Question about Refrigerators
OSTER OR4505G3B
I BROKE THE GALLON DOOR STORAGE BIN. WHERE CAN I BUY ONE?
  • 93 Answers
Try Sears Parts Direct (Sears.com). You will need the model number.
Posted on Sep 16, 2008
Part number for frigidaire refrigerator door bin for GLMS66EJSBO
Good Afternoon Friend,
I understand you are looking for the part number for the refrigerator door bin on your Frigidaire refrigerator, model# GLHS66EJSB0. There are two different bins. There is the standard half bin which is part# 240323002. There is also the gallon door bin which is part# 241808205. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
How to clean a scotsman icemaker
WHAT SHOULDN'T BE DONE.
Never keep anything in the ice storage bin that is not ice; objects like wine or beer bottles are not only unsanitary, but the labels may slip off and plug up the drain. Never allow the machine to operate without regular. The machine will last longer if it is kept clean. Regular cleaning should happen at least once per year,and preferable twice. Some water conditions will dictate even more frequent cleaning of the ice making section, and some carpets or pets will dictate more frequent cleaning or the condenser.
WHAT SHOULD BE KEPT CLEAN?
There are 5 things to keep clean:
1. The outside cabinet & door.
2. The ice storage bin.
3. The condenser.
4. The ice making system.
5. The ice scoop.
HOW TO CLEAN THE CABINET.
Wipe off any spills on the surface of the door and handle as they occur. If anything spilled on the door of gasket dries onto the surface, wash with soap and warm water to remove.
HOW TO CLEAN THE ICE STORAGE BIN.
The ice storage bin should be sanitized occasionally. It is usually convenient to sanitize the bin after the ice making system has been cleaned, and the storage bin empty. A sanitizing solution can be made of 1 ounce of household bleach and two gallons of hot (95 deg F.-115 deg F.)Water. Use a clean cloth and wipe down the interior of the ice storage bin with the sanitizing solution, pour some of the solution down the drain. Allow to dry.
HOW TO CLEAN THE CONDENSER.
The condenser is like a radiator on a car, it has fins and tubed that can become clogged. To clean:
1. Remove the kick plate.
2. Locate the condenser surface.
3. Vacuum the surface, remove all dust and lint.
4. Replace the kick plate.
CLEANING THE SYSTEM.
HOW TO CLEAN THE ICE MAKING SYSTEM.
1. Open the door and turn the ice machine control knob off.
2. Scoop out all of the ice, either discard it or save it in a ice chest or cooler.
3. Pour 4 ounces of Scotsman ice Machine Cleaner ( available from a local Scotsman Distributor or Dealer, ask for part number 19-0343-06- an 8 ounce bottle) into the ice machine reservoir.
4. Turn the ice machine control to ON.
5. Allow the machine to operate for about 2 hours.
6. Pour hot water into the bin to melt the ice that has formed. That ice will likely be white and frosty looking.
7. Clean the bin liner of mineral scale by mixing some ice machine cleaner and hot water, and using that solution to scrub the scale off of the liner.
8. Rinse the liner with hot water.
9. Sanitize the bin interior.
10. Replace the ice removed in step 2.
The ice scoop should be washed regularly, wash it just like any other food container.
WARNING; Scotsman ice machine cleaner contains acids. These compounds may cause burns. If swallowed,DO NOT induce vomiting. Give large amounts of water or milk. Call Physician immediately. In case of skin contact,flush with water. Keep out of the reach of children. Always follow manufactures directions.
May 16, 2014 | Scotsman DCE33PA1BC 15in Built-in...
Ice not dispensing from door. There is ice in the cabinet.
look behind the ice storage bin---there is a c-bracket that the storage bin slides into --- the motor may have to be replaced that turns the spiral feeder inside of the storage bin
Jan 02, 2011 | Maytag MBF2256H Bottom Freezer...
English instructions for saivod fhs186 ice maker
DO THE BASICS:
Change the water filter
Add ice machine cleaner and go by the directions.
What should be kept clean?
3. The condenser.
5. The ice scoop.
and the storage bin is empty.
household bleach and two gallons of hot (950F. -
1150F.) water. Use a clean cloth and wipe the
Allow to air dry.
How to clean the condenser.
