Question about Toshiba Satellite A135-S2386 Notebook
Computer won't start
WIth the battery in and the laptop connected eto the a/c the computer will not start. When I remove the battery and use a/c power only the computer does start correctly and tells me there is no battery available. Where do I start the surgery!!
    Scholar:
  • 45 Answers
Hello rb76wetu,
Well this is an easy one.... Provided you know for a fact that your battery is good, then the answer is that you have a fault on the hardware side of the board. There is so little to check on the battery side that it may be that you only need to replace the battery contacts on the motherboard (tho it is a rare failure).
If not then its the motherboard that has failed. This CAN happen if you have kept a failed battery in the laptop too long which then fries the charging circuit.
Sorry for the bad news, but its repair bay time or get out your solder kit and have a go.
Posted on Sep 16, 2008
    Brigadier General:
  • 5,158 Answers
You don't .... replace the battery it's defective.... check for recalls... there is currently one going on for Vaio or Viao
Robert
My hp 2000mt pro pc won't start up
The first thing to check is for proper power. Try connecting your charger with the battery removed and powering up the computer. If you are not successful with this, it may be that the charger is defective and not charging your battery.
Advise that you purchase/borrow a supported laptop charger. A local HP repair center should have a compatible charger that you could use to test.
If it is not the charger (the laptop should work without a battery), then you have motherboard problems. Memory or other issues would cause a power on but errors. No power up at all is going to require some sort of board replacement.
At that point, your choice is warranty repair service or, if out of warranty, best bet will be replacement of laptop.
Oct 21, 2012 | HP Pavilion 1137NR Notebook
Dell inspiron 1300 won't boot
If you want to keep your important data, use some softwares can solve thewindows won't startproblem most quickly, and no data will lose. Besides, it is very easy, even the people who lack of computer knowledge can deal with windows won't boot issue.
Sep 21, 2012 | Dell Computers & Internet
My samsung r480 won't power on, or charge
First remove the battery and connect the charger, if power is coming,Then connected battry
Apr 05, 2012 | Samsung R480 Notebook
No power , computer will not turn on
Hi, IF the system is not turning on any more, try removing the power cable, then press the power button for 10 seconds. then try to power it on again . If it is still not powering up there could be an issue wiht the power supply of the computer. But if it start to turn on, like showing the Sony logo then windows but not going to the desktop. you can try to log on using safemode. you can go there by pressing F8 on the keyboard after turning on the computer. If it still not turning on even on safe mode. there couldbe an issue with the operating system of the computer and needs to be reinstalled.
Thank you for using Fixya, your recommendation is highly appreciated for the free support.
Aug 20, 2011 | Sony VAIO V2M (VGCV2M) PC Desktop
My computer won't turn on i can get to the internet because it has an internet button but the main part of the computer won't turn on
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Aug 19, 2011 | Sony Computers & Internet
Computer won't boot pass window screen. ..
if there is password when you start the system then switch off the laptop remove the battery then remove the cmos battery and place battery and switch on the computer then switch of the laptop and replace cmos battery and switch on the laptop the password will reset
Jun 02, 2011 | Computers & Internet
My compaq presario cq60 won,t turn on. the power light next to the charger cable is on but it won,t turn on
The charger is functioning well. There are still two possible reasons why your computer is not turning on. 1. The battery, 2. The computer itself.
What you need to do is to isolate the problem.
Here's what you can do to isolate the problem.
1. Remove the battery from the computer.
2. Turn on the computer using the cord. Remember not to put back the battery yet. Just the cable and the computer connected. If the computer turns on, then, you need to replace the battery.
3. If it still not turning on by using the cord alone. Try to wiggle the cord to check whether it's loose or not. Check if there are some signs of power on the computer. If there is a power like lights lit in the computer, then, it's the computer that's having the problem. You need to bring it to a technician if that's the situation.
Please let me know if there are any development after doing the troubleshooting above so that I can get back to you if you need my help.
Thank you for using fixya.com
CARLO
Apr 13, 2011 | Compaq Presario CQ60-220US PC Laptop
Hp nc4200 won`t start
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not work, try also disassembling the laptop & make sure that all main components are seated properly. Also make sure that all ribbon cables interconnecting the various components of the laptop are tightly connected.
Dec 28, 2009 | HP Compaq nc4200 Notebook
When connecting to the usb on Mac laptop I get the error message Device is using too much power and will be deactivated. I have had this camera for 7 years and this has never happened. Removed and...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Aug 05, 2009 | Pentax Optio S4i Digital Camera
Forgot bios password
1. Shut down the computer. If you are unsure whether the
computer is off or in Hibernation, turn the computer on,
and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power cord.
4. Remove the battery pack by following these steps:
a. Turn the computer upside down with the front panel
toward you.
b. Slide and hold the battery release latch 1 to the left. (The
front edge of the battery pack disengages from the
computer.)
c. Lift the front edge of the battery pack 2 and swing it
back.
d. Remove the battery pack.
5. Remove the RTC battery from the socket on the system
board.
6. Wait approximately 5 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any
battery packs at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
May 07, 2008 | HP Compaq Presario V2000 Notebook
Toshiba Satellite A135-S2386 Notebook Logo
42 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
