Question about Motorola Mobility H500 Wireless Headset
Pairing H500 My mom gave me her old phone and bluetooth which worked together fine while she had it. Now All I keep getting is unable to connect, what d i need to do. Thanks
  • alexmissthan Sep 16, 2008
    Thanks alot for your help. I Tired that it didnt work. It is the same phone and blurtooth piece that she used. The bluetooth was paired to this phone before
    Genius:
  • 1,019 Answers
You need to get the device, to communicate with your bluetooth.
To do this, put the devices to be connected close together.
while the phone et,c is searching for the device. press any buttons on it. i.e vol up/down on/off.
so that the receiving device can locate its signal.
this is known as pairing, it,s already been paired. to a different device.
you need it to find yours.
Mike @ Compurepair.
Posted on Sep 16, 2008
Can not connect H500 bluetooth with Nokia 2680 slide cell phone. Need Motarola instructions.
Here are the steps to connect your Motorola H500 to your Nokia 2680 phone:
1. Switch off your H500 by pressing the main button for few seconds. 2. Put the H500 in discovery mode. To do this, press and HOLD the main button till it glows a solid blue light (no blinking). 3. Open bluetooth in nokia phone. Go to Menu, settings, Connectivity, Bluetooth. 4. Select "Add a new Device" and search for H500 5. Click on the name select pair. 6. it will ask for pairing code. Enter "0000"
You are done. Revert in case you have any problem
Jun 09, 2011 | Cell Phones
I am trying to connect my H500 to my new
Enter '0000' (four zeros) when your phone requests a passkey whilst pairing with your headset.
Hope it works for you.
Cheers! Carlos
May 17, 2010 | Motorola Mobility Universal Bluetooth...
I have a new droid by motorola and an old h500 bluetooth headset. It still pairs beautifully with my old blackberry, but won't pair with the droid. HMMM? Any tricks? What am i doing wrong?
You need to put your H500 into "pairing mode" by pressing the call button until the light turns steady blue, instead of blinking. Your droid will then see it when you are in the Bluetooth Settings screen under Networks & Wireless. I just did this myself last night and it worked fine. Be forewarned, however, that you cannot voice-dial with your bluetooth - only answer calls. There are several forums out there that are bashing Motorola & Google for not having this basic functionality.
Dec 26, 2009 | Motorola Mobility H500 Wireless Headset
How do i get h500 in pairing mode
sometimes you cant do the same things the way you are accustom to do things especially when it is old (h500).
try this make the light stays on the h500 then scan or pair the device.
also you should programme the h500 in your phone as an trusted device and you should get better results.
trust me i have the same one on my ears , and gave me hell too (smile)
Aug 26, 2009 | Motorola Mobility H500 Headset
Problems pairing up a Nokia 6301 with my Motorola H500
Try power cycling the phone. Turn the Nokia off, wait 10 seconds, then turn back on and try again. It really does help sometimes. Let us know if this doesn't help.
Apr 01, 2009 | Motorola Mobility H500 Wireless Headset
I have a problem with my bluetooth headset h500 pairing it?
The Blackberry Pearl was designed to work with 2.0 model bluetooth handsfree headsets. Whereas the Motorola H500 is compatible with 1.1 - 1.2 bluetooth apps only. I'm guessing you will have to dish out the cash on this one, sorry!
Jan 14, 2009 | Cell Phones
How do I use motorola bluetooth H500 with razor phone?
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your bluetooth headset pops up on the list, highlight it and press ok to connect.
your cell will then ask permission to bond with the phone, select yes. It will then ask your for a pin. The pin will be 0000.
Dec 26, 2008 | Motorola Mobility H500 Headset
Cell samsung SGH-F250 with bluetooth motorola h500
ACTIVATING THE BLUETOOTH
You must activate the Bluetooth feature of your phone to be able to establish a Bluetooth connection
between your phone and your SuperTooth kit as well as with other Bluetooth devices.
1.
Press Menu > Settings > Bluetooth > Activation > On.
2.
Press Back as many times as needed to return to standby mode.
PAIRING TO THE CELLULAR PHONE (Not possible while charging the SuperTooth)
Pairing will create a link or connection between the two Bluetooth devices - the SuperTooth kit and your phone.
1. Bring the cellular phone at about 20 cm from the SuperTooth.
2. Turn off the SuperTooth and wait for about 4 seconds.
3. While pressing the Answer Button, turn ON the SuperTooth by sliding the Power Switch to the right. Keep the Answer Button pressed for approximately 10 seconds until you hear a distinctive tone and the Bluetooth indicator LED changes from blinking blue to alternately blinking of red and blue. The SuperTooth is now in pairing mode.
4. While the SuperTooth is at pairing mode, access the Bluetooth menu of your phone. Press Menu > Settings > Bluetooth > My devices > Search new device. The phone will then search for pairable devices until it displays them in the list.
5. Highlight SuperTooth then press Select.
6. Enter PIN “0000” then press Ok. (Wait until “Paired with …“ and “Connected” will be shown briefly.)
7. Press Back as many times as needed to return to standby mode. Pairing is successful if the alternating red/blue lights of Bluetooth Indicator stops and then change to plain blinking blue. Normally, the phone would also show briefly on its display if it’s already paired and connected to SuperTooth or if pairing with it failed.
The SuperTooth kit is now ready to use.
Nov 15, 2008 | Motorola Mobility H500 Wireless Headset
Pairing works, but no connectivity
I had the same problem and went through several iterations. The AT&T store gave me the idea of powering off the BlackBerry and H500 but this did not correct the problem.
What did correct the problem was powering off the BlackBerry, then pulling out the battery and waiting a minute, then reinstalling the battery and powering up. I had the H500 off as well and powered it up into pairing mode at the same time. Back in business now, so that seems to be a way to clear the error.
Good luck
Jun 11, 2008 | Motorola Mobility H500 Headset
Bluetooth
Press the all-in-one button for about 8 seconds until the light is constantly on, this puts it in pairing mode. then go to your device and initiate pairing. the device code is 0000.
When done the blue light should shut down, and your all set.
Nov 07, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility H500 Wireless Headset Logo
102 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
