Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Trouble Closing Our door will open fine with either the car remotes or the indoor switch.  It won't close with either car remote and will only close by holding down the indoor switch until it's fully closed.  Any suggestions? Thanks, Mike
  • bcollins Sep 20, 2008
    I have the exact same problem. I was having problems with the remotes working randomly so I changed them out this did not fix the problem.Then I changed out the mother broad and then opening works fine but if I release the indoor button before it completely closes it stops closing and the lights start flashing. Cleaned and adjusted rollers put the old board back in to see if the inside button would work properly, but now the old one works only if I hold the indoor button until the door fully closes but it opens fine.
  • 4 Answers
Check your owner's manual, but I believe this is standard procedure when the safety beam system isn't working for any reason -- the only way to force the door to close is to manually override with the wall button.
Our house had a lightning strike, and after that, the safety beam was not working. Turns out a diode on the controller board got shorted out, making it so that the safety beam devices weren't getting any power.
So I'm guessing either:
- your safety beam devices are not getting power (check for the LEDs to light up)
- they are getting power but are not aligned and hence think there is something in the way (usually they blink in a way when they think there is something in the way, so this is also easy to test)
- they are flaky (unlikely since they are pretty simple devices, but one never knows!)
- the controller board is misinterpreting the signals. (replacing the controller board is expensive, usually. In my case, I was able to quickly find the fried diode, and $2 later, I have a working garage door again!)
Posted on Jul 15, 2009
Had similar problem. Check the safety beams on both sides of the garage door opener. Check the wiring on the safety beams.
Posted on Sep 17, 2008
I have a Chamberlain motorlift ML700. The remote works fine for opening the gate, but doesn't close it. Resetting the remote didn't help. Any ideas? Thank you.
My best guess is the closed limit switch is out of range or defective and telling the controls it is already closed.
Dec 07, 2014 | Building Materials
Lift master formula I will not close, only goes half way down, but fully opens. Worked fine until my wife closed the door on the car, after that it would fully close
I had this problem as well with the door opening just fine but was not closing when using the remotes or when breifly pressing the wall mounted control. The door would close only when using the wired wall mount control. I have experienced this problem with other garage door openers I've had in my previous homes and it was always caused by sensors at the bottom of the door tracks being either misaligned or the lenses were dirty. In this case, and it was just a moment ago today, I simply cleaned the sensor lenses and then the door began to function properly. Give it a try.
Jan 28, 2013 | liftmaster Chamberlain Garage Door Opener...
The garage Remote control was working normally at first then for now reason now it just opens the garage door but doesn't close it. I checked the side sensors they look OK & clear, and I...
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
Jun 06, 2011 | liftmaster Garage Door 1/2 Hp
I have a LiftMaster garage door opener. It has started to act up a bit, and I can't seem to locate the problem. It opens just fine, but when we try to close it, with either the remote or the wall control,...
If the opener feels any resistance it will act like this.Make sure that the rollers on the door to frame are oiled well and turn easily, move in and out easily as well, you can also turn the screw to increase the resistance stop pressure.Oil the rollers well
Jan 22, 2011 | liftmaster Chamberlain Garage Door Opener...
I have to hold down the wall mounted opener the entire time that the door is closing. The remote will not close the door. They both open the door fine.
Look at the back of the opener, the LED light blinks. Count how many blinks, then go to the troubleshooting guide to find the fault.
Jun 28, 2009 | liftmaster Chamberlain Garage Door Opener...
2005 town&country sliding door problem
try cleaning the terminals they may need to be cleaned on the door and bpillar
Jan 23, 2009 | 2005 Chrysler Town & Country
Door close with wireless remote entry but will not open
It sounds like this remote has lost its program! you will have to reprogram it!I hope this helps ya!
Dec 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
181 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Are you a Sears Building Material Expert? Answer questions, earn points and help others
