Question about LG WM-2277HW Front Load Washer
How did you do that?
How did you clean out the drain hose with an air compressor?
  • 489 Answers
I don't see how it can be done.  You will need to disassemble the front panel and remove the drain hose to physically clear it out.  Usually it's clogged with sand or dirt.
Posted on Sep 29, 2008
Tip
Airconitioners tips
<br /> <ul> <li>Check all hose connections for leaks. Repair leaks</li> <li>Make sure the condensate tube is draining freely.</li> <li>Change or clean the furnace filter once a month. This is especially important during the summer when dust and allergens circulate.</li> <li>Clean the outside compressor by spraying it with a hose.</li> <li>Keep plantings at least one foot away for adequate airflow around the entire unit.</li> <li>Vacuum registers and air vents regularly.</li> <li>Have your ductwork professionally cleaned every few years.</li> <li>Keep furniture and drapes away from registers.</li> <li>During the winter, keep the compressor covered and remove window air conditioners.</li></ul>
on Apr 02, 2011 | Heating & Cooling
My compressor builds up pressure in the tank but nothing comes out unless the unit is on and then it just trickles out like nothing is in the tank
have you drained tank
air tanks fill with moisture and crud if not regularly drained
this takes up room in tank and will eventually clog valves etc
you may have to remove hose conection from tank to clean out crud that has clogged it
Jan 04, 2011 | Coleman Powermate 11 Gallon Air Compressor
Hose not draining, bucket only fills
The easiest way to unstop the hose is to blow air through the end enough to clear the clumped up dust at the other end using air compressor or air pump.
Jul 12, 2010 | Frigidaire FDF70S Dehumidifier
WIndow A/C Unit- Not Draining Water
do not close your vents on the a/c unit because this makes the compressor have higher head pressures in the long run will cause the compressor to fail it will last longer if you set the thermostat to lower setting rather than closing off the vents. You need to clean out your condensate drain I use a small wire brush and water hose clean them out.
Jun 21, 2010 | Heating & Cooling
Water coming out airbush from hose
An in-line water separator should be used before the supply line, a good air filter wouldn't hurt either.
Apr 23, 2010 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Water remaining in bottom after cycle
Disconnect the drain hose at the sink drain. Reverse the action of your vacuum so that it blows (or use an air compressor if you have access to one), and blow the hose clean--it should discharge any drain hose contents into the washer cavity and hopefully cause faster draining in the future.
Oct 12, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Air conditioner dripping water
Try pouring some bleach in drain.
Jun 28, 2009 | Fujitsu 12C1 Air Conditioner
No cool air and oil in one of the drain lines
I would say that you have a refrigerant leak. The oil was pulled out of the compressor and leaked out with the refrigerant.
Jan 17, 2009 | DeLonghi Pinguino PACL90 Portable Air...
LG WM-2277HW Front Load Washer Logo
216 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
