Question about HP PSC 1315 All-In-One InkJet Printer
Can't scan I installed the driver for my HP PSC1315 All-In One ...everything works except the scanner. Can anyone help?
  • 3 more comments
  • Anonymous Sep 19, 2008
    I have the same problem. The error indicates a .msi file is missing.
  • Red Eagle Sep 20, 2008
    I uninstalled my PSC 1315 software and re-installed with the CD that came with my refurbished PSC 1315 and everything works except the scanner still. Any ideas what's wrong with the scanner only?
  • justnofx Oct 06, 2008
    try to scan using the psc 1315 all in one inkjet printer but It will not scan. the scanner moves about 1 inch. then homes out again and i get a earror message.
  • ellenmedi800 Oct 18, 2008
    i have the same problem, when scanning output is in all black, printing has no problem, scanning and copying in all black. please help!
  • Anonymous Mar 27, 2014
    printer shows E
I cant use my scanner
Posted on Oct 08, 2008
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
Any idea what MSI error message you had? HP has a product page for the PSC 1315. Click here to go to the product page. Once you're on the product page, you can search for MSI and you'll get a number of pages to choose from. You need to know the specific error message to choose the right one. HOWEVER, those errors mostly look like ones you'd see while installing.
If you didn't see those errors when you were installing, you might try to uninstall and reinstall your software/drivers. The drivers HP has for download are newer than the drivers that were on the CD when you bought the printer. The newer drivers are available here.
Posted on Sep 26, 2008
I have an old printer model HP psc1315 all in one, printer, scanner. What I need is a software when I can scan my document. I don't have HP director and I cannot find any software in the web to be able me...
IT COMES ALONG WITH THE DRIVERS CD
TRY REINSTALLING PRINTER
FIRST UNINSTALL YOUR PRINTER COMPLETELY
REMOVE ALL CABLES OF PRINTER (USB)
REBOOT YOUR SYSTEM
HAVE DRIVER CD
PUT IT IN ROM(CD/DVD)
INSTALL PRINTER SOFTWARE
DONOT PLUG THE USB CABLE UNLESS & UNTILL PROMPTED
PLUG USB WHEN ASKED
FINISH INSTALLING PRINTER
NOW YOU CAN FIND THE SCANNER
Feb 07, 2011 | HP Computers & Internet
I have just bought a HP Photosmart plus B210 printer. I have installed it ok and it is wireless connected. everything seems ok for printing but when I try to scan to Paint shop Pro 7 or from Word 2003 it...
Hello Carol,
The first thing you want to do is check to make sure the scanner driver is installed properly and working.
If you are running Windows XP or Vista; go to Start Menu \ Control Panel \ Scanners and Cameras
NOTE: For Vista user you must select "classic view" in control panel to see scanners an cameras.
For Windows 7; go to your Start Menu, in the "search programs and files" section (found below "all programs") type in "scan". You will see a result for View Scanners and Cameras.
Now you should see the HP scanner here. If it is not here then you need to reinstall because the scanner was not installed properly. If the scanner is here, right click on it and select Properties. (For Windows 7 you do not have to right click, you will see Properties at the bottom of the window).
In the properties select "test scanner". If this test fails, the driver is not working and you should uninstall and reinstall the HP.
If this test works then the driver is properly installed. HP should have provided you with some sort of scanning software, try scanning using that. You can also try scanning using Windows Fax and scan (for windows 7), Windows Photo Gallery (Windows Vista) or the Windows Scan wizard (Windows XP).
Thanks,
Pat
Nov 07, 2010 | Office Equipment & Supplies
Scanner will not work
Completely uninstall the driver check in the registry and delete the file name and then reboot the system and install the driver in a different location.
Mar 16, 2010 | Office Equipment & Supplies
My HP C4480 scanner only returns a black image (on
Did you repaired old drivers? if so first uninstall your products drivers and also its folders from program files, then uninstall "wrong update" and reinstall scanner. sometimes built in scanning modules comes wrong but everything works with original scanning software, use different software to scan and some of them may work perfectlly.
Feb 20, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
HP Officejet J5780 scanner communication error
I had this problem too, and after a while just gave up on the uesless HP interface, and went to the simple but efficient Windows Fax and Scan program on the Start>Programs menu.
Jul 09, 2009 | HP Officejet J5780 All-In-One InkJet...
Will not scan
you will have to uninstall the scanner drivers from the computer in the control
panel>scanners..then uninstall the printer drivers from the printer in the control
panel and then run the wireless setup wizard on the printer then try reinstalling the
drivers and the s/w using the disc that came with the printer......see if works
May 16, 2009 | HP Photosmart C7280 Printer
SmarThru Office can't see scanner (nor can word)
Windows is using Window's default scan driver, so it's working only within Windows scan wizard feature. You will need to install the Scan Driver separately to work with SmarThru and other software. The Scan Driver is available at Samsung website.
Apr 16, 2009 | HP PSC 1350 All-In-One Thermal Printer
HP PSC1315 Inkjet all in one
Hi vikram70
here you go select your o/s psc1315 and get software and drivers that are compatible with your product and the operating system.
Jan 17, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
165 people viewed this question
Ben Johnson
