FixYa.com
Tags:
Toshiba M752 VCR
Toshiba M752 VCR (by 2 users)
I have a low usage Toshiba M752 VCR that only recently started messing
up. The tape gets caught on the inside and the unit shuts down. I'm
wondering if anyone has a service manual for this unit. I realize that
this unit is around seven or eight years old but until now I have had no
problems. The tape mechanism is the only thing not working.
Thanks,
D.E.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Frenchy 612, posted on Nov 05, 2007
I have the same problemmaybe? After I replaced the pinch roller the VCR (M-752) would not load properly. I need a service manual!!! HELP !!!! -Paul
Best Solution
posted on May 30, 2006
Helpful (85)
electronics-forum
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
dutch:
A service manual for this type of fault is usually not required....
and in most cases the service manual will be of little help, if any.
Depending on the exact symptoms the problem could be as simple as a
worn belt or stuck idler gear... or possibly a bad/dirty mode switch.
If you are not certain where to start you should go to the website for
this newsgroup at
http://www.repairfaq.org/
there, with some search time, you will find a wealth of VCR
troubleshooting tips, repair proceedures, and important safety
information.
Good luck with your repair.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these VCRs problems?
VCRs
VCRs
Hello, I need to buy a new VCR.... Answer This...
VCRs
timer recording, more than 1...
I have a Sylvania 6260VF VCR. I... Answer This...
VCRs
I don't know how to set the...
I was unable to set video to... Answer This...
VCRs
no reception from vcr
when I plug the cable wire into... Answer This...
VCRs
When I only want to set the...
I select from the menu the... Answer This...
Repair Service
Find VCR Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
