Question about Canon PIXMA iP3000 InkJet Photo Printer
IP3000 Hi there I have noticed you have answered a ink problems with IP3000's. I have been using generic ink (i know naughty me wasnt aware even asked sales person they said it was fine blah blah never again haha) My problem is that my colours in ink are not working properly for eg I do a Nozzel Check the colour ink comes out green to the left and blue to the right if you understand that haha. I have now replaced generic ink with canon ink and down untold deep cleaning still to no avail. Your help is most appreciated
Canon ip3000 & ip4000 the heads get dirty.
if you keep doing cleanings and deep cleanings it will eventually cause an error because it thinks the tank is full.
take out the head - in the sink, with warm not hot water rinse out much ink as possible. then use windex, the ammonia removes the ink. flush good - shake out head, drops will form on the bottom. keep doing it until drops are clear. rinse with water. shake out well. dry contacts.
I use a water pic as a pressure washer to force water thru. replace head and tanks.
do not use clean, instead print a page of 'X's
make every 5 rows a different color. this way you can see what is working and it won't fill up the cleaning tank, causing a code error.
you can use any ink you want as long as it is the proper type- don't have to be canon
Posted on Aug 21, 2009
Power on / off
I'm thinking from what little info you've posted, that you are running your Laptop with a generic, rather than the recommended power adapter. If this is so, naughty you. When it comes to PC's and Laptops, always use the recommended power adapter, else you may cause your PC/Laptop to die a slow and horrible death.
I hope this answers your query.
Cheers,
Peter
Mar 04, 2013 | ASUS X80 Laptop AC Power Adapter (5A...
What does an error message of waste ink is full mean and how do I fix it. Waste ink absorber is full.
Hi There
Try this is for your printer, but donr forget some time you will need to clean out the waste ink pads that are inside the prinyer.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 30, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
My canon pixma ip3000 will not print in black ink
Hi There
Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Apr 29, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
All 4 lights flashing
Probably the waste ink tank is full.Try this:
Pressing and holding LOAD/EJECT and CLEANING buttons, press POWER button and hold it until You will see blinking INK OUT and PAPER OUT leds.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button, until all leds will blink.
Nov 11, 2009 | Epson Stylus Color 760 InkJet Printer
Magenta Ink Streaking
that printer color cartridge is a problem... buy a new one.... color ink
Jun 16, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Black ink
Hi
Check out my reply to chengfrank43 in ip3000 section.- it may be of some help to you.
Feb 06, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Ink not working properly on ip3000
clean the printer so the ink will come out. Don't worry i had the same problem trust me this works!!
Hope it helps
Jul 25, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon ip3000
try putting back in your old cartridge, If it works it means your new cartridge is defective or is not an original cartridge.. Newer printers have an upgrade in the firmware to detect Generic compatable cartridges or refilled cartridges and they claim the fail safe is to prevent damages to your printer.
Jan 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Computer Pixma printer ip3000
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Oct 11, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
74 people viewed this question
old marine
old marine
Corne Viljoen