The condenser is like the radiator on a car, it has
fins and tubes that can become clogged. To clean:
1. Remove the kickplate.
3. Vacuum the surface, removing all dust and lint.
Caution: Do not dent the fins.
4. Replace the kickplate.
Winterizing
1. Clean the machine as explained on the next
page.
2. Turn off the water supply.
3. Drain the water reservoir. See page 24, Spray
Pump Repair and follow the instructions to remove
the pump hose (step 2, bottom hose only).
4. Disconnect the incoming water line at the inlet
water valve.
5Remove control box cover and turn the timer
into the harvest cycle.
6. With the machine operating, blow air through
the inlet water valve; a tire pump could do the job.
7. Drain pump models should have about 1¤2 gallon
of RV antifreeze (propylene glycol) poured into the
ice storage bin drain.
Note: Automotive antifreeze must NOT be used.
8. Replace control box cover. Switch off and
unplug the machine.
CUBE ADJUSTMENTS
There are three items that may be adjusted: Cube
Size, Harvest Time, and Bin Level. Note: Cube
Size and Harvest Time adjustments should only be
done by a qualified service person.
Cube size control.
The cube size control should only be adjusted to
bring the cubes to the correct shape, the overall
size cannot be adjusted. Try to adjust the cube
size control when the ice machine is in the harvest
cycle, or in the first 10 minutes of the freeze cycle.
1. Open the door and remove the control box
cover.
2. Locate the cube size adjustment screw, and to
make fuller cubes, turn the screw clockwise about
1/4 turn. This will make the freezing cycle longer.
3. To shorten the freezing cycle and make cubes
that are not as full, turn the adjustment screw 1/4
turn counterclockwise.
4. After the next freezing cycle, the cubes should
have responded to the adjustment, if another
adjustment is required, do it early in the freeze
cycle.
Diagnostic Codes
Code Description
F - - - - - - - Freeze Cycle
F flashes- - - - Freeze Cycle is Pending
H - - - - - - - Harvest Cycle
H flashes- - - - Manual Harvest
b - - - - - - - Bin is Full
C - - - - - - - Clean Cycle
L - - - - - - - Board Locked
d - - - - - - - Test Mode
O - - - - - - - Off
E - - - - - - - Self Test Failed
1 flashes- - - - Max Freeze - Retrying
1 - - - - - - - Max Freeze Time Shut Down
2 flashes- - - - Max Harvest - Retrying
2 - - - - - - - Max Harvest Time Shut Down
3 - - - - - - - Slow Water Fill
4 - - - - - - - High Discharge Temp
5 - - - - - - - Sump Temp Sensor Failure
7 - - - - - - - Discharge Temp Sensor Failure
8 flashes - - - Short Freeze - Retrying
8 - - - - - - - Short Freeze - Thin ice
All 4 Upper Lights Flashing - Unit Remotely Locked Out
Jul 14, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Oster Compact Refrigerator Model OR4505G3B
Oster 4.5 Cu Ft Compact Refrigerator OR4505G3B
I just bought it from bestbuys for $99. It does get really hot when I have the setting on high, but it is still warm when i have it at 1/2 power...warmer than I would like it to be. I connect it straight to the wall outlet.
The temp. may be higher due to ambient temps.
The frige came with messed up box, paint defects...so I thought that it was a decfect/return...but I guess it may be normal for it to get so hot.
Aug 30, 2008 | Refrigerators
Dispenser doesn't dispense
ICE AUGER IN BIN IS BROKE,REPLACE,WATER VALVE TO DOOR WATER DISPENSER IS BAD,LOCATED ON BACK BOTTOM OF REFRIG.REPLACE,THANKS-MIKE
Mar 21, 2008 | GE Profile Arctica Stainless Steel Top...
Broken Door
This is a special heat treated glass and you will likely have to buy the door from them
http://www.shoposter.com/customer_care.asp
Jan 30, 2008 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Oster Toaster Oven 6232 replacement parts?
Write to Oster and they might give you a new one depending on how old it is
Oster microwave/grill
ha, had the same problem, just call the oster custumer service and they can send you a new one for $5
1-800-968-9853
Oct 06, 2007 | Oster 4877 / 4878 / 6209 Toaster Oven with...
Refrigerators Logo
276 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
