Question about Sony Handycam DCR-HC21 Mini DV Digital Camcorder
C31 42 ERROR
I GET THE C 31 42 ERROR AND MESSAGE REINSERT THE TAPE. WHEN I RELEASE THE TAPE DOOR THE CASSETTE EJECTS VERY SLOW. WHEN I REINSERT THE TAPE AND CLOSE THE DOOR, SOMETIMES THE TAPE WILL RUN FOR A 4 TO 5 SECONDS AND THE ERROR CODE AND MESSAGE REAPEARS. CANNOT GET THE TAPE TO PLAY. REWINDS SOMETIMES. FAST FORWARDS SOMETIME. ALWAYS RETURNS WITH THE ERROR CODE.
  • 883 Answers
SOURCE: trouble with camcorder
try cleaning the rubber pinch roller with a cotton swab dipped in alcohol
Posted on May 26, 2007
  • 883 Answers
SOURCE: Eating Tape when rewinding in vcr mode
look for a tiny pinhole and insert a pin while powered up to reset the device. if no-go, then the take-up reel needs attention...needs possibly a new or well-cleaned-with-alcohol-swab rubber belt
Posted on May 27, 2007
  • 169 Answers
SOURCE: error message 31:22 reinsert cassette tape
reel sensor is the problem of your camera it is a common problem to that model,maybe the pinch roller is loosen to the post cause of the lock of that is been broke..that roller is that one that pulling the tape...only a technician can put it back to the mechanism and replace that lock...in sony service they replace the whole assembly and cost a lots...i suggest find other service center for fixing it...hope that roller is not lost in your camera...
Posted on Sep 07, 2007
SOURCE: reinsert tape message
I got the dreaded reinsert tape message today and i thouht that my video taping days were over. i then made my way to this page and saw this. whack it three or four times and it will work. at first i thought what a load of crap but i tried it anyways... being really mad at the time, i showed my camera no mercy. i took out the tape and gave it 4 hard hits with my palm, put the tape back in and it worked. thanks alot, this works
i
Posted on Dec 30, 2007
ctf1800
  • 4402 Answers
SOURCE: cassette loading error 31:23
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Feb 22, 2008
Reinsert cassette - After inserting a cassette the on screen message reads as follows "reinsert cassette" a further message C:31:23
when ever to get this kind of message just try to fwd the tape mannualy, or just make sure tht when u are rew. the tape dont rewind tht completely....
Jan 04, 2010 | Sony DCR-TRV285E Digital-8 Digital...
I have a Sharp ViewcamZ VL-Z900. DEW error
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
Sep 18, 2009 | Cameras
I get an eject symbol and beep and error code c32:11, original issue was that it ate a tape
The error C 32:11 denotes for mechanical unsuitability, This problem appears when the improper insertion of the cassette been done, or lose cassette tape stuck,
In all these situations mechanical adjustment is required, You are suggested to please contact any expert for the mechanical adjustment.
Hope you will understand my sayings.
Thanks for using fixya.
Jul 11, 2009 | Sony Handycam CCD-TRV68 Camcorder
ERROR MESSAGE C 31:23
The error code is part of a self diagnosis feature of your cam. This particular code refers to something being wrong which you can fix yourself. The steps you should take, involve removing tape, and reinserting. removing power adapter plug and reinserting, remove battery pack and reinsert...
power down before each step, and power up again to check working status. The result of these checks should allow you to narrow down the problem.
You may have to look at trying a new battery, or replacing the cassette, or replacing power cord, or you just had not properly hooked something up, or the cassette wasn't properly seated.
These codes and their meaning can be found in your user guide, or manual. Good Luck!
Nov 11, 2008 | Sony Handycam CCD-TRV108 Camcorder
Error C:31:42
Jun 02, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Reinsert cassette
Turn the unit off and hit the back of the camera twice near the battery compartment with the palm of your hand. Sounds crazy but it worked with my camcorder Sony DCR-TRV480. Problem started when I used 8MM Head Cleaner. I think the roller got stuck inside camcorder. The trouble code came up C:31:22. Hope this helps.
Feb 13, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Inserted cassete in wrong way in Sony camcorder CCDTRV68, not ejecting cassette Error codeC32:20
Sony camcorders C:31:23 error
good luck
please mark the post with a fixya
Dec 24, 2007 | Sony Handycam CCD-TRV68 Camcorder
Cassette loading error 31:23
Nov 18, 2007 | Sony Handycam DCR-HC96 Mini DV Digital...
Error message 31:22 reinsert cassette tape
Aug 20, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Re-attach the power source followed by Reinsert Cassette
Hai Problem in mechanism. If the tape does not loaded completely, the message will show "Reattach the power source" Please check mechanism. Raghavendra, M/s.prathiksha Electronics
Jan 25, 2007 | Sony Handycam DCR-HC90 Mini DV Digital...
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
97 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
