Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
No Idle Occasionally, my 2007 FLHRCI will not idle unless i stay on the throttle. Start it...it dies. While riding, pull in the clutch...it dies. Usually it'll start idling again on its own in a few minutes but this last time it lasted 3 days and several hundred miles. Took it to dealer and ran fine (of course) and computer showed nothing. Any Ideas?
  • 1 more comment
  • 07roadking Sep 16, 2008
    Yes, it has stock air cleaner, and usually (but not always) it happens when i'm in or just after a parade situation and perhaps was a little warm.
    No carb - fuel injected. Solution still apply?
    Thanks a lot.I'll give it a try.Don't need any pictures.I agree it should be a simple fix. We'll see. Thanks again.
    Guru:
  • 674 Answers
Sound like the idle controll isnt working or got stuck .
it didnt code which makes me wonder does it have the stock air cleaner?
Posted on Sep 16, 2008
  • paul erickson
    paul erickson Sep 16, 2008
    pull the air cleaner and spray carb cleaner into the carb while its running the ridle wil rise and fall with short bursts. theis will open and close the idle valve and when you are spraying it will clean it .
    give that a try . i realy dont think you have a hard problem. just sticky.
    good luck and dont get any carb cleaner on your paint....
    later
    paul
  • paul erickson
    yea
    the carb doesnt have an idle air control valve.
    and the EFI does and that is the part that sticks.
    i like the 3M brand carb cleaner and put the tube on the can so you can direst the spray into the throttle body.
    lst me know if you have any problems s i might have some pictures of the throttle body. but i would have to look
    let me know if you need them you shouldnt it a simple fix.
    later paul
I have a 2007 cbr600rr, and I have noticed lately my bike idles around 1900-2000rpm, normal is around 1400-1500rpm(this is when the bike is warm), also when using the engine for braking it feels a little...
Hi, Anonymous and the usual suspects are:
1. Throttle cables improperly adjusted, pinched or need lubrication.
2. Idle adjusting screw needs to be backed off.
4. Air fuel mixture adjusted too lean start with 2 full turns.
5. Intake system air leak.
6. Fast idle choke ramp is not releasing.
7. Broken throttle return spring.
8. Damaged diaphragm or slide.
9. Faulty MAP, TPS, ATS, O2, sensors or wiring/connector
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2007 Idle Issues
How to Adjust the idle on 04 06 cbr600RR
2007 2009 Honda CBR600RR Service Manual Moto Data Project
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBR600RR 2007 Owner Manual
Jun 01, 2017 | 2007 Honda CBR 600 RR
02 yamaha yzf600r when riding pull in clutch rpms stay high come to stop they will come down slowly
1. Throttle cables improperly adjusted or pinched.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
YZF600R Forums View topic Tired of this issue random high idle
YZF600R Idle Problem Rev Problem
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
OEM parts for Yamaha
Yamaha YZF600RP Owner Manual
May 07, 2014 | 2002 Yamaha YZF 600 R thunder cat
Starts stalls
contaminated or water in the fuel is most likely the culprit here.
drain the tank and carb (small screw at bottom of carb float bowl)
Add fresh fuel from a CLEAN fuel source. Best to completely drain your fuel can and fill it up with fresh fuel. That way if the fuel can is the culprit you eliminated doing this twice.
What happened was fuel sits on top of water, this is why the bike would still idle. The idle circuit in the carb pulls fuel from a higher point than the main jet. This is also why when you hit the throttle it would just die, it was sucking most like something other than fuel.
Apr 02, 2014 | kawasaki KX 450 F Motorcycles
I have a small 4wheeler that is hard to start and will not idle it will run at speed but if you stop it doesn't idle it dies
Your pilot jet in the carb is plugged up or to small you will have to pull the carb out and clean it if you have a wire brush you can use 1 of the needles off it that will fit in the tiny hole in the pilot jet push it through and then spay carb cleaner through it and the main jet put back together and it should run fine
Nov 26, 2013 | RTO 125cc Full Size Adult Quad ATV
Remove gas tank
Does it idle correctly ??? You have an idle mixture screw that might need to be tweaked a little or you have an idle jet that is dirty. When you turn the throttle past that point you are pulling fuel through the main jet and bypassing the issue. Try to partially apply the choke and see if it runs better at your problem spot, this will help diagnose the issue...
Nov 26, 2013 | 2001 Harley Davidson FLHRCI Road King...
My 97 Dodge ram Van won't stay running.
Unless the vac leak is very large, it would not keep the engine from idling.
The computer controls idle speed by regulating how much air enters the intake thru the throttle body by use of the idle air control valve.
The throttle body could be gummed up, or the idle control valve may be faulty.
Feb 19, 2013 | Cars & Trucks
1995 honda civic dies when you stop occasionally.
check the throttle lines ,set idle just above stalling point if need be
Oct 22, 2012 | 1995 Honda Civic
Hi, I have a 1999 Chico/Citi Golf. The revs stay above 1000 and do not want to drop, I do not even have to pull the choke out. How do I get my revs to drop back to 1000? It use to Idle just below 1000,...
Check that the choke accelerated idle cam is not stuck. Check that the throttle cable has not dislodged and the outer casing is riding on the bracket. Check that the throttle linkages are free and the throttle returns to the idle adjustment stop. If all these are correct, adjust the idle adjustment to obtain the correct idle speed. 700 - 800 rpm is about the right speed.
May 15, 2011 | Volkswagen Golf Cars & Trucks
When warm looses idle speed and cuts when coasting to a stop
Try turning the idle up a bit after it has gotten to running temp. There's a nob down beside the carb and turn it in ti raise the idle.
Oct 01, 2009 | 2007 Yamaha Stratoliner
When 1993 dodge caravan is driven awhile, It sometimes will not
idle is set at factory but if the idle air control valve is bad it won't idle right also if the throttle position sensor is not working right it won't idle right a diagnostic scan should be able to determine which one is needed.
Aug 25, 2009 | 1993 Dodge Caravan
Lands Phones Logo
192 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
