Sep 17, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker makes ice, but doesn't dump it.
If you have a steady blinking light when you open the door then the sensor is working. I these cases the problem is usually in a bad motor or thermostat in the icemaker. If you need I can give you instructions on how to change these parts.
Nov 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice Dispenser
hi there,
check to see if you have a leak either on the inside or the outside of the freezer door.
check your icemaker line and see if anything is freezing up.
from the sounds of it, something is stopping the water flow into the icemaker.
Sep 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker not working
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Jun 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker not making ice
The same thing happened to my Whirlpool gold. Defrost it for 24 hours and the ice maker now works.
Apr 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
1,654 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
