Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Gas oven door chrome facia
How do I reattach the chrome facia on the outside of the oven door? Where do the screws go and what size are they?
  • patton451 Apr 04, 2009
    The glaas front just fell off. It appears to have been glued to the frame.
  • 750 Answers
Hello jagereghty
You asked, How do I reattach the chrome facing on the outside of the oven door? Where do the screws go and what size are they?
Why is the front off the door? This means that the seal is now broken?????????????????
Posted on Sep 25, 2008
My oven door handle has come off at one side how do I reattach it?
Since we don't know the model number or see a picture, I will guess that the door is two parts and you probably have to separate them to get to the screw that attaches the handle.
Jan 09, 2015 | Baumatic Ovens
Integrated Worktops
Usually screwed internally within the door edge of the oven it is rare but may be lugs on the top edge within the oven facia panel.
Jan 09, 2012 | Ovens
How to remove built in oven
Open the oven door and you will see 4 screws around the edge, these hold the oven into the unit, remove the fuse from the power socket and with all the power off to your oven remove socket faciaand detach the power cable to the oven. Reconnect electrical socket facia and leave the fuse out. Please rate my helpfullness O
Jul 18, 2011 | Whirlpool RBS275PD Electric Single Oven
How do you remove the front facia door of a Teknik integral dishwasher
I have just replaced the facia on mine. It is a TKD795/4 so I would imagine yours would be very similar. Around the inside of the door are 10 starhead screws; 4 along the top and 3 down each side. On mine it is the 2 end screws along the top and the 2 middle screws down the sides that hold the facia on. It is best to remove one screw at a time to establish which ones hold the facia on and which hold the door together. The short screws hold the door together and should be replaced and left in place. It is the longer screws that hold the facia on; these only need to be undone enough to release the facia panel. Once you have undone the relevant screws, the facia will lift up enabling you to release the 2 clips at the bottom. Replacement is reverse of removal. Hope this helps.
Feb 26, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Replacing door seal front loader bosch
This video will show you how to change a door seal on this bosch
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
Handles fell off of the top oven door on maytag gemini glass top
Open the door a few inches, to the first hold-open stage. Lift the door upward & off the mounting bars. There will be screws along the bottom edge.
Mar 08, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
Handle has pulled away from the door. How can I access the screws
Realized the top chrome part split into 2 pieces and then was able to remove the wood like strip in the chrome strip. Popped the top chrome anchor, reattached the handle bracket as the screw holes were not stripped, put the wood like strip back in place and slid the top chrome anchor back in place.
Feb 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Lamp replacement
Without giving specifics, I'll cover most configurations.
Look for a thumb screw on the lower right "side" of the TV as you face the screen. If it exists, unscrew it and take the door off. Reach inside the cavity and lift the "D" ring and pull out the lamp. Insert the new lamp by tilting the lamp up on the left side (high voltage connector should be on the bottom), the "D" ring will raise and lower on its own when it seats. Reattach the door and it's done. If your set blinks the power light 3 times, you didn't get the door on correctly or the lamp isn't fully seated.
The other models require popping a facia panel off the front of the TV. To do this look for thumb screws on the rear of the set just below the corners of the screen. Loosen them until they are free from their threads, they will not come out completely as they are captive. Pull the plastic facia panel off the front of the TV. Find another thumb screw at the lamp door and loosen it, sliding the latch over to release the door. Use the long allen tool to loosen the bulb mounting screw and pull the bulb out. Reverse the sequence to reassemble.
Nov 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
122 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
