Question about Averatec 3200 Notebook
Screen isn't bright enough
My averatec screen is dim and when the battery is plugged in I have o wiggle it for it to get brigh
  • Brande Sep 16, 2008
  • 659 Answers
Remove the battery and clean the contacts on the battery and the laptop these sometimes become dirty and need a good cleaning try that and if nothing ill shoot some more ideas your way.
Posted on Sep 16, 2008
Tab 3 screen keeps dimming even when im playing on it
seems like you may have the auto brightness turned on. switch it off and set the brighness to your needs, but be careful, the brighter you have it the more battery you are using
Oct 18, 2013 | Samsung Galaxy Tab Tablet PC
Toshiba CF19F22 TV screen too dim.
It looks like the CRT tube on your TV came at the end of its days, if the tv is 15 years old or so this can be normal.
It may not be woth repairing.
Sep 14, 2008 | Toshiba CF19F22 19" TV
How do i get the screen to light up more, its to dim?
Depending on how old your computer is, your lamps may be failing,
Or you may have reduced the brightness, look for two F buttons generally F7 and F8 for screnn brighness, hold down Fn or function button and tap F8 to increase brightness.
Jan 17, 2010 | Toshiba Satellite A75-S226 Notebook
I need to lighten my screen
this is not a computer problem you have to press the buttons on your monitor that is a menu when the menu comes up change the brightness
Nov 14, 2009 | Averatec 7171000100 Keyboard
My Garmin nuvi 1300 brightness problems
I spoke to Garmin Support about this issue. There are 2 settings for contrast on the nuvi 1300. You need to set the contrast while it is plugged into the vehicle, and also while it is unplugged from the vehicle. The reason for the 2 settings is to save the charge of the battery while it is not plugged into the vehicle or power source.
Sep 14, 2009 | Garmin nuvi 1300 Car GPS Receiver
Lights dim and then brighten
This is your Alternator. Check the Battery Cables for Tightness in Addition.
Jan 12, 2009 | 1997 Nissan Pickup
Display brightness
Ok on your keyboard there should be some way to adjust the brightness just plug in the laptop and adjust it to what you want then unplug the laptop and adjust it to what you want and it should keep that setting. if that does not work you can check the bios settings some laptop bios' have a brightness option.
Dec 06, 2008 | HP Compaq Presario R4000 Notebook
Screen Keeps dimming and contrast function does not work
This is possibly, a loose cable or the screens inverter board is overheating. the inverter is similar to a booster in a flourescant light fitting. which converts power from DC To AC and boosts up the panels Light Tube. CFL if it,s faulty or overheating. this will cause the panel to dim.
also check the plunger at the underside of the screen, isn,t sticking down. designed to cut off the panel when the lid is closed. Finally some model laptops, only boost the brightness running on A/C Power. the battery would run-out fast with screen at full brightness. if theres an fn key on the keyboard, press fn and the brightness button to adjust screen brightness.
Mike @ Compurepair.
Jul 31, 2008 | Samsung V20 XVC 2400 Notebook
Picture is very dim
there is a problem in the flyback section of the tv set. the fly back has two knobs, one for screen and the other for focus. use the screen knob to adjust the brighness. if it did not help, either check the capacitors around the flyback or change the fly back with a new one. good luck
Jun 01, 2008 | Televison & Video
Screen`s brightness less
<Fn> + <→> Brightness up Increases the screen brightness.
<Fn> + <←> Brightness down Decreases the screen brightness
If tese dont work either your LCD lamp or board may be going bad.
Nov 18, 2007 | Acer Aspire 5600 Series 5630-6951 Laptop
Averatec 3200 Notebook Logo
51 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
