Model # L46WD22YX5, 46 inch RCA. Sound went out. Unplugged TV for 1hour. No help! This TV is 2 1/2 months out of warranty. HA!! Go figure! Recently change antenna and all wires. We do not have cable. When setting up TV, picture is beautiful but no sound at all on any channel. I would love to be able to fix this on my own, but this may not be possible. Hope you can help! Thanks.
  • Mark Vincent Cowherd Mar 01, 2013
    I have the same model and also no sound.
  • 21 Answers
SOURCE: PLTV-32 good picture, no sound
if you still have a problem (and the tv!) email me at gmail.com
Posted on Aug 31, 2007
Shuttle83
  • 1139 Answers
SOURCE: RCA 32 in TV no picture no sound just a beeping noise TV power is on
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Posted on Mar 24, 2008
  • 4 Answers
SOURCE: NO POWER, PICTURE, OR SOUND, power button flashes green 2-3 times
had same problem. update tv software with a usb drive. do not take the tv apart. its easy download to computer unzip to usb drive and put drive in right side of tvs usb slot with power off, then turn power on, you should get an update screen.
did not work for me the first time i had to format usb drive to fat (not fat32) and then unziped to the drive took 10 minutes to update. I have tv 60PP9200D/37
Posted on Apr 28, 2008
dutchman05
  • 487 Answers
SOURCE: LG LCD/DVD TV no sound on TV - DVD works fine with sound!!!!
HERE is the servce manual for this TV
Posted on Jun 21, 2008
  • 927 Answers
SOURCE: hitachi ultrascan HD tv 43 inch
Good Day;
If you don't hear the relay click suspect Q003. No power suspect Q912, Q914 & I901. Good Luck, big IRISH.
Posted on Sep 06, 2008
I have a 52 inch floor model RCA TV bought in Nov 2004. It will not turn on OR when it does turn on it will go off. There is no logic, sometimes it works, sometimes is doesn't. If it is not going to...
I recently had the same issue with a 6 month old Panasonic...the Tech determined that a component on the main circuit board failed. I was lucky and it was fixed under warranty. Good luck!
Oct 05, 2010 | RCA Televison & Video
52 inch RCA Home theater-Sound is distorted/scratchy
I unplugged the tv for 5 minutes. When I turned it back on, I had sound!
Aug 01, 2009 | RCA 32V420T 32" TV
Tv popped and picture went out
im srry to tell you that you picture tube blew in you tv this can happen from many things as simple as a defective one .. to a bad power surge in your house ... if it is under warranty they will fix free of charge .. if not you'll have to get a new tv .. a new tv in most cases is cheaper then tryin to just by the tube .. oh and if its not under warranty .. you could always just say it surged and claim it on you home owners insurance =]
May 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 57 inch hdtv Model#HD56W58 has sound but no picture.
WOW...had a high pitch noise, came and went...got worse as time wore on. Would shut off the set, times it cleared times it didn't. Warranty folks set out a TV repairman--said he had worked for RCA exclusively for years...anyway, explained that the 1k hertz noise was a known issue with the HD56W58 and that RCA’s published fix was "nail polish" applied on some board, had something to due with power and vibration...long story "presto" noise gone...but after 6 or so months we began to hear it again—say it ain’t so, but yes the high pitch was back. Same repairman, this time bigger problem...along with noise, the network card is broke and Fry’s Electronics (Irving, TX—hear that Corporate HQ at San Jose…your Irving store needs to be leased in and tote the company line...where's the customer satisfaction???) is balking at a “equal” replacement, they see it as take the less than equal product or get store credit…good luck & wish me luck with the equal replacement they tout when pushing the warranty.
Mar 15, 2009 | RCA HD56W58 56" TV
No picture with VIDEO INPUT, only AUDIO INPUT works
Hi ,disconnect the cable and leave the three RCA cables in.Switch off TV and DVD player ,then switch on tv and dvd player next .If you see the dvd picture and have sound then i think the cable box is overriding the rca channel.I normaly use a scart connection for the dvd to cable box then another scart from cable to tv.Hope this helps..
Feb 06, 2009 | Toshiba 37AV500U 37 in. LCD TV
RCA 52 inch
three strikes and it's out... rca does this, it is just showing it has tried 3 times for you and untill it is unplugged it won't try again.. you need to provide model #.. could be a few different things
hissing usually meens you have high voltage...that's good but then what don't you have?
ctc 169 - 179 could be high voltage divider... need more info
Oct 17, 2008 | RCA R52WH73 Projection Television
No sound on LCD tv
in the audio part of the menu, check to make sure the internal speakers are not turned off.
what connection are you using for the DVD? if using YPrPb, make sure you also have the audio red and white plugged in
Feb 12, 2008 | RCA L37WD12 37 in. LCD HDTV
Rca m50wh74s HELP
Sounds like a bad high voltage transformer (FBT). Call a service center.
Jan 11, 2008 | RCA HD52W56 52" Rear Projection HDTV
Rca truflat with green tinted picture?
Just because a machine has failed, there is no cause for you to call it a stupid TV. And as it is only 6 months old, why not take it to the Company service Centre? There must be warranty.
Apr 01, 2007 | RCA 27F530T 27" TV
RCA 27 inch TruFlat TV/ Walmart Feature Item "Defective!"
I AM SORRY ABOUT YOUR PROBLEMS WITH YOUR TV... AS IT IS YOU BOUGHT YOURS AT APPROXIMATELY THE SAME TIME THAT I BOUGHT MINE. I STARTED HAVING PROBLEMS WITH THE SAME THING YOU DID ABOUT 6 MONTHS AFTER I PURCHASED IT. BUT THEN I THOUGHT IT WAS DUE TO SOMETHING MY NIECES HAD DONE TO THE TV. MY DAD TRIED TO FIX IT AND IT WORKED FOR A WHILE AND THEN ON CHRISTMAS EVE 2006 IT WENT COMPLETELY BISERK!!! NOW I DONT EVEN KNOW WHERE TO GET THE CONTROL PANEL.
Jan 07, 2007 | RCA 27F530T 27" TV
Televison & Video Logo
446 people viewed this question
Top Televison & Video Experts
