Question about Panasonic AG-DVC30 Mini DV Digital Camcorder
Won't record to tape
I can;t get this camera to record to tape.
Have tried several tapes, made sure they are in record mode.
  • 2 more comments
  • buerger Sep 16, 2008
    Yes, I tried a cleaning the heads with a DV tape cleaner. I am new to this camera. I used it a week ago and it recorded fine. I played with a few settings since then to be able to record to my lap top and sync the record/pause function to my capture software. It records to my laptop, just not the tape.
    I also don;t seem to be able to view other recorded tapes on this camera.
  • buerger Sep 18, 2008
    More info....so I also went through every possible menu setup and reset everything back to the defaults. Still does not record. I also discovered that it will not playback any tapes that I have recorded with my other mini-dv cam. So in a nutshell, this thing is not recording or playing back.
    I did observe that during record or playback mode I can see the dv tape wheels turning, so I assume there must be something wrong with the tape head or related mechanism. I can capture video to my pc and use my software to operate the cam to record,pause or stop.
    So I guess I need to get this to a repair shop.
  • Tim Babcock
    Tim Babcock May 11, 2010
    I'll have to take a look at the manual on this one.
  • Tim Babcock
    Have you tried cleaning the video heads with a DV tape cleaner?
  • Panasonic Master
  • 2,794 Answers
Sounds like the tape isn't getting contact with the video head.  It could just need an adjustment.
Posted on Sep 18, 2008
The camera is not showing a picture on the camcorder screen or tv when trying to play in play mode. It ate a tape when I tried to play back a video. I took out the tape, fixed the tape and then tried a...
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jan 22, 2011 | Canon ZR600 Mini DV Digital Camcorder
Camcorder won't record
Check the tape and make sure the record tab is still on the tape and has not been removed. If the record tab has been removed then use a new tape for recording as the unit will not record. This tap is usually on the lower left end of the back of the tape. When the tap is present it closes a record mode switch letting the system know the tape is able to bv recorded on..
Dec 27, 2009 | RCA CC6363 Camcorder
How do I erase a tape alreday recoreded so that I can reuse the tape?
Before you insert the already recorded tape make sure you close off the small square hole with the moveable tab(often green or red colored).After inserting the tape rewind it to the point where you want to start reusing the tape ,set in camera mode and hit the record button .
May 13, 2009 | Canon ZR100 Mini DV Digital Camcorder
Dont know how to use the harddrive with camera
Make sure you turn your other settings in the menu while in camera mode to ext, both or chain. Ext. mode, means pushing record on the camera makes the hard drive record, but not to tape, Both means that both tape and hard drive will record, Chain means when you run out of recording onto tape, the hard drive will automatically start recording as the tape runs out.
Mar 25, 2009 | Panasonic AG-HVX200 Mini DV Digital...
Is there a better (brand) tape to use with a Elura 90? I read somewhere that certain tapes had more problems than others. Thanks, Joe
One thing that can change the tape quality is making sure you are using th 60 minute recording mode vs the 90 minute EP recording mode. If you record alot, you should clean the tape heads every 6 months as well. I haven't really found any bad tapes out there (I'm sure there are some). Usually Sony and JVC are good choices to use.
Dec 23, 2008 | Canon Elura 90 Mini DV Digital Camcorder
Why wont it play LP taped tapes?
Tracking is very sensitive on hi-8 tapes in LP mode. This recorder will record and playback in LP mode. It is however recommended that if you record in LP mode that you use the same camera to play it back, that it was recorded with, or you might have problems.
Also from what I can find online, the TR427 is just an video8 camera not a Hi-8 so if you are trying to play Hi-8 tapes on it, it won't play right.
Nov 03, 2017 | Sony Handycam CCD-TR427 Hi-8 Analog...
Blue screen on playback on Sony DCR-HC40
You can see an image in a camcorder viewfinder any time the camera's actually on in record mode, whether or not the camcorder is actually recording. So that's no guarantee.
Assuming the obvious (you have the right kind of tapes, they're not in write-protect mode, you rewind before playing, etc). I recommend that you borrow a tape of the same kind from someone else and check it on playback in your camcorder. This should lead you know understand if you have a playback problem or a recording problem.
Jan 20, 2008 | Video Cameras
Record button doesn't function
You may want to check the record lockout safety switch located on the tape. This button can get moved by accident and the camera will refuse to record on that tape. Also, be sure the camera is in "video" mode, not "photo" mode. Some of Canons camcorders have a digital still camera mode which stops the camcorder from functioning because the photos are being recorded to a memory card and not your tape, please check this swithc as well. Good luck. Joe Weibel customelectronics.org
Feb 26, 2007 | Canon Elura 65 Mini DV Digital Camcorder
Recording problem
If your camcorder powers up but does not record, try the following: * Be sure that the camcorder is in camera mode. * Be sure that inserted tape is not full * Be sure that the protection / lock is not enabled on the tape * Try a new tape If your problem has not been resolved, find your nearest authorized service center.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
I can't start recording.
# You may not have turned on the camcorder to record properly. For camcorders that feature both Automatic and Manual recording, make sure you press in the LOCK button while setting the POWER switch to the desired setting, either "A" (Automatic) or "M" (Manual) record mode. # Automatic recording places the camcorder into Auto Shot™ mode, while Manual recording mode allows you to control many of the camcorder's special features, including accessing the menus and setting the clock. # For many other camcorders, make sure the CAMERA/OFF/VCR switch is set to CAMERA. Make sure the Erase Protection tab is in the position that allows recording. If not, slide the tab. Some tapes have removable tabs. If the tab has been removed, simply cover the hole with adhesive tape or use another tape.
Sep 06, 2005 | RCA CC-432 Camcorder
Panasonic AG-DVC30 Mini DV Digital Camcorder Logo
106 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
