Question about Whirlpool Washing Machines
Duet Sport Ht when you start a cycle the machine will hum as if it were going to start but does nothing. The door locks only to have it unlock by itself
  • e4176 Sep 17, 2008
    no water flowing and an error code of F1
    Novelist:
    Champion:
  • 261 Answers
Can you hear water entering the machine and do you get a F error code?
Posted on Sep 16, 2008
  • John Robbins
    John Robbins Sep 18, 2008
    You are having a eeprom communication error. We need to first unplug this and is your outlet grounded? I had one of those today. Any way we need to look at the white ccu box on top and the white mcu box on the bottom. Before we do is your washer have any coverage? Or do you have a house with a policy that covers appliances? That is always an easier way, pay a deduct and let some one else sweat. We need to unplug and replug in all connections from the motor to the mcu and up to the ccu. The door locks so that is good and while your down there look at the side panels for a tech sheet it will have a map of where all those wires go. Another thing is checking safety grounds. Little boxs located where panel pull off that trip up computers on these machines when they stay open to long. Another thing to is to check your inlet valves when the power is off by unplugging the wires and checking with an ohm meter. You should have around 840 to 932 ohms on each one. If I think of any thing else to check I will post back.
My whirlpool duet sport front load (HT) washer is not working.
it sounds since this machine was named "duel sports" that is going to play with your heads some crazy games but nothing to worry about its going to grow up eventually,meanwhile just sit back amd injoy the game after all why did you adapt a "player"
Jun 12, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
I have a whirlpool duet HT. The control lock botton is on. So the washer will not start it does nothing. I unpluged it, hold in the unlock door botton nothing works. The door opens and close I just...
Hello Welcome to FixYa here is the answer your searching for..Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked. If this was helpful please rate me Thanks :)
Jun 12, 2011 | Whirlpool Washing Machines
My Maytag Epic Z washer stop in mid cycle then locked the door, we unlock the door via holding the cycle signal button down for 3 seconds, now we can open the door, close it, power up, start a cycle, but...
The low humming sound is from the pump. Remove the 3 screws on the bottom panel and remove it to check the pump filter. Here is a video for the "Duet Sport" washer. This washer is about the same. This video will show you the process and in this video the problem was similar to yours.
Happy Holidays The FixYa Team
Dec 19, 2010 | Maytag MHWZ600TB Front Load Washer
I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
May 18, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Duet Sport washing machine with a leaking door.
You need to check if the door is not loose on the washer, make sure you tighten all the screws on the door
Jan 07, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
