Power regulator what is the number of ic power regulator of sharp television model 20V-L70m
scott201201
  • 170 Answers
SOURCE: television power led blinking
are you sure that you are checking this correctly?
What is the location number for this regulator?
If its the main regulator, what are you using for ground on your meter? Also, isn't the part number marked on the regulator?
Posted on Apr 12, 2008
SOURCE: Does the TOSHIBA TA8445K Vertical Deflection IC fails when the Deflection Yoke is Dirty?
hola tengo un tv onwua que no me habre el verticar ya revise los voltajes y estan bien pero en la pata 11 tengo solo 7 voltios en ves de 12 voltios cual puede ser el problema de mi parte muchas gracias.mi email es ruben_148_2@hotmail.com.
Posted on Aug 15, 2008
Rifaa
  • 99 Answers
SOURCE: MY SHARP PRIMO TV MODEL 20V L75M IS ASKING FOR A SECRET NUMBER
It may be a parental lock, so u need the code or u have to reset it, check the manual on how to reset it
Posted on Jan 08, 2009
  • 1340 Answers
SOURCE: I have Sharp 20V-L80M, Power
I have tried numerous times and the TV manufacturers will not sell parts or diagrams to consumers.You have to be a repair shop with a username and password just to view the stuff.Here is one possibility.
http://www.eserviceinfo.com/most_wanted_link.php?what=list&requestid=44394
I will try for others...hang on please.Here is another possibility.All I usually find is user's manuals which are free few and far between.Schematics just aren't out there.
http://esupport.sharp-cee.com/html/om/index.php?ProdLine=40&TemplateLang=en
Sorry to have to tell you that.I like to fix my own stuff too.There is nothing more I can suggest with all the limited access.Good luck!Maybe if you take the regulator out and ask a shop?
Posted on Aug 02, 2010
  • 130 Answers
SOURCE: my tv sharp model no.20v
have an oscilloscope? trace the audio. I'm assuming you have a scope if your replacing I.C.s in TVs. make sure your volume is up a little bit when checking the amp section. make sure all wires are connected (speaker too).
make sure tda is getting voltage (view tda7056 datasheet for pinout data)
make sure it isn't an eprom fault
Posted on Apr 15, 2011
Testimonial: "i tink the problem of this no sound is the eprom fault tank you very much"
Possible cause of sharp primo 20v-l70m standby led power
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 16, 2016 | Sharp Televison & Video
I have sharp tv model 20v-r70m not power on the b+ is ok i try test 9v supply go to ic801 drop the 9v,then i try replace ic801 nothing happen, how to fix this
pls. check if there has 5v ic regulator... also check the open non- electrolytic colored yellow or orange tantallum capacitor near the talc switches and memory ic.if i'm not mistaken.... the capacitor value is 2.2uf 50v.
Jul 14, 2014 | Sharp Televison & Video
Sharp 20v-w70m speaker and IC ok but no sound
Check the input voltage to IC. If it is absent, the IC won't work. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 31, 2013 | Sharp Televison & Video
Fading brightness of sharp 20v-l70m
pls. try adjusting screen control.
Jul 04, 2013 | Sharp 25R-S100 25" TV
Sharp model 20v l70m
What is the problem to your Sharp TV? Provide more details please.
Jul 04, 2013 | Televison & Video
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
