Question about HP DeskJet 3745 Printer
Trouble having my 3745 printer work
My printer had a paperjam. I pulled the paper out. After that the printer does not feed the paper. when I checked, I found that the ink cartridge is not moving on the track. It is blocked by two prongs?. Did I break some thing when I pulled the paper out? Can it be fixed? Did I break any parts?
Thanks
Johnson
Bhimavaram, India
  • 1 more comment
  • johnsonchopp Sep 16, 2008
    No. It does not move to the center. There are two prongs on lower plastic track that go down and come up which are obstructing the movement of the cartridge.
  • johnsonchopp Sep 18, 2008
    When the cartridge is in the center, oneither side of it, on the lower track are the two flexible prongs I was talking about. They are preventing the smooth movement of the cartidges
  • Tim Babcock
    Tim Babcock May 11, 2010
    If you open the printer door does it move the cartridges to the center of the printer?
  • HP Master
  • 2,794 Answers
If there's a way you can get the cartridges out of there and put them back in, it should work properly again.
Posted on Sep 16, 2008
  • Tim Babcock
    Tim Babcock Sep 20, 2008
    Can you realign then back on the track?
Paperjam siplay no paper in the back
hi open your printer so that you can see the wheels that feed the paper into the printer and check that no paper is stuck in the meconisom is this is soum times wey it says paperjam
Apr 09, 2014 | Kodak ESP 3 Multifunction Printer/ Copier/...
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
My desket 3745 light blinks..when I put paper in, the light keeps flashing..says no paper~! doesn't seem to catch the paper to start printing.
This is cased by a dirty paper feed path or paper feed sensor so it will need cleaning and blowing out. Make sure that all the internal paper guides and separators are free of obstruction. Make sure that the sensors are all clean that the internal paper guides are all in place and operate freely. Also clean it with a vacuum with a soft haired brush tool to avoid any damage. Also fan the paper before using it and do not overload the print paper tray. Also check that the pick up rollers are not worn or contaminated with dirt / debris etc. Also make sure that the print tray is not overloaded and make sure that the paper is not to tightly held by the tray side guide.
Also check the paper pick up for wear as this will cause additional pages to be collected and fed through the printer. Make sure that you fan the paper before use ant it is of suitable quality and weight.
Oct 01, 2009 | HP DeskJet 3745 Printer
OKI B4100 paperjam warning
Acording your explained you need do
1) clean the input tray roller surface, to make sure it has enough grip force.
2) looking for a sensor around the roller rear, it could be cause the paper jam there, because if the sensor does not detect any input paper go throug there then should be stoped at roller rear.
3) if you find a optical sensor there, please use a slft cotton stick to clean its surface. (maybe open some cover needed)
hope you fix it , ask me any time please!
May 17, 2009 | OKI B4100 Laser Printer
We got a kyocera fs-5015n used. It won't print just says paperjam. i have followed all the steps in the manual to remove a paperjam and haven't found any paper in the machine.
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Office Equipment & Supplies
Kyocera paperjam
Tally 2280+. While printing, goes offline and displays paperjam.
Dec 29, 2008 | TallyGenicom 2280 Matrix Printer
Paper is not loading
what's the brand of your printer?if its hp, then it takes several minutes before the paper would feed. it still wont work try to restart your printer
May 27, 2008 | HP DeskJet 3745 Printer
Printer pulling on paper
My husband took the top cover off the printer and took a good look inside with a flashlight. He found a hot pink crayon stuck where the paper feeds through. I guess I should have had a better look initially, since the paper never made it all the way through the printer. Works like a charm now!!
Feb 23, 2007 | Lexmark X6150 All-In-One InkJet Printer
Flashes paperjame sign but there is no paper jame!
the problem is same sensor no work in the good way or ther is problem in the fusing unit or ther is problem in the feed unit
Jul 24, 2006 | Toshiba 1370 Black and White Copier
HP DeskJet 3745 Printer Logo
52 people viewed this question
Seeker5211
Seeker5211
